How to restoring classic caliper brakes?
Old 09-11-20, 02:16 PM
datord
Quoted: 7 Post(s)
Liked 3 Times in 3 Posts
Hi guys. Can you please help me on how to remove these stains from a classic caliper brake to make it oh so shiny again? Its from a 1989 bridgestone roadman. Thanks guys!
datord is offline
Old 09-11-20, 02:25 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,054 Times in 1,254 Posts
Make two more posts and you can upload pics
clubman is offline
Old 09-11-20, 02:28 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
First deal with any dirt with a simple wash. If necessary try something stronger like simple green or a citrus based solvent.
Second if dealing with rust, evaporust does the job.
Once the calipers are clean try a polish like mothers
bikemig is offline
Likes For bikemig:
Old 09-11-20, 02:47 PM
datord
Quoted: 7 Post(s)
hmmm. well this is one.
datord is offline
Old 09-11-20, 02:53 PM
clubman
Phyllo-buster
clubman's Avatar
So tell me what model calipers you have.
clubman is offline
Old 09-11-20, 03:02 PM
datord
Quoted: 7 Post(s)
Finally able to upload photos. Haha.
Its a dia-compe. I have very little knowledge on bikes. Apologies if this arw silly questions.
datord is offline
Old 09-11-20, 03:04 PM
datord
Quoted: 7 Post(s)
another one.
datord is offline
Old 09-11-20, 04:18 PM
Jeff Neese
Quoted: 1083 Post(s)
Liked 687 Times in 441 Posts
Nothing a little elbow grease won't take care of. I'd use Mother's Mag and Aluminum polish, which is sold all over. You can make those look like new again.
If you have a buffing wheel it would take 5 minutes. By hand, a little longer.
Jeff Neese is offline
Likes For Jeff Neese:
Old 09-11-20, 04:31 PM
bikemig
bikemig's Avatar
You may want to replace those brake pads; kool stops are very good.
bikemig is offline
Old 09-11-20, 04:33 PM
Glennr134
Glennr134's Avatar
Bikes: 1968 Hercules 10spd. 1971 Raleigh Grand prix 12spd. Bridgstone 10spd, BSA 12 spd. 1872 Rudge high wheel 1987 Schwinn super sport
Quoted: 23 Post(s)
Liked 21 Times in 15 Posts
Mothers mag and aluminum works great !!
Glennr134 is offline
Old 09-11-20, 04:34 PM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
New pads - too after the calipers are all cleaned up and springs lightly lubed, Kool Stop is a good choice.
ryansu is offline
Old 09-11-20, 04:47 PM
Salamandrine
Quoted: 2317 Post(s)
Liked 597 Times in 430 Posts
It's light oxidation, AKA aluminum rust. It'll come right off with metal polish and a rag and elbow grease, like everyone says. They'll shine like chrome. I typically use Simichrome. Mothers will work, or Wenol, or probably about a dozen others.
FYI those are Bridgestone self centering brakes, made by Dia Compe. Neat design.
It is easiest to polish them if you take them apart. But don't do that unless you're confident in your mechanical skills. They'll clean up well enough if you leave them together. Give the pivot points a drop of oil when you're done.
Salamandrine is offline
Old 09-11-20, 04:58 PM
datord
Quoted: 7 Post(s)
Hi guys! Thank you sooo much for the responses. I'll try cleaning them and update you guys. This community is amazing.
datord is offline
Likes For datord:
Old 09-11-20, 05:04 PM
Kabuki12
Quoted: 874 Post(s)
Liked 2,288 Times in 1,278 Posts
I use Mothers Polish and on those you my need super fine steel wool first. I think taking them apart will render the best result. But as Salamandrine says be sure you have the skill to correctly reassemble. If not put together right then modulation can be off. They will look like chrome when finished. I usually do it while watching tv. I have done a few sets of side pull and center pull.
Kabuki12 is offline
Old 09-11-20, 05:11 PM
plonz
plonz's Avatar
Quoted: 656 Post(s)
Liked 469 Times in 302 Posts
All good polishes mentioned above. They’ll clean up the first pic but I doubt they’ll get rid of the spots. 2 or 3 stage wet sand followed by the polish will make them pop. 300/1000 grit (or approximate) for a nice shiny finish. 300/1000//2500 for a high polish finish. All able to be done by hand.
plonz is offline
Old 09-11-20, 05:18 PM
ramzilla
ramzilla's Avatar
Quoted: 700 Post(s)
Liked 322 Times in 252 Posts
Don't spend too much on chrome cleaner. The cheap stuff works just as good as anything else.
https://www.turtlewax.com/en-us/our-...-rust-remover/
ramzilla is offline
Old 09-11-20, 05:38 PM
niliraga
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times in 129 Posts
ooh, nice - Dia Compe SCs!! (self centering that really works!) i have two sets of these in use and I think they're kinda great brakes. They always seem to turn up on Bridgestones.
Another cleaning idea is to toss the whole caliper into an Oxalic acid bath - that will take the rust off the steel bits, but will also clean the (unanodized) aluminum back to a brighter, pale grey - from which point the polishing becomes much easier. (I use Blue Magic for raw aluminum, with a scotchbrite pad when tackling the peppering you have here)
You may also want to check & lube everything as part of the clean up - the mechanism is simple and clever, but it does require that parts can turn against each other in a tight "friction fit". a decade or three sitting outside can often end up killing the "SC" part of things until a refurb.
niliraga is offline
Old 09-11-20, 06:57 PM
branko_76
branko_76's Avatar
Quoted: 702 Post(s)
Liked 672 Times in 420 Posts
1) disassemble
2) green scotch pad and water
3) metal polish and micro-fiber cloth
4) grease pivots
5) assemble
6) Kool-Stop pads
7) ride
8)
branko_76 is offline
Likes For branko_76:
Old 09-11-20, 08:51 PM
SJX426
SJX426's Avatar
Quoted: 1608 Post(s)
Liked 2,216 Times in 1,103 Posts
LC_FrntBrk_01
, on Flickr
SJX426 is offline
Likes For SJX426:
Old 09-16-20, 12:06 AM
datord
Quoted: 7 Post(s)
Hey guys! Here's how my brakes look like now. I used 3M metal polish and sanded the parts that didn't come off.
Thanks for all the help.
datord is offline
Old 09-16-20, 04:55 AM
plonz
plonz's Avatar
Quoted: 656 Post(s)
Looking good. Now make the call on how shiny you want them. Polish and leave as is, hit them with wet 1,000 grit and polish or go all the way by following up with wet 2,500 grit and polish. They’ll end up like this which is hard to believe until you’ve done it.
DSCN2438 (600x450)
plonz is offline
Likes For plonz:
Old 09-16-20, 10:52 PM
datord
Quoted: 7 Post(s)
DSCN2438 (600x450)
wooooaah! That's some shiny piece of metal you got there! haha. I'll ust put it back for the meantime, I haven't ridden my bike for more than a week now and im excited with my "new" brakes. haha. Once i have free time i'll polish it even more.
datord is offline
