Go Back  Bike Forums > Bike Forums > Utility Cycling
Cargo bike rear brake has rotor rub after each ride
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 04-10-20, 09:50 AM
greensprout
Hey all, need some help. My long tail cargo bike has brake rub after each ride. I’ll adjust the brake pads after the ride so it spins freely with no rub and then as soon as I ride with any weight on the bike the brake pads start rubbing the rotor as soon as I do any braking. It starts making a grinding sound in a rhythm as the rotor spins. It looked as if the rotor was warped, but I put a new rotor on and it did the same thing. It has a wobble in it. Is this common for a cargo bike carrying weight? I carry 50-100lbs on the back. I’ve adjusted it about 10 times and each time the rubbing comes back and I have to readjust the brake pads. I’m so confused why this is happening! Any ideas?
greensprout is offline
Old 04-10-20, 05:28 PM
Maxwell
Some calipers just don’t hold The pad adjustment, mechanical brake? what brand?
Maxwell is offline
Old 04-10-20, 05:35 PM
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
Reckon the wheel is moving in the frame. Figure out if you can get it tighter, if it has an external cam QR, go to internal. Make sure the wheel is well seated. If it has horizontal drop outs use something like Surly Tuggnuts to keep the wheel in one place.
Trevtassie is offline
Old 04-10-20, 09:30 PM
greensprout
Thanks for the replies.
This is what the setup looks like. Everything is nice and tight. Maybe the calipers aren’t holding? I can try tightening them extra tight and see what happens. I’ve already tried to really tighten them up.
Old 04-11-20, 03:56 AM
Trevtassie
https://www.parktool.com/blog/repair...rake-alignment
