Sugino XD600 Loose
Quoted: 8 Post(s)
Sugino XD600 Loose
I put this crankset on my commuter and today the left crank started loose. The BB is Shimano UN55 (?) 115mm, and both should be JIS. Its been fine for a month or so of occasional commuting.
Did I just not tighten it down enough before? I did have my foot a little more outboard because my heel was nipping my kickstand, so I think this is what started it.
Quoted: 5888 Post(s)
Liked 3,472 Times
It probably just needs to be tightened down. Don't overdo it but it looks like you underdid it. I ran into a bike mechanic on a tour who told me that square taper cranksets are prone to failure. I don't think that's true but it's clear that a lot of people tighten them down properly.
Be careful; if you run that crank arm loose, you're likely to ruin it.
Quoted: 2026 Post(s)
Liked 1,096 Times
The recommended tightening torque for square taper cranks (350 to 450 inch-pounds) is a LOT tighter than most new mechanics realize and far more than a typical 8 mm allen key can provide. A hex bit in a torque wrench is really recommended. Assuming you didn't torque it properly you were on borrowed time and it picked now to finally come loose.
As noted, if you rode with the arm loose for any real distance you may have distorted the arm's square hole and it will never be right again.
Constant tinkerer
Every amateur mechanic has undertightened a square taper crank at some point. In my experience (yes, I did it too...) once you feel it loose the arm is ruined and needs to be replaced. It only takes a little movement to ruin the tapers. Your best bet now is to re-install it with as much force as you possibly can and start shopping for a new crankset.
For a much better and detailed explanation, see here: Installing Cranks by Jobst Brandt
That mechanic was wrong, but lots of cranks do get ruined from undertightening. Installed properly, a square taper crank will be good forever or until the bottom bracket needs servicing/replacement.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
When I used square taper, I always torqued my bolts to the same torque as HillRider suggests. I never had problems with an arm coming loose. But I've seen many poorly torqued and ruined square taper cranks. Even a moderate amount of riding on a loose crank will ruin it.
Stuart Black
Stuart Black
Quoted: 3376 Post(s)
Liked 5,526 Times
Always use a torque wrench on a square taper.
Learned that the hard way.
