Sram S300 Courier crankset $135 worth it?
I want to know if anyone would or would not recommend these cranks for the price. Are there other crank sets you would recommend in the $150 price range? Anyone ever ride Miche cranks? What about Sugino RD Messenger cranks?
Bikes: Cinelli Mash Histogram, Raleigh Tokul 3, All-City Macho Man
Quoted: 29 Post(s)
I've put thousands of miles into S300 cranks. I personally could not tell the difference in stiffness between S300s and Omniums. If you want a 130BCD GXP setup, S300s are great. However, you can get the Miche Primato Advanced cranks for the same money which are lighter and 144BCD. You will have to use a square taper JIS bottom bracket, but I prefer square taper systems for fixed gear riding anyway. I'd decide what style bottom bracket you want to use, then get either the S300's or the Miches. Sugino RD cranks are inferior to both the S300s and Miches in every way.
Quoted: 1332 Post(s)
Liked 398 Times
They're all fine cranks. I had both S300s and Miches for a while. I'm not sure if this is true of the new version of the Miche cranks, but the older ones I used had a bit narrower than usual Q-factor if that matters to you. The cool thing about SRAM cranks (either S300s or Omniums) is that they have everything you need in one box and they're extremely simple to install. Some people gripe about the stock GXP bottom brackets that come with them, but I've never had a single problem with mine.
Super-duper Genius
Quoted: 768 Post(s)
Liked 983 Times
I have an S300 on one of my bikes. It's a good crank, worked well for me from day one. I don't have thousands of miles on it, but I have at least a few hundred. Whether it's worth $135 is a question you'll have to answer for yourself. I'd certainly pay that much for another one before I'd pay $220 for an Omnium.
Of course, both models (and others) are hollow-spindle, external bearing designs. If you like that setup, the S300 is nice. The actual spec for this crank/bottom bracket is SRAM's Giga-X Pipe, aka GXP. As Seau said above, there have been reports of problems with the BB that comes with it. I've not had any trouble with mine--yet.
If you prefer square taper spindles, the S300 is obviously a hard pass. Another consideration is the chain ring. S300 uses 130mm BCD, and comes with a narrow (3/32") ring. Is this the kind of setup you want? If so, I think you'll be happy with it.
Quoted: 29 Post(s)
I do really like the simplicity of the GXP bottom bracket (i've had omniums before) although I don't want to have 130BCD cranks. I didn't look at the specs of the S300's before posting. I've realized now that if I go for the primato miche crankset + buying the bottom bracket + new chain ring will come out to $250+ so should I just go for omniums since it does come with the GXP BB and buy an FSA chain ring for $58? priced in retrogression
Liked 398 Times
Might be a good time to ask yourself how much a couple extra teeth in your drivetrain are really worth.
