How often have you used the mult-tool set on the road?
Old 09-08-18, 11:47 PM
  #51
noglider
noglider's Avatar
Quoted: 7334 Post(s)
Liked 2,431 Times in 1,420 Posts
Just this week, I used mine to reduce the cleat tension on my left pedal. My right pedal is already at minimum tension because it's the pedal I clip into second and out of first.
noglider is offline
Old 09-09-18, 12:26 PM
  #52
alan s
alan s's Avatar
Quoted: 1496 Post(s)
Liked 189 Times in 128 Posts
I don’t use a multitool very often, but it’s indispensable when needed. Kind of like rain gear. It’s with me when needed. Friday is a good example. Torrential rains for the commute home. Most other riders had no rain gear whatsoever, and even though it was in the 70s, they were probably pretty cold and very wet. It was able to ride comfortably with rain pants and jacket, and fenders.
alan s is offline
Old 09-10-18, 09:06 AM
  #53
Archwhorides
Archwhorides's Avatar
Bikes: Death machines all
Quoted: 297 Post(s)
Liked 86 Times in 63 Posts
+1. Funny, rain is predicted during rush hour this evening. I've got my gear (and a multi-tool)
Work is the curse of the drinking classes - Oscar Wilde
Archwhorides is offline
Old 09-10-18, 11:52 AM
  #54
alanf
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 73 Post(s)
Liked 29 Times in 13 Posts
Once I did a century, with zero planning, on a lark, with my daughter. I thought 'well I'll just bring a tire patch kit'. It was totally useless. The only thing that would be useful was a tube. Now I just buy HD tires period. They are heavy etc. but no more flats.
I don't carry a pump anymore or a tool kit. I've never had a use for it.
(Now you just watch, on my next ride, all hell will break loose )
alanf is offline
  #55
nogasbiker
Rarely use mine, a Park Rescue Multitool. It has a chain tool, which is because of a bad run of chain issues I have several years ago. Interestingly, the chain issues stopped when I got the multitool.
I guess it's time to reassess and trim down on what I carry.
nogasbiker is offline
Old 09-10-18, 11:54 AM
  #56
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 444 Post(s)
Liked 844 Times in 408 Posts
Prevents shark bites. Keep it in the bag.
blacknbluebikes is offline
Old 09-10-18, 11:55 AM
  #57
alanf
Quoted: 73 Post(s)
Originally Posted by cyccommute
I don't want to turn this into a helmet thread either. However a helmet, like a multitool, is something that I carry and use on a frighteningly regular basis. I've popped far too many helmets against the ground to doubt their efficacy.
I always wear a helmet. My bike is capable of frightening speeds and my head is the first to reach the scene of the accident.
alanf is offline
Old 09-10-18, 01:40 PM
  #58
Bikewolf
Quoted: 139 Post(s)
Liked 34 Times in 24 Posts
For my commute, I don’t carry a multi tool (yet). However I do carry compact scissors, to cut the inner tube when necessary.
Bikewolf is offline
Old 09-10-18, 01:56 PM
  #59
alan s
alan s's Avatar
When is it necessary to cut the inner tube?
alan s is offline
Old 09-10-18, 02:05 PM
  #60
noisebeam
Arizona Dessert
noisebeam's Avatar
Quoted: 5345 Post(s)
Liked 2,169 Times in 1,288 Posts
It is the only way to get it off a still mounted wheel
noisebeam is offline
Old 09-10-18, 02:24 PM
  #61
alan s
alan s's Avatar
True, but aren’t you going to put a new tube on, in which case the wheel has to come off?
alan s is offline
Old 09-10-18, 04:04 PM
  #62
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,102 Times in 1,366 Posts
I recall seeing an inner tube that didn’t make a circle, like a balloon animal. Maybe he’s gluing both ends shut
Darth Lefty is offline
Old 09-10-18, 04:26 PM
  #63
noglider
noglider's Avatar
The fact that you haven't used or have rarely used your tool is not proof that you don't need to carry it. If you end up using it every week, something is wrong.
noglider is offline
Old 09-10-18, 06:22 PM
  #64
SylvainG
Bikes: Schwinn Miranda 1990, Giant TCX 2 2012
Quoted: 486 Post(s)
Liked 10 Times in 7 Posts
"It has a chain tool, which is because of a bad run of chain issues I have several years ago. Interestingly, the chain issues stopped when I got the multitool"
So this is in accordance with Murphy's law.
"I guess it's time to reassess and trim down on what I carry"
Are you sure you want to tempt the Murphy?
SylvainG is offline
Old 09-10-18, 07:45 PM
  #65
cyclintom
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
Liked 2 Times in 1 Post
Originally Posted by vol
If you carry a multi-too set (typically including various sized allen wrenches, screw drivers), have you actually used them during the ride? I carry one, and a mini pump, tube repair kit, in a frame bag, but have never, ever touched them during a ride. Together they add weight, and I always have to take them off the bike when parking outside.
I use it very rarely but when you need it you need it. The other day I hit a section of broken pavement that caused the bars to roll down. It could have been dangerous without a tool to repair that.
cyclintom is offline
Old 09-10-18, 08:13 PM
  #66
daoswald
Quoted: 212 Post(s)
Liked 83 Times in 54 Posts
My multi-tool has 9-tools. Of those nine, there is one Phillips driver, and seven hex drivers. And one of the hex driver has a cap over it that provides one size larger, so that makes nine.
What have I used it for?
  • Tweaking the limit screws on the FD a few times over the years. Not often, but once in awhile I'll drop a chain, and apply a 1/8th turn to assure it doesn't happen again.
  • Adjusting seat height and set-back, but this was on a ride dedicated to tweaking my fit just slighty -- I may as well have brought a couple of my shop hex wrenches along.
  • Taking up some headset vibration that was annoying me. But that could have waited until I was home.
As I think about it, there are really only a couple of times when I was first dialing in the FD where I really needed the tool. For some irrational reason I continue carrying it with me, assuming someday it will come in handy. But what could ever happen that would require a roadside use?
  • Additional FD / RD limit adjustment? Really doubtful -- the bike is now ten years old and well dialed-in for the limit screws and B-screw.
  • Seat height and set-back? Nah, I touch that one or two times a year to tweak within a half-centimeter range when I find myself experiencing early warning signs of front knee or inner-knee pain. There is no situation where I would have to do that on a real ride.
  • Head set adjustment? Surely I can make it home to tighten that up.
  • Stem tightening, rack tightening, pedal tightening, brake caliper tightening... that would never be an issue, since I check those things at least once a week.
What else is there? I really ought to just leave it at home.
You've talked me into it -- I'm leaving it home and adding one more CO2 cartridge since it's so annoying dealing with the hand pump.
daoswald is offline
Old 09-10-18, 08:38 PM
  #67
alanf
Quoted: 73 Post(s)
It just occurred to me that I usually carry a single tool. A pocketknife.
alanf is offline
Old 09-10-18, 08:49 PM
  #68
Gdfbike
My new folding bicycle only needs one tool. Every bolt is the same size 2.5mm Allen, Thinks like the cranks are held on with three non-load bearing fasteners, and outside of a chain tool, no other tools such as crank arm pullers Etc are needed. When I'm running the Tannus tyres also don't need to fix flats otherwise when I use pneumatic tyres I carry patch stuff.
Gdfbike is offline
Old 09-10-18, 09:18 PM
  #69
alanf
Quoted: 73 Post(s)
How do you find the Tannus tyres? The ads sound unbelievable... A Godsend.
alanf is offline
Old 09-11-18, 07:24 AM
  #70
Bikewolf
Quoted: 139 Post(s)
For a still mounted wheel, yeah. Think e-bike. Sometimes convenience. I try to patch the inner tube, but there are times you need (or want) to replace them quickly.
And yes, there do exist inner tubes dubbed 'snakes' like the ones from Gaadi:
https://www.edinburghbicycle.com/gaa...it-design.html
Bikewolf is offline
Old 09-11-18, 10:51 AM
  #71
alan s
alan s's Avatar
How do you like the Gaadi tubes? Never heard of anyone who actually uses them.
alan s is offline
Old 09-11-18, 02:08 PM
  #72
Bikewolf
Quoted: 139 Post(s)
Gaadi? Particulary useful for people with an e-bike having a rear wheel that is somewhat more difficult to remove. As an emergency solution.
As always: a solution for a particular group of bikers, not for EVERYONE ;-)
Bikewolf is offline
Old 09-11-18, 07:50 PM
  #73
noisebeam
Arizona Dessert
noisebeam's Avatar
When I rode a fixed gear if I could I would keep the rear wheel on to fix a flat. I'dfFind where the puncture was from looking at the tire and then just pull out a bit of tube and patch. Probably did this about 10 times over 40k miles
Old 09-11-18, 08:25 PM
  #74
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,192 Times in 2,352 Posts
I haven’t used the Gaadi but Specialize made a similar tube called the Dirt Worm. It worked really well and is kind of brilliant considering that removing the tire is the difficult but they just never caught on. I haven’t used them in years because the Dirt Worms aren’t made anymore. I only found out about the Gaadi a while back and haven’t gotten around to getting any.
Stuart Black
cyccommute is offline
Old 09-12-18, 08:11 AM
  #75
noglider
noglider's Avatar
About a hundred years ago, there was a bike tire with several inner tubes, maybe around eight. It didn't catch on. Maybe someone should resurrect that idea.
noglider is offline
