7/8 22.2 Seatpost
7/8 22.2 Seatpost
Hello everyone. My hybrid has a seatpost that doesn't let the saddle adjust fluidly. It's only in set increments. I can't get the saddle angle precisely where I want, so I want to swap out the seatpost. The problem I am encountering is size. It's a 22.2 and it seems exceptionally hard to find this size. The brands I am familiar with (Specialized, Fizik, etc) seem to only make 27.2 and larger seatposts. Anyone with more knowledge of this have any ideas about where to find a good replacement? Recommendations? Thanks.
Quoted: 1581 Post(s)
Liked 1,189 Times
Good luck with that. I believe that (22.2, usually steel?) is an old-school ('90s?) BMX standard. You might have some difficulty sourcing a replacement.
Quoted: 576 Post(s)
Liked 1,001 Times
Yeah. I'm new to cycling and I would never have thought to look at this as part of the purchase decision. After looking checking out other bikes, I can't understand why a company would produce a bike with this size seatpost. I've been happy with the bike otherwise. Frustrating.
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
What brand bike is it?
I have a '70 Peugeot that also has a very small seat post size. I think it may be 22.0mm, but I don't recall exactly. The steel seat tube necks down at the top and there's also a thin shim that goes in that further reduces the size. I'm not sure why they did this, and I'm curious to know the make and era of bike you're working with.
Likes For calebpagan:
Liked 761 Times
The website may be deceiving, but it looks like a more typical 27.2mm seatpost. The seat tube looks like a pretty typical 28.6mm steel seat tube -- there must be a pretty thick shim at the top to get the seat post down to 22.2mm.
https://www.brooklynbicycleco.com/products/roebling
Unfortunately, the website specs say only that the seat post is an alloy seat post with an integrated clamp and micro adjust. I don't think these are available in the small 22.2mm size. Would it be possible to post a picture of what you have?
Liked 761 Times
That's great to hear -- 25.4mm is still also thinner than I'd expect it to be...but as you note, it is indeed a more common size.
I guess the no kidding, absolute final say on the topic would be the existing seat post you have in the bike. It sounds like you have it...it's just not easy to adjust the seat angle. Most all seat posts have the size marked on them near the bottom, near where the minimum insertion line is. So you should be able to pull the seat post out of the frame and look for the size marked there. That would really confirm the number the manufacturer gave you.
Liked 761 Times
Remember to apply some carbon paste to that seat post before installing it (if it looks like it's the correct size).
Quoted: 576 Post(s)
Liked 1,001 Times
That's where I looked, but I didn't see a number. It had the minimum line but nothing else I saw. I ordered a 25.4 fsa carbon post from Cannondale Experts. A carbon post is a bit of overkill for my needs, but I didn't find many 25.4. I'll update when it arrives on whether or not it fit.
25.4mm is not an uncommon size, its the last adult size "standard," a size I drop down to with shims on odd sized. C-experts deals with a lot of proprietary C parts, a few high end C frames use 25.4 for its extra compliance, which is why they stock these. Thomson make good 25.4mm posts with great tilt control, I have a few of them (in other diameters.)
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
Just putting my two cents in:
https://www.worldwidecyclery.com/pro...hoCr1YQAvD_BwE
This is a really nice seatpost. I bought one used (but new since it wasn't used for only $30) a week ago and it's really nice being able to adjust seat angle.
Cool thing is, it's made in the U.S. and it weighs very closely to what a more expensive carbon fiber seat-post weighs.
Liked 761 Times
The two bolt systems are very nice for getting seat angle just right. My Giant Roam had this style of seat post from the factory, and I appreciated how easy it was to dial it in just so. I'll not buy a seat post with a single bolt adjustment in the future if I can help it.
Likes For hokiefyd:
Quoted: 422 Post(s)
Liked 182 Times
Anyhow, was happy to find this seatpost for sale in Winchester va. The guy whom owned it, said he never used it since he bought a different bike.
Was not a good crash, slightly damaged rear wheel, needing to be trued now. Had to readjust rear derailleur, really bloodied up my leg and arm and even had to pop my arm back into it's socket....yea, it wasn't good..
