1-Gal Air Compressor for Tubeless Tire Setup?
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 67 Post(s)
Liked 19 Times
Hey everyone -
So yesterday was an extremely frustrating day. Riding my gravel bike with my 700x37 WTB Riddlers set up tubeless at about 35 psi on a trail I've done a million times and I get a sidewall slash from a rock or something. Sealant spurting everywhere, you know the drill. Won't seal after multiple attempts, so I put my tube in and finish my ride. I get home and try a plug slug, still won't seal. I try inflating the tire and tilting toward the gash so it'll fill with sealant, no dice. So, since the tire was pretty worn anyway, I go buy a new one. Exact same tire.
The bead will just not seat. I have a Blackburn chamber pump which I have used for many other tires, including the original Riddler on these same rims, which I must have filled up 20 times last night. I tried soaping the bead, I tried inflating with a tube first and only having to seat one half of the bead, I tried my ratchet strap, this stupid tire will just not seat.
I left the tire inflated with a tube overnight and it is sitting there at 55 psi right now until I get off work. I'll try again and hopefully having "stretched" the bead for 24 hours will do the trick, but if not I'm gonna throw in the towel and buy an air compressor.
My main question is: how big of a compressor do I need? I live in an apartment (I do have a garage but it is still close to my neighbors) and one neighbor in particular constantly complains about noise when my other neighbors use any sort of tools. Luckily, I have escaped her wrath so far, but I would like to continue to do so until I move out. So, the typical pancake/hot dog air compressor for Harbor Freight seems to be out of the questions due to its noise.
I've found a couple compressors like this one for $113 or the 2-gal version for $155. There's also a Husky brand 1-gal for $100 and another quiet California one with a 4.7 gal tank for $140.
How much capacity do I need if I just want to use this to seat tubeless tires? Is capacity the most important or is it CFM? I obviously want to spend as little as possible (with a quality product still) and keep it with a small footprint since I only have a 1-car garage and its already overflowing with stuff.
Thank you!
Thank you!
Quoted: 67 Post(s)
Liked 19 Times
Thread Killer
Quoted: 3195 Post(s)
Liked 1,727 Times
Get the biggest tank you can swing if you want to keep noise to a minimum. The ultra-quiet compressors are quiet, but they still make noise, so if that’s really a crucial factor, having a big tank will reduce run time.
That said, I think 3gal is minimum, 5-6gal ideal.
I have a Husky Silent Air 4.5gal twin tank which I’m quite happy with and can recommend.
Having tried several inflation heads over the years, I can suggest saving yourself a lot of headaches and just throwing down for the Park pro head. It’s almost as much as the compressor, but it’s such a critical piece; it’s what you work with, and lousy, clumsy heads can torpedo your job.
Quoted: 427 Post(s)
Liked 339 Times
Forget about tank size and get the shortest fattest hose you can get on it with extra large fittings (inside diameter) and a free-flowing fill valve like the Park or other. Take out the valve core. What you need is a really fast initial puff of air to seat the bead, not a giant slowly hissing tank of air.
Likes For dwmckee:
If you need something quiet, an Airshot canister or charger pump will work nearly as well as a compressor.
The only tires I have not been able to setup with an Airshot were wire bead MTB tires on rims that were not tubeless ready either, and even though they were comically loose, a co2 still worked. For some reason a co2 will often work where compressed air will not on very difficult tires. The cost and waste kinda sucks, but a $1 co2 here and there is still a lot cheaper than a quality air compressor if your only use for it is bike tires.
I would also not recommend the low end HF compressors because of the noise, and they just don't last. The pancake one lasted one year with light use before the piston ring just fell apart.
A $1 CO2 cartridge will seat most tires. If I can't get a tire to seat with a pump I'll just use the CO2 inflator and pop - it's on.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I recently was in a similar situation (never had problems seating til I got one set of tires that would not seat). I bought a 3-gallon because I have other stuff to pump up, using it to dry off bike, etc. But I think a 1-gal would be fine for you. The tire either seats right away or never, so it is not like you need to run it for a long time. If you want more air you probably could hook up a fat hose to the bleed valve. Just be careful to not pop the tire as the air literally screams out of that.
Even with my new compressor I could not seat my tires (Gravelking SS; LBS also could not seat for me). I finally got them to seat by a last desperate idea I came up with: kneading them for a few minutes. With thumbs on tread rotate tire toward you and pull sidewalls toward edges of rim with sides of knuckles of index fingers. You are pinching the tire a bit to do this, every two inches or so alternating sides. It needs to be completely dry or you won't be able to get a grip on the tire - no soap no sealant. Do three laps of this around the tire and the bead is now close to the rim at all points. Don't put on floor, just stick on compressor while holding and inflate. So far I am batting 1000 with this method.
Thread Killer
Liked 1,727 Times
Regarding tank capacity, there are two things to be aware of. First is that a gallon of air isn’t much, and if a tire isn’t seating and air is escaping, you’ll blow through most of that in a couple of seconds and the compressor will run attempting to recover tank pressure. Further, small compressors are not only small in terms of tank size, but compressor power and output, and a .8 SCFM compressor will need to run longer than 3.0 SCFM compressor to maintain pressure, and it will not be able to provide as much pressure either. A 1 gal tank will pretty much run every time you need to mount a tire, which is exactly what the OP does not want.
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
You need fast airflow, not a lot. A big tank is not going to help inflate a tire. Someone already said this - take out the valve core. Then use an air blow gun attachment with a hose over the valve core.
Also, Skinny Strippers (FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="https://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="https://fattystripper.com/media/FattyStripper_L) work great and make it much easier to inflate a gravel tire - I've done it with a regular floor pump!
