Derailleur
Quoted: 4228 Post(s)
Liked 3,926 Times
Maybe, depends on what's wrong and what else is at play. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1439 Post(s)
Liked 1,094 Times
"Poking around" without a plan might not work so well. Trying a systematic approach, such as the Park tutorials, will likely yield better results.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
The link posted earlier to the Park Tools repair help is a good link to follow.
Mechanic/Tourist
Actually, I've found that fiddling is preferable to poking around, and, tweaking is even better. However, I just came on this odd recommendation recently that one use a bizarre new approach. It's called diagnosis. What you do is first describe the symptoms, then identify what parts might cause those symptoms, and finally by experimenting, eliminating possibilities. or applying logic, determine a fix. Sometimes one can start at the first step and then ask someone else for help by giving them full information. But it seems to me like a lot of work, and I've also stumbled on this trial and error thing that sounds intriguing.
Liked 3,926 Times
AndrewRStewart
AndrewRStewart
Quoted: 1624 Post(s)
Liked 2,654 Times
Define 'worth'.
Quoted: 1572 Post(s)
Liked 644 Times
Not for me.
your rear derailleur just might be the most reliable component on your whole bike. I've never had trouble finding a donor bike rear derailleurs when I wanted one.
I have replaced jockey wheels, replaced bushings inside jockey wheels, straigtened bent cages, and returned stuck derailleurs to fuinctioning by removing the mounting bolt and cleaning all manner of gunk out of tne derailleur body. I have had a couple that weren’t salvageable after a wreck or the time a catastrophic derailleur hangar fail sent one flying through my rear wheel (did a number on tne wheel too). But absent such kinetic issues, they are pretty resillent.
