Indexed vs Friction Shifters
#126
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
And please note, I have, and love 5 bikes with DT shifters(3 friction, 2 indexed), but I have no illusions about the technology not being obsolete.
#127
Quoted: 3514 Post(s)
Liked 2,927 Times
"b: of a kind or style no longer current." Not even sure what "current" means here. DT shifters are still "currently" being made by the thousands and "currently" used by the hundreds of thousands--if not millions.
#128
Liked 2,927 Times
#129
Liked 11,914 Times
#130
Liked 11,914 Times
*********. It's perfectly accurate and descriptive.
#131
Maybe one can say that friction shifters are going the way of rod & stirrup brakes?
No doubt there are still new bikes being sold with rod & stirrup brakes (in India?), but there's no need to use the dreaded 'obsolete' word.
Likes For Xavier65:
#132
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Did "the vast majority" of bikes on Earth ever use dt shifters?
With the popularity of 3-speed hubs and single speeds, I really doubt it.
What is the gearing for "the vast majority" of currently produced bikes on Earth? Single speed?
Likes For SurferRosa:
#133
Quoted: 4415 Post(s)
Liked 4,871 Times
#134
Liked 4,871 Times
That isn’t the point. The point is that DT friction shifters were superseded decades ago on bikes that typically used them.
#135
Liked 11,914 Times
Likes For genejockey:
#136
señor miembro
Liked 6,488 Times
#137
I have historically used friction shifting on a lot of my bikes. I don't any longer, however, other than on my grocery getter. And that's mostly a function of a shift in the kind of riding that I do.
I currently do only road riding and I do it as structured training where I'm trying to carefully control some workout parameter such as heart rate. I do this primarily to manage my diabetes. When I'm riding like this, I find that:
1) the small bits of extra time and effort required to friction shift distract my focus away from where I want it: on my carefully structured training.
2) I need to shift a lot in order to have my gearing dialed in such that I'm controlling my parameter of interest well. Friction shifting tends to make me shift less because it's harder.
Maybe I just never got good enough at friction shifting, who knows. However, at this point in my life, I need to be in the execution phase of things more often than the learning phase.
I am still using downtube shifting, just indexed. And that's become a royal pain due to the poor availability of reasonably priced, high quality NOS shifters. I'd cut off a thumb for a set of NOS SL-7900.
#138
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Di2!
Electronic shifting is surprisingly reliable for me. (I've heard of a few local failures over the years, probably less likely than broken indexed shifter mechanisms.)
At 8.5 years and 38,000 miles, a ballpark estimate is that I've shifted 500,000 to 700,000 times. Mainly because it's so fast and easy to shift, even with a ring finger if my hand is out of position. The 500,000 estimate is 13 shifts per mile, about one every 400 feet of riding (or approx every 20 seconds) -- but I often shift more than one gear, or shift up for a few pedal strokes and shift back again.
With mechanical click buttons on the shifter and the derailleurs themselves, the system is still working perfectly.
I didn't expect this much reliability with physical click buttons on the hood levers, and tiny motors and miniature reduction gears in the derailleurs. I did replace the lithium battery when it started needing a recharge after 300 mile intervals.
Likes For rm -rf:
#139
Liked 2,927 Times
#140
Quoted: 2486 Post(s)
Liked 2,956 Times
Likes For Trakhak:
#141
1) Use a "dead" STI lever up front? Yuck.
2) Us a non-STI lever up front that, then, does not match the rear shifter. Yuck.
3) Use an STI rear lever and downtube front shifter? This is what I'm doing but most modern bikes don't have the mount for it.
4) Use an STI rear lever and an Genevalle friction front? I've tried this and probably like it second best of the available options.
5) 1X shifter set. Expensive just to satisfy my need for symmetry.
6) Bar ends. Symmetrical but I don't love the cable routing options.
What I'd really like is an STI-ish lever that is friction AND matches whatever I'm using for an indexed shifter on the rear.
#143
Liked 2,927 Times
#144
Close I guess. It's just a lot to pay when all my bikes cost less than $1,500. Often much less.
Two, recent, SL-7900 adventures for me:
1) A dude, in my city, offered an NOS pair for $50. I bailed on work and still was second to show. I even, unethically, offered to pay 3X the asking price if the seller would screw over the other guy.
2) I thought I found four pair from a Louisiana bike shop on line. They wouldn't ship to Canada. So I made complex arrangements with a friend for expensive, two stage shipping. Turns out the store never had the shifters to begin with. They just hadn't updated their inventory database in a good long time.
I've been considering using Microshift but I'm not sure their shifters are meaningfully different from just using the 10s Shimano bar end shifters that I have as DT.
#146
Liked 2,927 Times
#147
Quoted: 1034 Post(s)
Liked 1,292 Times
Di2!
What is so absurd about this discussion is that so many here cannot grasp the fact that there are different needs for different types of riding, and what works for them, may not be the best thing for someone else. Many touring bike riders like to keep things simple, mainly due to the fact simple is easier to repair in the middle of nowhere, and is also less likely to break when a heavy, fully loaded bike falls over. That doesn't make friction shifter superior to indexed. My touring bike had indexed bar end shifters. They worked, until they didn't, and I simply switched them to friction, then after riding it that way for a while, I bought nicer friction only shifters. I like them. They shift so easily.
Being able to shift from the hoods using brifters, yes I called them that, is wonderful. Especially for those who are riding "road bikes," and wanting to try to ride fast in order to beat their personal best, or actually race, or just have fun. You will find that most touring riders are not shifting all the time. We tend to get into a gear and ride. The friction shifter is nice for me because when I need to, I can go from the small cog to the large one in one fell swoop, instead of clicking through each cog.
I have actually entertained mounting my shifters on the down tube bosses. They are currently on the bar ends, and while I like them there, I grew up with down tube shifters, and four touring, they work well there, and are out of the way. They are hard to damage there.
People throw out words like obsolete and such, but friction shifters work, and are in current production. They are simple and some people like them. Some people now tour with indexed shifters on the hoods. They work too. Most of this comes down to personal preference, with some specific needs thrown in, but of course here on Bike Forums, there are many who cannot possibly believe someone would need or want something that isn't cutting edge, or god forbid something they themselves don't care for.
#148
Liked 4,871 Times
#149
Quoted: 1248 Post(s)
Liked 1,323 Times
Your definition is still inaccurate: "a: No longer in use or no longer useful." DT shifters are in use world-wide and as such, by definition, are therefore "useful."
As for the garages and basements full of DT friction-equipped bikes, just because they exist doesn’t mean they are used or ridden. Even the friction advocates on this site who boast of having dozens of bikes as part of their collection, never mentioning the actual distance put on these bikes. There may be millions of friction-shifting bikes remaining but most of them are treated like tchotchkes at best and forgotten relics at worst.
#150
señor miembro
Liked 6,488 Times
