Mystery frame. 50's? Nervex? England A&P? unusual serial number
Old 07-08-11, 10:00 AM
vjp
Liked 3 Times in 3 Posts
As said above, Accles & Pollock "A" tubing, looks 40's, maybe 50's to me.
vjp is offline
Old 07-08-11, 07:54 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
Liked 40 Times in 16 Posts
got a message from the seller in regards to what components were on the bike when he acquired it. i can't imagine it would help to identify it, but maybe.
"...The cranks were Chater lea or chater Lea style cottered cranks, 3 pin with a Baylis-wiley Bottom Bracket. THe Headset was a cool looking steel Brampton and the stem is Pivo. The Saddle was a Leather Lycett..."
do these bits (assuming they were original) make it more likely french vs english or vice-versa?
Edit: stupid question, obviously English since all threads are English, duh
shnibop is offline
Old 07-08-11, 11:31 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 697 Post(s)
Liked 272 Times in 223 Posts
even without the component list it is British without doubt....just has some French frame bits.
Sorry but I can't ID it, maybe Hilary or Norris can.
unworthy1 is offline
Old 07-09-11, 12:26 PM
realestvin7
Large Member
realestvin7's Avatar
Liked 3 Times in 1 Post
Who gives a funk what it is. I'd build it and ride it. I'm slightly jealous.
realestvin7 is offline
Old 07-09-11, 01:27 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Trevisio, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 51 Post(s)
Originally Posted by realestvin7 View Post
No way that bike was originally pink. Until the 80's, pink was a girl's color.
You want to trade that beauty for something in the "old garage"? Lol.
Prior to WWII, pink was a boy's color.
bbattle is offline
Old 07-09-11, 10:27 PM
oldbobcat
oldbobcat's Avatar
Bikes: '79 Gios, '80 Masi, '06 Felt, early '60s Frejus
Quoted: 43 Post(s)
Liked 29 Times in 23 Posts
Absolutely lovely. It takes a lot of work to miter tubes to fit in those narrow lug flanges. If riding a bike whose make you can't identify keeps you awake nights, I'd gladly ride it for you.
oldbobcat is offline
Old 07-10-11, 07:59 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
alrighty so i stripped the frame today, 99% of the way at least. there are a couple tiny little dings here and there but nothing horrible.
the fork was completely chromed as well as the head tube lugs, and half of the stays and drops. also, the fork is a bit tweaked, 90mm between the fork tips. i laid a center line and it seems the drive side blade is pushed in, non-drive seems fine.
i had my LBS check the frame for any misalignment and they found nothing, the drops are within 1mm of each other in terms of center line of the frame, pretty good for a half century old frame.
i found more of the pink paint throughout:
weird swirly rust all over the main tubes, sands right off however:
remnants of chrome on head lugs, can barely be made out:
numbers/letters on bottom of fork crown are more visible now, possibly '047' and 'WJ':
chrome on the fork is a total loss, front of fork crown looks half way decent but the rest is awful:
a little patch, the last of once glistening chrome:
my next step will be to remove the rest of the paint and rust, then decide how i want to paint it. either try brushing it on, a first for me, or spray, i've had great success with Duplicolor's automotive line of enamel paints. decisions...
shnibop is offline
Old 07-10-11, 10:02 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1767 Post(s)
Liked 266 Times in 179 Posts
Have you looked over the head tube, seat tube and down tube for any traces, any shadows, of old decals? Those rust swirls you show often leave a black stain on the tubing that doesn't clean off well; and under where the decals were, that stain may be missing. See anything like that?
rhm is offline
Old 07-10-11, 10:54 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
oh yes, i looked. i was hoping to see something like you saw on your Fothergill
shnibop is offline
Old 07-11-11, 01:27 AM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
i tried threading a Campagnolo NR/SR shifter on the shifter boss and the threads seem to be different. is this normal for a frame of this vintage?
shnibop is offline
Old 07-11-11, 05:58 AM
rhm
multimodal commuter
rhm's Avatar
I think that is normal. If it's like the one I used to have --and I think it is-- then a Cyclo Benelux shifter will fit on there. Simplex and/or Huret would be worth a try. I don't have a frame with one of those bosses any more, so I cannot check for you.
rhm is offline
Old 07-11-11, 11:31 AM
dbakl
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 11 Post(s)
The Carltons I've had with brazeon shift mounts didn't fit the Camagnolo screws, I think they were for Benelux: the levers will work however...
dbakl is offline
Old 07-15-11, 04:51 PM
sisddwg
Congratulations! I came very close to bidding on that myself. I think it's a very fine looking frame. A few weeks ago I purchased an unknown frame and fork. I built it up and road it and love it! It fits perfectly and rides great. Now really care less what it is. Actually, I think it likely came out of the Motobecane factory with a Astra name on it. As to your bike, if that light mount is on the right fork blade (drive side), to me that would indicate British. Enjoy!
sisddwg is offline
Old 07-15-11, 08:36 PM
shnibop
shnibop's Avatar
Quoted: 51 Post(s)
news flash! don't assume that an ebay seller's description is accurate.
i've got the frame stripped down 99% of the way and decided i want to mock it up and take it for a quick spin and make sure everything fits (ie. brake reach, BB spindle width etc.) before painting.
well it turns out the BB threads are French, not English as stated in the listing. for a second i couldn't figure out why my fixed cup would not thread in, well because the threads are going the opposite direction. luckily i have a French thread BB as well. it went in a little crunchy but it went in.
unfortunately the crank setup interferes with the chain stay. i wanted to run a cyclo-cross Stronglight 93 chain guard and 1 chain ring, the inner chain ring hits. so i have to ditch the chain guard or get a wider spindle. btw i'm using the matching BB for that crank set.
on a side note, given the fact that it might be a French frame now, does it make it more identifiable based on the serial number?
shnibop is offline
Old 07-15-11, 08:51 PM
rhm
multimodal commuter
rhm's Avatar
By the way, here is the Accles & Pollock stamp on the steerer tube of my Fothergill, which I think dates to the 40's.
I don't know what the French BB means. But the light boss on the right side of the fork, that's still English. The French drive on the right side of the road and anyway, the French like their headlights mounted atop the front of the fender.
rhm is offline
Old 07-15-11, 08:56 PM
realestvin7
Large Member
These are the days of our lives...
Old 06-15-13, 11:19 AM
Jaebook1
Hi, i know this is an old tread, but i think you have a Viking frame. Look at classicvikings.co.uk. Nice frame, i think its an An Steel Model. Jim
Jaebook1 is offline
Old 06-15-13, 12:14 PM
madscrambler
Bikes: '71 Raligh Pro , 1956 Sport; 1895 Victor standard, Bertin 1950's racer.
Quoted: 7 Post(s)
Liked 6 Times in 3 Posts
I have a 50's Bertin that has Nervex Lugs and a numbering system on the bottom bracket similar to the one in your photo. However it begins with 59 suggesting to me that it is a mfg code from Nervex and it very likely begins with the year made.
madscrambler is offline
Old 11-20-17, 11:32 AM
trevoruk
its a BATES British made bicycle built by brothers Horace and EG Bates.
Good luck with your restoration.
Google classic Lightweights UK
Regards
Trevor
trevoruk is offline
Old 11-20-17, 04:47 PM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 29 Times in 20 Posts
Regards
Trevor
Trevor, can you let us know how exactly you came to this conclusion? Thank you!
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
lostarchitect is offline
Old 11-20-17, 07:06 PM
trevoruk
I have just acquired the same manufacturers frame..mine is about 1954 serial number 17469. Mine probably made by EG Bates. His Brother Horace was famous for a unique design of tube and front fork.
trevoruk is offline
Old 11-21-17, 05:56 AM
trevoruk
Sorry...I could be wrong here with my assumption...please delete if a distraction in the thread. Regards
trevoruk is offline
Old 11-21-17, 08:16 AM
hobbs1951
Velominatus
Bikes: 1986 SBDU Raleigh, 1984 Raleigh Corsa, 1980 Allin Stan Butler Special, 2 x late 1960s Roberts, 1978 Philbook, 1964 Allin Belgique, 1959 Allin Stan Butler Special, 1951 Higgins Plus Parfait, 1951 Hobbs of Barbican, 1913 Centaur Featherweight.
Quoted: 194 Post(s)
Liked 31 Times in 20 Posts
I'll not get involved in identifying this frame (I think I know what it is though), but I will advise you - forum members - that steerers on English frames in this period often used A&P tubing even though the frame may be built with Reynolds.
The Nervex lugs are fairly commonplace on frames of this period and later: the gearlever boss is for a Cyclo.
John.
hobbs1951 is offline
Old 11-21-17, 07:58 PM
rhm
multimodal commuter
rhm's Avatar
Just the steerer, or also the fork blades? Seems to me I've seen the A&P stamps on fork blades more than once.
The fork blades on my Fothergill are definitely A&P and perhaps the reason that bike's so comfortable. As I ride I think I can see the blades flexing over bumps etc. And the fork is remarkably light.
rhm is offline
Old 01-17-21, 11:02 PM
crumbling
Bikes: MKM., F. A. Lipcombe, Schwinn King Sting, 1938 BSA
Quoted: 5 Post(s)
The discussion here has helped me with my hunt to the track frame I have and clarified what numbers I have. The frame I have is stamped Accles and Pollock quality A tubing and is a frame much like the A&P advertising of the 1922 tube set. The steerer tube on my frame is stamped separately with a tube set number on one side that also appears on the BB so the unusual serial number referred to on your frame is the A&P tube set number, not a builders number. This also appears to be stamped over the Nervex number that is a record of frame angles that the BB provides.
Thus I conclude the A&P tubeset number appears on both the steerer tube and BB. This also seems to apply with a small number of A&P frame sets discussed elsewhere. I doubt very much if the tubing used for my frame is Reynolds as pre 1928 A&P and Reynolds had no association at all being in complete manufacturing competition and then even up to 1980 there is only one reference to both being associated as part of Tube Investment Ltd in their used of each otherís tubing.
I have no idea of who assembled the A&P tubeset in Christchurch?, New Zealand. The Major Taylor handle bar stem and seat stem are both stamped Accles and Pollock Made In England. There is only one odd number on the BB that could be a makers date, 16, along with 36. Advertising I have seen for A&P does refer to 1914 as a manufacture date for their bars.
Pre WW1 it is recorded that the manufacture of product for domestic consumption stopped to allow for the WW1 supply to be made.
crumbling
crumbling is offline
bwilli88
Classic & Vintage
20
05-05-20 10:30 AM
Nessism
Framebuilders
13
10-20-18 04:35 PM
anhizer
Framebuilders
22
08-13-13 02:12 PM
ColonelJLloyd
Classic & Vintage
64
06-15-13 11:07 AM
ftwelder
Framebuilders
22
05-06-12 04:34 AM
