Need help choosing the right color tape
I ride to clear my mind
Can anyone look at the striping on the bike and determine what color it is exactly? I need advice lol
(The red was from my older bikes color scheme and the dropbars were transferred over).
Quoted: 6196 Post(s)
Liked 4,810 Times
Won't Ribble tell you?
Quoted: 18420 Post(s)
Liked 15,564 Times
Orange.
PMS 427. It's a gray that's on the cool side. The cool side being blue. According to my screen settings. YMMV
Since that is clearly some shade of blue you wouldn't want if you were trying to get actual blue bar tape I bet if you order "blue" bar tape from 5 different sellers from China on eBay one of them will be that color...lol.
In all seriousness, I've had trouble with getting the right color match when buying accent items online so I know how difficult it would be to identify that color. I think the only way you are going to get a good answer is if someone is already familiar with a particular line of tape that comes in that color. You might try going on amazon and just scouring through the bar tape options to see if any appear to be the same color. If you buy ones with free returns you can at least have the option to send them back if they don't match. If you filter by "prime" or "bought and sold by amazon" option then most of those should have free returns and if you have Amazon Prime you don't even have to worry about minimum order amounts.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
You could go all-out-crazy & do carnation pink or lime green. Then get yellow tires to match.
It would look like the 1980's all over again!
So about thst seat post...Are you 8 feet tall?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Seriously, though, Deda and LizardSkinz both have a 'sky blue' that would probably be close enough.
I just googled that. You hit the nail on the head
Teal?
Given: Your hands will transfer black from chain to your bar tape after your first puncture repair ,
so the pragmatic choice is black tape .
Btw, way cool that someone was able to identify the color for the OP!
Or keep disposable gloves in your patch kit...
I got under bar tape Gel pads from Fizik b you buy the package deal the tape is black ... red paint it looks fine..
, want another color? buy the pads separately And the tape in another color
I have that in the back of my mind. I am trying to get a color scheme here in case my bike gets lost in a crowd I can spot it. But yeah black is in the thought
Liked 4,810 Times
I wouldn't worry too much about dirt from tire changes and maintenance getting on the bar tape. The newer tapes of the last ten or so years are much better at not holding on to filth. At least that's IMHO. I put some white tape on my bars several years ago expecting they'd be filthy nasty looking before half the year was out, however two years later it's surprisingly clean. I used Fizik's performance 3mm tape.
But you'll just have to look around. I'd try looking online at all the bar tape manufacturers and seeing what looks the best match on their website. As well look at local bike shops when ever you are near one.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I'd worry about that saddlepost first.
-Tim-
-Tim-
Yep, mentioned in my reply that I do that. Coincidentally I also do the second thing you said and buy under tape gel pads separately. They are awesome btw and I’ll never go back to just a single layer of bar tape. I actually wrap my bars with my old tape first then wrap with the new tape and the gel pads underneath. I use the Planet Bike gel pads from Amazon.
Quoted: 696 Post(s)
Liked 910 Times
Black tape to match the saddle. Accentuate the blue stripe with wardrobe/helmet.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
First instinct is to pick orange. But on second thought, the blue that's already on the bike is "more or less" the accent. So two accents don't make a right.
If the frameset were already mostly blue, then the orange would work well. The white appears at the bottom of the forks, hardly significant.
I would continue with the blue accent as an extension and restatement of the frameset. However, the blue bar tape needs to be a very close match to the blue on the frameset.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
White, so you earn cred when your mates see the grime that indicates how much you ride. OTOH, if too clean it works the opposite way.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Bright Aqua
is generally the trim color, so you have options.
From the color wheel, warmer gold and lighter browns would look nice.
A bright yellow complements an aqua trim.
Also, a light grey would be good.
Finally, if you're in Miami, then...
