National Packing List
I have had plans for just that sort of thing rustling around in my head for a while. Just not clear enough to start cutting wood.
PI
So I saw how the tents are set up. Some will be on concrete, some will be on grass. The booths are fairly small in size compared to last year. As far as I can tell, there will be no common rollers to share.
Quoted: 1851 Post(s)
Liked 679 Times
And I'll add that until this week, I've never felt the need for the wagon. But figuring I'll need to haul Rollers, plywood (maybe), chair, and a large cooler, in addition to my normal race day gear, it seems useful.
Normally, I don't bring my Rollers as I have ample time to warm up on the track and the events are stacked so I'm basically rolling around the warmup circle in between events. Sometimes, I don't even have time to change gears.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
So I do need to bring Rollers and plywood or just Rollers?
Instead of starting a new thread, I'll add to this one:
Facts:
- You will not be guaranteed track time before your event like you would at your local track.
- If there is "open track", it may be from 6:00AM - 7:45AM...and your first event might be at 2PM.
- Your first event may be at 2PM on the schedule, but your name may not be called until 4PM.
How do you deal with this?
- Learn to do your entire warmup for the biggest event of the year in the infield with no track time. Even for the power events like the 500M, Kilo, and Match Sprints. You probably won't get to do your jumps on your race gear before your flying 200M.
- For last few race/training sessions at your local tracks, don't join the warmup pacelines or take any track time before your workouts/races. Do your entire warmup on your rollers/trainer. This will give you confidence that you can still perform at the same level while warming up only on rollers.
If you don't think it can work, just look at what happens in the infield at any televised world-level race. I've literally never seen an "open track" group warmup.
Also, the few brief moments that the commisars at Masters Nationals do open the track for open track, it's a mess. You'll do yourself a favor by staying out of it. Anyone who has been to Nationals before has stories about the craziness that has happened in open track.
Facts:
It's sorta unnerving to do the same routine all season then have that routine upset during the biggest event of the year.
As the saying goes, "Practice how you Play and Play how you Practice."
Which is I think why Taras wrote:
Some tracks have a culture of warming up in the infield on rollers (Alpenrose, TTown, etc...) and some don't (DLV).
Quoted: 22 Post(s)
It went well although I didn't achieve my goal of top 5, I was 6th. It was a great learning experience. It exposed my weaknesses and some strengths. The biggest takeaway was the effects of training at altitude. I live at 7700 ft and the Boulder Velodrome is 5000' and the OTC is 6000'. The thick humid air felt like riding in sand when I got to speed. It literally felt like I rode into a wall. I think I need to focus on lifting more and maybe doing erg workouts with supplemental O2 (suggested to me by the head Nordic Coach for the US para's). Also I was the only rider in our age group riding spoked wheels.
The tips were great. One of the coaches called me a Boy Scout for being so prepared. Two things I added along with all of your suggestions were compression tights for the long drives and in between heats and a Zero Gravity Chair, a fancy name for a reclining camp chair. It was nice to get my legs up between heats. I'll try to go back through this thread and make a packing list on a Google Spread sheet and share the link.
Thanks everyone for the help, it figured into the equation somewhere that helped me squeak into the tourney....I'm sure I was a nice warm up for the winner of the tourney in the 1/4 finals...
Elitist
Liked 92 Times
I did make it to Nats'!!
Be careful with the compression stuff in the summer in the southeast. When last I checked, compression gear hadn't really shown itself to be effective (some say it is, some say it isn't). But, what is definitely true is that it will keep you from cooling off. Heat can be a formidable enemy. It can increase recovery time between efforts, slowly sap your power, adversely affect your mental acuity, cause cramping, and even worse. So, the recovery gains don't outweigh cooling off in the +95F/35C degree infield.
This goes for all compression: socks, tights, shirts, skinsuits, etc...
The best setup I've ever made was a 2-piece skinsuit made with normal bib shorts and a Nike or Under Armor compression shirt. These can be found for $25-35 in basic colors in long or short sleeves.
1) It's easy to get in and out of, being 2 pieces.
2) You can warm up on a loose fitting T and then put on the compression before your events. Then after the events, take off the compression and put the loose T back on.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
If you folks haven't seen them, the Feedback Omnium rollers are stellar. They make two sleds, the low resistance one is great for track warmups. Really can get your spin on, and they fold up tiny and fit in a medium suitcase. Used them this week and love them.
For future hot outdoor events, bring a beach towel. Soak it with water for a poor man's cooling vest.
Lapped 3x
I've never thought of a beach towel. I always kept a towel that was large enough to drape the area of my chest, and soaked it with rubbing alcohol. The alcohol is cheap enough and a couple of bottles will last you the weekend. Draped over the neck and upper back, it allowed me to keep my legs moving on the rollers without overheating.
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
Also thumbs up for the wet towel! It wasn't just nice to have; it was a piece of survival equipment in the heat and humidity!
Elitist
Liked 92 Times
Yeah, those looked awesome. I didn't ride any, but my buddy has the 1st generation set. He loves them. Used them to warm up for his Team Sprint. They pack away as small as a camera tripod.
To be honest, I'd recommend them over rollers. Rollers:
- Require more packing space.
- Are heavier.
- Require concentration (some can't look away or have a conversation when on rollers).
- Require minimum speed.
- Fork stands for rollers exist, but are that much bigger and more to carry around.
I mean, if we focus on the objective (low resistance work to warm up, stay warm, or cool down), they tick all of those boxes.
Feedback Sports:
My only suggestions for the next version of them are to:
Make the rollers wider to accommodate more sway in the rear wheels. My buddy jumped off of his once. It was user error, but I think that the packing and usage footprint wouldn't suffer at all when doing so. I know they want to be as small as possible (and they've achieved that). I think that maybe 2" wider would help a lot and not hurt. Trackies like to do rev-outs at max cadence for muscle activation and sometimes sway a bit.
It seems like the current design would allow for an optional wide set of rollers to be swapped out.
Offer some sort of optional (add on) rectangular boards that would spread the weight of the front and rear ends horizontally for use in grass. The length x width would be the same as the packed-up unit and fit into the same bag.
Alpenrose for example:
Maybe get some prototype sets into the hands of track sprinters (not just roadies and enduros) who use rollers slightly differently and get feedback.
$429 MSRP isn't cheap. I think if they can get the price down closer to $250-300, they may be a "go-to" item for trackies and many will own a set. I don't know what the margins are on them, but if that's possible, I think that would help a lot.
- Are heavier.
Feedback Sports:
Quoted: 116 Post(s)
Sorry it took me so long. I should have taken pictures while I had it fully loaded at Nationals, but I had other things on my mind. I had it loaded with two bikes, including fort wheels, rollers, race wheels in a double bag, two helmets, two pairs of shoes, tools, pump, chair, gallon of water, and a small duffle with clothes, towels, etc. It has over a 500 lb capacity and carries everything nicely and easily rolls over the transition from grass to asphalt or sidewalk.
Thanks for the pics! That's a pretty sweet wagon!
Definitely gives me a clearer picture of what I want to build.
I'll be sure and post pics when (if) I get mine built.
PI
PI
Liked 679 Times
That was you? I totally saw you and your cart at Nats. I was very impressed by the cart.
Also, someone commented it was the first time they'd seen a Koga in the US.
Elitist
Liked 92 Times
[Roar of applause from all of the Track Wives and Track Girlfriends around the world]
As the wife of a teammate (who goes to Master Nationals almost annually) once commented, "He just invites me so I can help schlep his stuff in and out of the velodrome."
My scratch race is Tuesday, points race is Wednesday. I'm registered for the Madison on Sunday but my partner broke some ribs in a training crash. We'll see how that works out.
I did notice that there are 19 guys registered, so at least one will be looking for a partner.
Paul
Paul
Liked 679 Times
@Divebrian and @sarals, it was nice meeting both of you at Nationals this week.
Brian, I stopped you in the courtyard to ask about your cart and asked if you owned a Koga.
Sarals, we met while sitting at the start tower before our events. I think I was doing the Kilo and you your match sprints.
@queerpunk, sorry I didn't get a chance to say hello.
Idiot Emeritus
I wish I’d met divebrian, too.
