Are Presta valve caps uncool or what?
Calamari Marionette Ph.D
Riding a bike without lock nuts and caps on the valves is like walking around with untied shoelaces. Sure, it can be done. But it's a display of sloppy workmanship and lack of attention to detail.
Yes, I said that.
Yes, I said that.
Likes For SquidPuppet:
Quoted: 2323 Post(s)
Liked 4,988 Times
Liked 4,988 Times
?? Not to argue but I've never, ever had this happen. That's in over 30,000 miles this decade will carrying two spares.
Steel is real...and comfy.
And don't get me started on the ridiculous anti-aerodynamic claims made by cap haters. The threads on the valve catch a LOT of air, and therefore create massive wheel turbulence and imbalance. Covering as much of the threading as possible with a long smooth valve cap pays huge dividends towards improved handling. Also, valve caps are shaped like a bullet. A BULLET for crying out loud. Helloooooooooo?
Riding without caps is for bicyclist with limited or poor bike handling skills. They are not sensitive enough to notice the dramatic improvements in handling that caps provide.
Liked 4,988 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
Totally unnecessary.
You wanna talk weight and aero? OK, let's go there.
The big wrench flats on the outside of spoke nipples are square (non-aero) and add a ton of unnecessary weight. That's why before I build my wheels, I put dozens of nipples in a lathe and machine them down to a smooth cylinder shape. Then I weigh them and only use the ones that fall within a weight tolerance of .000000003 grams. Balance matters. A LOT! Then I use the screwdriver slot in the head of the nipples to true my wheels.
Also, I make my own carbon fiber valve caps and titanium lock nuts. The lock nuts are not knurled. Drag and turbulence reduction, again.
Riding at the level that I do, it's easy for me to understand why the average rider wouldn't notice these things.
Liked 4,988 Times
Again, riding at such a low performance threshold and under such mild conditions, it's completely understandable that you would not notice the benefits.
Quoted: 7652 Post(s)
Liked 3,473 Times
Asking what is "cool" is unimaginably uncool. You are toast, socially.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
If you like your valve caps, you can use your valve caps.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Erik the Inveigler
Quoted: 1310 Post(s)
I keep them on my heavy steel bike just to piss the "serious" cyclists off. It works.
However, when I'm out on my "serious" CF bikes, I won't stand for them.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Thread does not disappoint!
Right. I always wonder what other "shortcuts" the valve cap deniers are taking on the rest of their bike.
Some say that caps are just too much trouble when they get a flat. I had a friend like this. After showing him how to remove and reinstall the cap he agreed that it wasn't difficult at all! Now he's as cool as me.
So why do all new tube and bike manufactures supply them? Surely they could save $$$ and just delete 'em.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Someday, I'll get around to cleaning and vacuuming the mudroom where I keep in-rotation bicycles. I anticipate filling up a whole vacuum canister with Presta valve caps. I tell myself that they're not cool, but the real reason they get left off is because they seem to disappear.
If only we could get those springs on QR axles to stop being cool...
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Ya'll fumble with your jam nuts and caps when changing a tube at 17°F.
I'll save a seat for you at the coffee shop.
Quoted: 4560 Post(s)
Liked 2,802 Times
Quoted: 5888 Post(s)
Liked 3,471 Times
These are the kinds of threads that makes Bike Forums worth reading. I'll be disappointed if it doesn't go over 10 pages though.
Liked 2,802 Times
Liked 2,802 Times
