Mystery frame. 50's? Nervex? England A&P? unusual serial number
Old 07-06-11, 05:35 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
Liked 40 Times in 16 Posts
i've been looking for a 1 size smaller frame with some character to build a townie/light duty porteur style/grocery getter type.
i was watching this on eBay with no real intention of bidding, but at the last minute i threw out a bid and won. i had some reservation due to the seller claiming some possible damage to the top tube.
i laid a straight edge in every which direction to try and find said hump and cannot find anything. checked all tubes and nothing. the only thing might be that the top tube has a 'sag' to it in the center, however i could not pass a credit card between the straight edge and tube so i'm not too worried. also, this is the original fork with matching serial number so any frontal impact causing damage to the top tube would surely have taken the fork out with it.
anyway, it will be perfect for my needs and i absolutely LOVE the Nervex lugs, the detailing and sharp edges is to die for!
english thread bottom bracket and headset
Nervex lugs and bottom bracket shell
seat post diameter is 26.4mm
possibly fully chromed at some point, headlugs, entire fork and rear stays/drops are definitely chromed
high-res pictures here: https://www.flickr.com/photos/alexjri...th/5909935317/
serial number on fork and BB is 95112 with a 7 below it (what's all the other gobbledygook beside the serial? angles and such for the BB?)
IMG_1284 by shnibop, on Flickr
IMG_1297 by shnibop, on Flickr
tubing 'Made in England' by who? A&P A?
IMG_1285 by shnibop, on Flickr
anyone recognize this fork crown?
IMG_1294 by shnibop, on Flickr
IMG_1296 by shnibop, on Flickr
IMG_1293 by shnibop, on Flickr
IMG_1295 by shnibop, on Flickr
IMG_1291 by shnibop, on Flickr
IMG_1289 by shnibop, on Flickr
IMG_1287 by shnibop, on Flickr
i'd love to know:
who made the frame?
the era?
what kind of tubing?
also, are solid axle/wing nut style axles narrower in diameter than later quick release style hollow axles? i tried to throw a loose Campagnolo Tipo hub in the rear drop outs, the axle will fit but takes an amount of force that would indicate that it's probably not intended to fit this style of axle. can i swap solid axles for the QR axles easily enough? eBay the source for such things? i wanted to build this up with parts i already have, but perhaps a completely different setup would be a better option. not looking to do a period correct build by the way.
shnibop is offline
Old 07-06-11, 05:43 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 1259 Post(s)
Liked 1,294 Times in 793 Posts
Accles & Pollock tubing.
I'm not quite sure, but it looks similar to a Freddie Grubb. It's missing the requisite headbadge holes, though.
-Kurt
cudak888 is offline
Scooper
Decrepit Member
Scooper's Avatar
Bikes: Waterford 953 RS-22, several Paramounts
Quoted: 621 Post(s)
Liked 38 Times in 33 Posts
A&P is Accles & Pollock, a competitor of Reynolds and acquired by Tube Investments in 1919.
In the early 1960s, there were 11 companies in the steel tube division of Tube Investments, including Accles & Pollock and Reynolds Tube Co. Ltd. (see companies in the red box below).
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Old 07-06-11, 06:01 PM
Oregon Southpaw
Larger Chainring
Oregon Southpaw's Avatar
Bikes: 1988 Schwinn Circuit. Bike-Boom-Puegeot. First "real bike" Trek 720 Hybrid in gross disrepair.
You sure don't see ads like that anymore.
Oregon Southpaw is offline
Old 07-06-11, 06:13 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1767 Post(s)
Liked 266 Times in 179 Posts
Looks like a nice frame!
My Fothergill has a similar accles & pollock stamping on the steerer tube, but the traces of the tubing decal on the seat tube were consistent with the size and shape of a Reynolds 531 decal. I don't know any other way to tell the tubings apart (the weight of the frame is consistent with 531, but Kromo wouldn't be different). I put a 531 decal on it.
Is there only one shifter boss? That's a 50's thing. It'll probably fit a Simplex or Cyclo Benelux shifter. A good way to use that is with Sturmey Archer AW hub with two cogs and a derailleur; this gives six evenly spaced gears.
rhm is offline
Old 07-07-11, 01:21 AM
realestvin7
Large Member
realestvin7's Avatar
Liked 3 Times in 1 Post
Super sweet frame? How about a full body shot? Lol.
realestvin7 is offline
Old 07-07-11, 01:28 AM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 206 Post(s)
Liked 212 Times in 100 Posts
That really is a great looking frame.
mkeller234 is offline
Old 07-07-11, 01:36 AM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
1 shifter boss. btw, your Fothergill is a real inspiration, i will be PMing you with questions
IMG_1286 by shnibop, on Flickr
shnibop is offline
Old 07-07-11, 01:40 AM
realestvin7
Large Member
Wow. What size? TT length?
Old 07-07-11, 05:35 AM
Charles Wahl
Disraeli Gears
Charles Wahl's Avatar
Quoted: 297 Post(s)
Liked 117 Times in 78 Posts
. . . From the days when people could/would read.
Charles Wahl is offline
Old 07-07-11, 08:24 AM
Scooper
Decrepit Member
Scooper's Avatar
Quoted: 621 Post(s)
. . . From the days when companies were hiring.
- Stan
my bikes
Scooper is offline
Old 07-07-11, 08:45 AM
dbakl
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 11 Post(s)
I was watching that on ebay, looks like a nice frame. Damage concerned me.
Don't know why, but fork crown looks Italian to me...
dbakl is offline
Old 07-07-11, 09:54 AM
David Newton
Wood
David Newton's Avatar
Bikes: Raleigh Sports: hers. Vianelli Professional & Bridgestone 300: mine
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
Beautiful and full of potential.
I really like how you won't have to listen to everyone wailing to you to leave the finish original.
David Newton is offline
Old 07-07-11, 11:10 AM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 699 Post(s)
Liked 276 Times in 226 Posts
[QUOTE=dbakl;12892361
Don't know why, but fork crown looks Italian to me...[/QUOTE]
the crown is definitely made for Imperial pattern blades (like domestic Reynolds) and is either cast or forged...not likely Italian.
I can't seem to find Milremo catalog scans anywhere on the Interwebs, today, but I'd guess this is either one of those (read Bocama made for Ron Kit) or a Vagner. So I'd say "French". It has a slight resemblance to another FR make: one of the Nervex Super Legere patterns, but those were supposedly welded-up crowns, not forged.
unworthy1 is offline
Old 07-07-11, 06:53 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
thanks for all the feedback so far guys/gals!
i checked around on the Freddie Grubb possibility, however i don't think that's what this is. there are quite a few similarities but also some differences in details that were consistent in the confirmed F.G. frames, my frame lacked those certain details. also, i checked inside the head tube and have since sanded some of the paint... there was/are no head badge holes.
i've also sanded through the green, then the brown/primer layers to try and find any remnants of decals on the main triangle tubes, there are no longer signs of decals or original paint color.
however, there is this metallic candy pink color on the fixed cup side of the BB, around the lugs of the BB, inside the BB on the ends of the chain stay tubes and on the back of seat lug (all the hard to reach spots perhaps, DIY painter got lazy?). i believe this would be the original color although this doesn't narrow down the frame builder obviously/unfortunately.
IMG_1300 by shnibop, on Flickr
IMG_1303 by shnibop, on Flickr
IMG_1304 by shnibop, on Flickr
any more incite?
shnibop is offline
Old 07-07-11, 07:05 PM
realestvin7
Large Member
No way that bike was originally pink. Until the 80's, pink was a girl's color.
You want to trade that beauty for something in the "old garage"? Lol.
Old 07-07-11, 07:29 PM
cudak888
cudak888's Avatar
Looks more like the basecoat for a Schwinn-style "flamboyant," semi-transparent red color.
-Kurt
cudak888 is offline
Old 07-07-11, 09:11 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2434 Post(s)
Liked 942 Times in 605 Posts
Well, here's one Milremo scan, but the crowns don't look quite like what is on that frame:
JohnDThompson is offline
Old 07-07-11, 10:10 PM
unworthy1
unworthy1's Avatar
Quoted: 699 Post(s)
true, and thanks for that scan. Ever see a forged/cast Vagner (or any other) crown with letters and numbers in the underside like the OP's?
Old 07-07-11, 11:58 PM
noglider
noglider's Avatar
Quoted: 6769 Post(s)
Liked 1,371 Times in 880 Posts
My usual response to the "help me ID this" threads is, "I don't know, but it sure is nice!"
And it applies here.
Not true. In the early 20th century, pink was for boys and blue was for girls.
I have more shirts in pink than any other color.
noglider is offline
Old 07-08-11, 12:03 AM
realestvin7
Large Member
That's with sirts. Not a steel riding machine. Don't get me wrong, it's pink all the way. I have had 4 pink/yellow Ironman bikes.
Old 07-08-11, 06:57 AM
rhm
multimodal commuter
rhm's Avatar
Well, that settles it for once and for all.
rhm is offline
Old 07-08-11, 09:04 AM
noglider
noglider's Avatar
See, now you know me completely!
I was riding my bike in Maplewood a couple of years ago, wearing a pink polo shirt, and someone leaned out of the car she was riding in and yelled, "Nice shirt ... QUEER!"
I was perplexed, but when I retold the story on maplewoodonline.com, people got upset. This is supposed to be one of the most gay-friendly towns.
noglider is offline
Old 07-08-11, 09:25 AM
rhm
multimodal commuter
rhm's Avatar
Her problem if any, not yours.
My wife just called me from Target asking me if I'd wear plaid shorts. I said, if you think I'll wear them, I'll wear them. She may regret this, but I won't be bothered one way or nother.
rhm is offline
Old 07-08-11, 09:38 AM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 29 Times in 20 Posts
In Italy, you see lots of men wearing pink shirts. They look great with dark hair and olive complexion. I personally assume that a guy in a pink shirt is a very confident guy, gay or straight.
lostarchitect is offline
