Source for 4mm Barrel Adjuster
Bikes: Indeed!
Quoted: 1511 Post(s)
Liked 3,487 Times
I purchased this very nice Peter Mooney frame from the local non-profit bike shop. The missing barrel adjusters are not the 5mm ones I'm used to. They appear to be M4 x .7.
When I finished the paint touch up I though I was in the clear but I'm striking out finding replacement adjusters. I've tried both Shimano and Campagnolo adjusters from their adapters that convert downtube shifter bosses to adjustable cable stops with no luck. The Shimano is 5mm and the Campagnolo is 5mm with 4mm flats.
Any help is appreciated.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Quoted: 1163 Post(s)
Liked 442 Times
Is it possible that slide in barrel ajusters like Jagwire Mickey adjusters would work. I am at work now but I have some of these at home and could see what the diameter of the shaft is. Is suspect they might slide right in. Also are the 4 mm holes threaded?
Bikes: Indeed!
Liked 3,487 Times
Brent
Liked 442 Times
obrentharris - no problem . Now my curiosity has been triggered. Makes me wonder if Peter Mooney is still making bike frames? I'm also curious if the threaded holes are wide open all the way through or if they are stopped at the bottom?
blahblahblah chrome moly
Quoted: 1195 Post(s)
Liked 2,600 Times
4 mm seems a bad choice for a barrel adjuster, not strong enough. I'd drill and tap to M5.
5 minute job.
Mark B
5 minute job.
Mark B
Likes For bulgie:
Bikes: Indeed!
Liked 3,487 Times
In answer to the previous question from @masi61 the holes are wide open all the way through. I can run an M4 screw in from either end.
I have heard that Peter Mooney is no longer building, but that is third hand information at best. This is not one of his fanciest frames but the work appears top notch to me. I'm very eager to finish building it so I can take it on a nice long ride.
Brent
Liked 442 Times
I did an eBay search for 4mm barrel adjusters and came up mostly empty. I did find these: https://www.ebay.com/itm/39423691497...mis&media=COPY.
They might just work. The knurling is nice in a retro kind of way.
Bikes: 1970 Alex Singer, 63 Hetchins, 75 Motobecane Townie, more . . .
Quoted: 10 Post(s)
Liked 8 Times
Those are M5
[QUOTE=obrentharris;22829309]I purchased this very nice Peter Mooney frame from the local non-profit bike shop. The missing barrel adjusters are not the 5mm ones I'm used to. They appear to be M4 x .7.
Thats a Walter brand CS60 head tube lug. The adjusters are M5, not M4. It looks smaller because of the paint in there. Gently and carefully run a tap in there and you'll be set.
Bikes: Indeed!
Liked 3,487 Times
Perhaps they changed the lug design early on when they decided 4mm wasn't such a good idea.
Brent
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
If you don't need the adjustment, you could probably use a step down ferrel in there.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
framebuilder
Brent, I just checked the Campagnolo down tube shift lever adaptors I put on my travel bike in 1995. Its barrel adjuster is 4mm and not 5mm. It has a spring around it to make it look bigger in diameter. The spring is to secure the adjustor to keep it from turning. Look for an older set of Campy adaptors and you will be all set. Those lugs were made with Campy instead of Shimano in mind. It makes no sense that Peter made a frame with adjusters that would be difficult at the time to find.
Bikes: Indeed!
Liked 3,487 Times
Brent
Likes For obrentharris:
