Do Look Keo Blade Carbon Ceramic TI Tour De France Limited Edition Road Pedals ok?
Does Look Keo Blade Carbon Ceramic TI Tour De France Limited Edition Road Pedals work with Campagnolo Super Record 12 speed mechanic version?
https://www.lookcycle.com/notices/no...TECHNOLOGY.pdf
https://www.cyclesetsports.com/en/cy...720179777.html
is there any good pedal plate for LOOK KEO BLADE CARBON CERAMIC TI TOUR DE FRANCE LIMITED EDITION ?
I want to use pedal plate for normal shoes ridding
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Titanium spindles...hope you weigh less than 180lbs
Likes For Marcus_Ti:
Quoted: 1020 Post(s)
Liked 463 Times
On the outside chance that the OP is asking a serious question, the answer(s) is/are:
1. These pedals work with all current crank arms;
2. What release “pressure” (8nm, 12 nm or 16 nm) you use is a matter of the rider’s level skills and confidence levels. Professionals use 16nm (the tightest setting) I use 12nm. You can buy replacement “blades” to change the amount of pressure.
3. These pedals are meant to be used with LOOK cleats, you can’t use them as “platform” pedals.
Hope this helps (assuming honest questions from the OP).
Likes For eja_ bottecchia:
Quoted: 2026 Post(s)
Liked 1,095 Times
There are adapters available for some clipless pedals (Shimano SPDs for one) that clip into the cleat mechanism and provide a flat platform, sometime even including toe clips and straps, that let you ride in street shoes. I very much doubt they are available for Look Keos.
Likes For HillRider:
Quoted: 1814 Post(s)
Liked 1,693 Times
I'll also make the naive assumption that the OP is asking serious questions and that English is (obviously) not his native language and perhaps not even his second.
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,563 Times
It really doesn't matter. If you look back at other posts from the OP, it appears that this person is building up a very high end frame with Campagnolo Super Record 12 speed components without any knowledge about how to do it. Using Keo Blade pedals adapted for use as platform pedals is part and parcel of this silly build. Any one sided pedal adapted this way is a kludge, the pedal will turn upside down any time you take your foot off so you will constantly be having to flip it back at every intersection or stop. It has nothing to do with comprehension of English, we might as well be speaking Swahili as far as it goes getting through to this person
most time riding it with normal shoes in the city,sometimes riding with lock shoes shimano for 50-150 km
Likes For cycling2012:
