Tyre key. has anyone tried it?
Quoted: 130 Post(s)
Liked 24 Times
Back in the olden days getting tires on and off was easy peasy, but modern tires are a freaking pain in the ass. this thing looks pretty cool, has anyone tried it?
https://www.tyrekey.com/product/tyre-key/
Quoted: 4559 Post(s)
Liked 2,802 Times
Kool Stop tire bead jack. Costs only ten bucks or so. Got one for convenience early in 2018 because my Schwalbe One and Conti Ultra Sport 2 tires were so difficult to install, especially on the road with cold hands. I pinched a tube the first time I tried to install the Ultra Sport 2 using a plastic tire lever. Got the Kool Stop bead jack, never looked back.
After my shoulder was broken and dislocated in May it was an absolute necessity. Now I carry it on almost every ride, including casual group rides in case someone else has a flat. Some folks chop off a bit of the handle. I haven't. I just shove it in a jersey pocket or my jeans pocket.
Unfortunately there isn't a tutorial video that does justice to how simple, quick and easy it is to use. It only needs a 30 second demo. But RJ the Bike Guy's video is okay.
BTW, there is a wrong way to use it and I've done that a few times when I wasn't paying attention. Doesn't hurt anything, it just doesn't work well when flipped the wrong way. Flipped the right way it's fast and easy.
Quoted: 130 Post(s)
Liked 24 Times
https://www.youtube.com/watch?v=-EZRSz1DlHg
That's super cool
Bikes: 2015 Giant Roam 2 Hybrid
Quoted: 91 Post(s)
Liked 6 Times
I too second the Cool-Stop. To the OPs point, they are essentially the same thing but the direction of leverage is different, the Tyre Key should work just about as well.
I've got tubeless ready rims and tires and still have tubes in them, The first flat I had I about wrecked my fingers getting the tire back on, the beads are very tight on tubeless. The Cool Stop works like a champ.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Not expensive so certain worth trying out. I've used a VAR tire jack for decades when I encounter a difficult mount. Works great as well.
Quoted: 551 Post(s)
Liked 277 Times
Looks like a more compact alternative to the Kool Stop tire bead jack. I might try this.
Some folks chop off a bit of the handle.https://www.youtube.com/watch?v=-EZRSz1DlHg
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Good work around. Otherwise too big to carry around. The tyre key looks like it would be a reasonable size.
Quoted: 7652 Post(s)
Liked 3,473 Times
Now we need a tool that makes dismounting tubeless tires as easy as that makes it to mount them.
Edit: I carry the VAR tire jack when I am not carrying a lot of extra storage---does the same job.
Quoted: 479 Post(s)
Liked 277 Times
My current tires are just too damn tight to mount without the Kool Stop Tire Jack - which works amazingly well. But, it's big - better suited for work in the shop (garage). The Tyre Key looks like the jersey pocket version. I'm going to grab one.
Thanks dougphoto!
Thanks dougphoto!
Quoted: 18374 Post(s)
Liked 4,509 Times
I may have to try one. I'm generally OK with mounting and removing tires, but had some hassles a few weeks ago with trying to mount a tubeless tire with a tube (punctured both my spare tubes). I need more practice!!!
Modern fat tires are still easy to put on by hand, it's the 100psi narrow ones that fit tight, and I feel more secure they do, at those pressures..
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Looks good. Thanks for the tip.
Quoted: 344 Post(s)
Liked 20 Times
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I've seen the TyreKey before...I just wonder, if like a Bead Jack, some rims don't approve of its use.
in bagnomaria
If the center of your rim bed is lower than the edges, stop and give yourself a high-five because you don't need a tire lever.
Liked 4,509 Times
Perhaps I need more practice and experimenting such as changing from valve first to valve last. But, the tire doesn't drop down into the grove as easily as one might hope.
Liked 406 Times
Some tires and wheels are just impossible to mount no hands, even with immaculate technique. A classic example are Fulcrum/Campagnolo 2-way-fit wheels (have a bead channel and don't even need tape), and Hutchinson tubeless tires.
in bagnomaria
No, you need to use gravity and force to push the bead into the groove and create slack.
in bagnomaria
I happen have a set of 2-way Fulcrum R3s and have easily mounted by hand a variety of Continental, Vittoria, and Schwalbe tires on them over the years.
Bikes: CAAD10
Quoted: 27 Post(s)
Barring damage to the tire or wheel, or something being horribly out of spec, I disagree.
I don't know about that specific tire, but I have mounted a few TL tires on TL rims tool-free and have yet to face a problem.
in bagnomaria
