Bottom Bracket for Richey Logic Triple Crank
I'm currently using an old Ritchey Logic crank on one of my bikes. As a double this crank worked great, but now as a triple the shifting is not good. Does anyone know what length bottom bracket I should be using? Currently it has a 115mm in there.
Thanks in advance for any help you can provide.
Quoted: 4204 Post(s)
Liked 3,862 Times
It is more direct to measure actual chain lines, ft and rr. Or visually check the chain's angle when in the middle ring and cog(s). Minor deviations from "perfect" chain line rarely causes shifting issues. Many times it's the ring/chainstay clearance that controls the ft's chainline. How much space is there on your bike? Andy
AndrewRStewart
AndrewRStewart
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
Good luck getting the shifting/gearing you want.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I used to have a Sugino-made Ritchey MTB triple on a Bridgestone MB-1, which has a 68mm BB shell. I think it used a 122mm spindle BB.
Likes For dsbrantjr:
Bikes: 1991 Bridgestone MB-1, 2022 BMC Monstercross, 1990 Bianchi Axis
Quoted: 7 Post(s)
Liked 6 Times
The Ritchey crank pulled of my 92' Bridgestone MB-1 had a 120mm spindle which is hard to find. I plan on trying 118 and will see if that's close enough.
Cheers.
Cheers.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
