Today is seatpost anti-corrosion day
Quoted: 283 Post(s)
Liked 262 Times
Title says it. Take out Mr. Seatpost and do what needs doing. My bikes are Al or Steel, I'll be using auto wheel bearing grease to keep bad things from happening. I know nothing about carbonite.
Have a nice day
Have a nice day
Likes For grizzly59:
Quoted: 2026 Post(s)
Liked 1,096 Times
Was that a question?
Quoted: 980 Post(s)
Liked 582 Times
"Don't grease the grapevine!"
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
last summer I got a beautiful GUNNAR CrossHairs, somewhat customized old-man style with a taller headtube.
i was jones-ing for a super SPIFFY over priced NITTO seatpost - S65 Crystal Fellow.
Turns out GUNNAR (aka Mr. Richard Schwinn) makes the seat tubes to the upper limit of the standard seat tube size.
And it turns out that NITTO ends up and the minimum seatpost size after all the polishing and beautification.
I could not stop the seat post from slipping. The fine folks at RivBike where I got the seat post offered to knurl it for me if I would tell them the height I needed. (you know, so no one would see the knurling, it'd be in the seatube....)
My LBS gave me a teaspoon for the carbonite grease with the grit in it. I am using that for my seatpost ...... anti-grease? I dunno, it's giving me a very slight interference fit that I need. Working great for about 9 months or so.
Anyway. I thought I'd add a pointless story to kind of what looked to be a pointless thread. Just have the moderators move the whole deal to "Foo"......
happy trails.
Quoted: 4201 Post(s)
Liked 3,855 Times
This kind of thread is actually a really good reminder. because I believe that periodic cleaning and prep (lube, assembly paste, anti seize application) is the best answer for galvanic corrosion, or just plain corrosion. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 283 Post(s)
Liked 262 Times
I didn't know carbonite was a thing. I thought it was slang for carbon fiber Star Wars bikes. I forgot, if you have a quill stem you might as well do that too.
Quoted: 569 Post(s)
Liked 581 Times
On my bikes I also apply anti-corrosion above the clamp. My favorite is Wolfgang MetallWerk™ Concours Metal Sealant, keeps the mirror-like shine from fading after applying metal polish.
Quoted: 608 Post(s)
Liked 352 Times
As part of my spring maintenance I pull the seat posts and quills from my bike and re-grease them. This is just prudent.
@mrv what is the knurling of a seatpost that you speak of? I own a Rivendell and my seatpost is always slipping so I bought a Nitto S65 from Rivendell and it slips even worse than the no name one. I assume that seatpost and its highly polished surface isn't helping. A few days ago I pulled out the post and start cleaning the grease off and I will try some carbon paste next. Though I am interested in this knurling process which I have never head of. What's the process? If you or someone can enlighten me that would be great.
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
Here's what the tools look like: https://www.google.com/search?channe...=knurling+tool
- I have seen them (and hypothetically used them) on a lathe.
- The google is indicating you might be able to buy a knurling hand tool for not toooo much money, and do it your self. (Possibly Andrew R Stewart could comment further. I have seen many many many insightful and excellent pro-tips from him on bike building.)
- I am thinking if you just get the simple hand tool, then you "upset" some of the seat post material below what's above the seat post, you can develop some slight interference with the seat tube and give the seat tube collar (correct term? not sure....) something to grip to when you tighten it.
Since you bought your bike from the fine folks at Rivendell, definitely contact them forthwith. I only bought the seatpost from them and they offered to help me out by knurling the post (below what I would have sticking out of the seat tube). I try to support RivBike every now and then.
As previously mentioned - so far I am having success with the carbon-paste. I'll probably be spraying frame-saver in the bike soon, so I'll have to re-do the carbon paste.
Post here when you get it worked out! I'd like to know.
Cheers!
knurly, dude...
SE Wis
Quoted: 2745 Post(s)
Liked 3,390 Times
Likes For dedhed:
