1980's Frame Misalignment
Quoted: 703 Post(s)
Liked 679 Times
Most of the bikes I've owned and worked on were 1970's era Raleigh's and all have had misaligned frames. This is the second bike I've worked on from the 1980's and both have misaligned frames. First was a ROSS Signature, this one is a SCHWINN Traveler.
How common is this?
The first photo is of the non-drive side, second is drive side, the gap is 7mm. The dropouts are parallel and are perfectly spaced for a 126mm hub.
How common is this?
Likes For branko_76:
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 348 Post(s)
Liked 268 Times
branko 76-
Misalignment of older steel bikes is pretty common in my experience. Wear and tear, getting crashed or dropped, all sorts of things happen over 40 years. I routinely have my bike purchases checked by a nearby frame builder and then aligned. It makes a great difference in the ride and tracking even when I previously considered the bike to be fine.
Quoted: 703 Post(s)
Liked 679 Times
branko 76-
Bikes: old ones
Quoted: 26477 Post(s)
Liked 10,441 Times
...of the stuff I have redone for my own use, probably 70% of them need some sort of either minor or major realignment. As stated above, it's pretty common.
I routinely check the dropout spacing and alignment, frame alignment, fork alignment, and derailleur hanger alignment as part of the process on every bike I work on.
If a bike gets used, **** happens. And some of them were not well aligned when sold new, anyway.
Quoted: 571 Post(s)
Liked 604 Times
It is worth the trouble. My worst was 7 years ago an utterly unridable 80's custom from a local builder. Hung upside down by strings looped through the rims the fork would cant off 30º. A lugged Reynolds 753 which you can find Reynolds engineers documents saying 753 can not be cold set. I tried to cold set the fork first and as soon as i mount and moved it would snap back to the original position. Fortunately an old time framebuilder in town with Marchetti frame table and Lange fork table got it perfect. I enjoy it to this day.
Likes For easyupbug:
Quoted: 999 Post(s)
Liked 1,672 Times
branko 76-
As to the OP: Yes, pretty common. A further question would be what methods can we use as a DIY alignment check.
Our guys at Sheldon have a few things posted
https://sheldonbrown.com/frame-spacing.html
Likes For zandoval:
Quoted: 1381 Post(s)
Liked 1,771 Times
Yup, tweaked frame alignment is not at all uncommon. I always check frame and fork alignment and correct as required. And, in many cases, correction is required. I use the string method to check stays alignment but I no longer have a fork gauge. Stupid me sold mine a long time ago:-(
blahblahblah chrome moly
Quoted: 1206 Post(s)
Liked 2,648 Times
The string should come off the dropout at a point that matters, namely where the wheel will sit, the inner face of the "land" for the axle. This shows the string coming off a part of the dropout that's not involved with holding the axle, and it's different between the right and left (that knot can throw off the string's centerline).
Even if you do it right, you might want to measure and compensate for the curve in the seat tube from brazing on the front derailer attachment. All tubes have some runout of course, nothing is perfectly straight, but the F. der. BO puts a pretty decent curve in the tube, more than any runout I have measured in an unbrazed tube.
So the string method is not the ultimate alignment, but it's decent as a shade-tree mechanic technique for those without more rigorous methods, or even for a pro framebuilder in too much of a hurry for a complete alignment, say for a frame that isn't valuable enough to warrant the complete tear-down and rebuild. Just run that string in the right place, and try to see how bent your seattube is!
Note this string method (done right) is equivalent to the Park ***-1 tool shown in the OP; they measure the same thing. So the ***-1 (or -2) is also, in my opinion, not a "be-all and end-all" pro alignment tool, but it is very fast and easy to use. I have one and use it, but I keep its limitations in mind.
EDIT: the asterisks were put there by the censor. They replace the name of the Park Frame Alignment Gauge.
I, for one, welcome our new robot overlords!
Mark B
Last edited by bulgie; 08-13-22 at 04:19 PM. Reason: Censor bleeped the name of the Park tool!
Liked 2,648 Times
<snip> you can find Reynolds engineers documents saying 753 can not be cold set. I tried to cold set the fork first and as soon as i mount and moved it would snap back to the original position. Fortunately an old time framebuilder in town with Marchetti frame table and Lange fork table got it perfect. I enjoy it to this day.
That's not a problem with the forks though, which are no thinner than 531. They're just 531 blades that got heat-treated to make them stronger, a very dubious advantage since 531 forks are strong enough. (I'm mad at Reynolds for "chickening out" and not making the blades lighter, a missed opportunity.)
The 753 steerer is also the same gauge as 531 for most of its length, but where the 531 steerer gets a butt at the bottom, the 753 doesn't, so the lower part of the steerer is lighter than 531. This a 753 fork is just a little bit lighter than a 531 fork, but it's really very little, like an ounce? Sorrry, I once knew the weight difference but I forget now, someone here will know.
Even if the blades were infinitely strong, you can still bend the crown, so yeah those forks definitely can be cold-set. You just need a longer lever, and a stout vise! Or a 100+ lb alignment fixture like the one I made recently from vintage cast iron industrial parts,
That's a work-in-progress shot. It's now finished and bolted down to a very heavy steel table that's bolted into the concrete floor. Main difference from this pic is the handwheel is spaced upward an inch so you don't pinch your fingers against the crown. Unfortunately it only does 1" forks (I'm a committed C&V retrogrouch).
Mark B
Likes For bulgie:
Quoted: 3464 Post(s)
Liked 2,834 Times
Braze on front derailleur mounts are definitely a way to bow a seat tube.
Old fart
Quoted: 3617 Post(s)
Liked 3,446 Times
Yeah it's "common knowledge" that 753 can't be cold-set, but what they really should have said is it's difficult to cold set. If it springs back without taking a set, it just means you didn't push hard enough. Any steel, no matter how strong, can be bent, unless it's too brittle and snaps. But the problem with 753 isn't brittleness, it's just very thinwall (in the frame tubes, not the fork), making it likely to buckle or kink, a.k.a. beercan failure mode.
And that's why I don't recommend cold-setting 753 frames.
Likes For JohnDThompson:
framebuilder
I'll start by answering the OP's question about how often are classic era bike frames out of alignment. As a builder/painter since the mid 70's, I've done hundreds (thousands probably) of alignments. The answer is most frames are somewhat out of alignment and some seriously out. I've visited many framebuilding places (especially in the UK) in the 70's and most were pretty casual about it with rudimentary tools. Furthermore, the $100/150 retail cost of a painted frame in Europe required those builders to make them quickly. The exception I've found were 80's Japanese frames that always seemed to be spot on. American builders raised the price and standard although not everyone does it perfectly. Where I learned to build at Ellis Briggs in Yorkshire, they had a very nice cast iron fixture/alignment table combination. I took back with me from Manchester much of Johnny Berry's Equipment including his 3' X 4' cast iron table. I've gotten others since but that one is still my main table for alignment. I was very fortunate to get it (and the knowledge of how to use it).
The problem with DIY alignment is figuring out what is the problem. I'm not a fan of Sheldon's string method. So you measure the distance of the string to the seat tube on both sids and there is a discrepancy. What's off? One might think that the rear dropouts are left or right of the center of the frame but how do you know? Maybe the down tube is leaning over to one side or maybe it's the seat tube leaning but not the head tube. Or the other way around. Or both. Or the front triangle is really 90 degrees from the threads of the bottom bracket shell and the dropouts are really off center. So the string method is only telling you something isn't right but it can't tell you where to fix what is wrong. There is a way to DIY if one wants to make a straight edge with an adjustable screw but that is beyond the scope of my post.
Just for your amusement, I'll show a couple of pictures of frames and accessories on my Johnny Berry alignment table. The 1st picture shows a carved lug frame I was making for my nephew. The other picture shows 3 kinds of straight edges with adjustable screws.
some of the accessories to check frame alignment on a cast iron table
a gaggle of straight edges that can be used in checking alignment
Liked 2,648 Times
When I was with Trek, we decided to test cold-setting a 753 frame on a crashed team frame that was headed for the scrap barrel anyway. Put it on the alignment table and had at it with the Big Levers of Alignment, and just as you say, it kept springing back, and we kept increasing the force. Finally, it gave, by crumpling at the shift lever bosses.
Mark B
For me just getting proper derailleur alignment has been a great thing. And I don't even have proper tools to do it. I just use two large "C" clamps.
Bought a vintage frame set, being shipped to me now, and I wanted to do an alignment check on it.
Likes For reroll:
Alarming that ShelBroCo would show a picture of doing it wrong. (I am admittedly too picky by half, but why not do it right? It's not any harder.)
Mark B
Mark B
Quoted: 571 Post(s)
Liked 604 Times
The above 753 Andy saved hung afterward by strings run through the rims hung straight as an arrow and it fails Sheldon's string test badly but I can ride it around the block w/o touching the handlebars, it is a delight. Andy also painted it for me, he is a gilt to C&V in Southern Arizona and I recall him saying basically what you did above.
Old fart
Liked 3,446 Times
Right, I think you're agreeing with what I wrote. But do you agree that 753 forks should be alignable? (Is that a word?) Can't say as I recall ever having tried it, but I have aligned Prestige forks (maybe a thousand times, but weaker than 753) and a fair number of 853, which ISTR is even stronger than 753.
Quoted: 1869 Post(s)
Liked 666 Times
The 753 steerer is also the same gauge as 531 for most of its lenght, but where the 531 steerer gets a butt at the bottom, the 753 doesn't, so the lower part of the steerer is lighter than 531. This a 753 fork is just a little bit lighter than a 531 fork, but it's really very little, like an ounce? Sorrry, I once knew the weight difference but I forget now, someone here will know.
Mark B
Mark B
branko 76-
Liked 2,648 Times
How expensive does this run usually? I have a 1983 Ross Aristocrat that I just started riding heavily and when I look it appears that the wheel doesnt sit straight in the frame. It was my dads bike and I plan on putting some decent miles on it so I might have a shop do a thorough tune up, not sure if alignment is feasible or not
If it's just a bike for riding though and doesn't need to be perfect, a good LBS can probably do an OK job. Making things worse isn't all that likely really, I just mention it because some people have zero tolerance for risk. Lightweight frames don't like to be bent back and forth, so some of the damage a bad alignment can do can't be properly undone. So ya pays yer money and ya takes yer chances.
I don't know what a Ross Aristocrat is, is it high-end? They had a couple of world-class framebuilders (Jim Redcay,Tom Kellogg) pass through there, but I think the high-zoot ones were called "Signature".
Quoted: 348 Post(s)
Liked 268 Times
ihm96-
The advice bulgie gave above is solid. Definitely have a framebuilder do the job rather than a bike shop. Most current shops are not familiar with cold setting a steel frame and could do damage. A frame and fork alignment check will likely run $100 but this is variable depending on the area and the framebuilder. Your Ross' Ishiwata 024 frame and fork mark this as a mid level bike but alignment will benefit it regardless. I have even done alignments on light gauge hi-tensile frames and they have benefited from the treatment.
Likes For bertinjim:
Bike shop mechanics usually aren't tooled up or trained to do this properly. The problem is when they don't know what they don't know, so they think they are qualified, then damage can be done. If it's a precious family heirloom, then have a good framebuilder do it.
I dont really plan on doing any racing but im starting to do a lot of regular 20-50 mile rides around Philly and my modern hybrid bike is not as good as putting on the miles as this. I was kind of regretting purchasing a Hybrid since I already am outgrowing it with the distances Im doing and was worried I might have to stick it out and get a better road/gravel bike next summer but then I remembered I had this bike. I rode it yesterday and it rides really nice and eats up the miles. Im not doing any racing so I figured I might as well get this tuned up and start riding it regularly rather than getting the itch to buy something new
It does have a little click noise that I feel as I go through the pedal stroke and I accidentally smacked it off a pole while slowly coming onto a sidewalk but I dont think it did any other damage than destroying the vintage cat eye reflector where I hit the pole . It feels like it rides fairly straight but if I look at the wheels they both look a little misaligned in the frame. Im fairly novice to actual cycling , I mostly just rode bikes around the neighborhood as a kid so any advice is majorly appreciated. Biking as an adult feels like a whole new world, especially with the great trails Philly has. I never realized before how easy it is for me to zip downtown and back to the suburbs and all on a bike. Can ride down and get a beer at the park without dealing with any of the traffic , its honestly amazing
ihm96-
The advice bulgie gave above is solid. Definitely have a framebuilder do the job rather than a bike shop. Most current shops are not familiar with cold setting a steel frame and could do damage. A frame and fork alignment check will likely run $100 but this is variable depending on the area and the framebuilder. Your Ross' Ishiwata 024 frame and fork mark this as a mid level bike but alignment will benefit if regardless. I have even done alignments on light gauge hi-tensile frames and they have benefited from the treatment.
Awesome thank you! Will definitely have to find out who around me is good in that arena. Philly has a big bike culture so hopefully theres someone good I can find
