Disc brakes are great!
#126
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,913 Times
Maybe we should just bring it full circle, and put big wings on the end of thru axles to make them easier to unscrew?
Likes For genejockey:
#127
Quoted: 3513 Post(s)
Liked 2,927 Times
Next solution: the thru axle! It is not actually an axle, so it doesn't support any forces and it doesn't make anything stiffer or stronger. It is merely a wheel retention device, that features less clamping force than a properly applied QR. But it is relatively idiotproof, and allows the bike industry to shed any liability.
#128
Liked 11,913 Times
I have to say, I do like the precision of thru axles compared to QRs. Especially after my massive sprint (or maybe just my massive mass) keeps pulling the rear wheel off center on the bike with the chrome plated horizontal dropouts! I also find that on some bikes I have to be really careful in aligning the wheel in the dropouts before closing the QR. I don't know why, might be the shape of the dropouts.
#129
Quoted: 2338 Post(s)
Liked 2,827 Times
To be more clear/accurate my point was more that wheel retention, safety tab or not, seems to have been enough of an issue that that thru axle is the standard for disc hubs now.(sure there are other benefits)
#130
The bike industry obviously saw this as well, and the associated liability. Thru-axles are not necessary to get wheels properly aligned in the fork, any idiot can accomplish this. But the way that folks were using QR levers incorrectly required another 'solution' that was idiot proof. Hence the PITA thru-axle.
#131
Liked 2,927 Times
#132
Quoted: 3955 Post(s)
Liked 7,303 Times
Exactly. At the Co-op and on the bike lanes we see this with terrifying frequency. A lot of riders attach their wheels by spinning the QR until it is sort of tight, without flipping of the lever. Scary.
#133
Liked 2,927 Times
#134
Liked 7,303 Times
Likes For tomato coupe:
#135
Liked 2,927 Times
#136
Quoted: 6972 Post(s)
Liked 10,969 Times
What you do miss, though (as evidenced by your posts in other threads), is that some riders go off-tarmac, some ride in the rain, some ride through mud, some occasionally do steep descents in all of those conditions, and they do it with fat tires -- all of which are better handled by disc brakes.
Likes For Koyote:
#137
Liked 11,913 Times
I only have that problem with the Battaglin, which has chrome plated Campy horizontal dropouts and chrome plated Campy QRs. Both sides of the interface are smooth. I can tell when it's out of alignment because the chain starts rattling in the smallest cog. I ended up cutting rubber washers to put between the faces.
On the contrary, it's the fork dropouts that seem to be the problem. It's like the wheel has two ways it can sit, and I have to make sure it's sitting right before I close the lever. And yes, the wheels are symmetrical - I checked. I dunno - just something in how the axle interacts with the dropout.
That's what dropout adjusters are for, on the back. The front, of course, doesn't need them.
#138
Liked 10,969 Times
Why start the thread at all?
- to try and understand why others wont get on board with what you think is clearly the obviously best choice.
- to try and convince holdouts, through conversation, that they should jump on board.
- to try and start an argument for entertainment.
(For the record, I've never tried to convince anyone to "get on board" with discs. Not even a little bit.)
I'll mark my calendar!
Likes For Koyote:
#139
Liked 10,969 Times
I always figured the thru axle makes it easier to always keep the rotor perfectly aligned in between the pads; with QR dropouts, you have to at least quickly eyeball it when clamping down the lever -- it's not difficult or time-consuming, though. If I forget to do it, there is usually still no rubbing.
Likes For Koyote:
#140
Liked 2,927 Times
#141
Liked 2,927 Times
#142
Liked 11,913 Times
#143
Liked 2,927 Times
#144
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
I dont know why koyote started the thread as it isnt my week to peek into his mind and explain his motivations. My week starts March 17th, so ask me then and I can give you a more accurate answer.
OTOH, starting another new thread on a topic that was just recently over discussed is not against the rules. You can start one, too, if you want.
There's been a lot of argument about disc brakes lately, and it feels like both sides talk past each other a bit -- maybe one side more so than the other. After just reading yet another post with a blanket condemnation of disc brakes, I thought I would start this thread. Below are descriptions of my two disc brake bikes and the reasons why I choose discs.
If any of you naysayers think my reasons for running disc brakes (on two of my five bikes) are stupid, ill-informed, whatever, let's hear it right here. I'm eager to process your logic.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
#146
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
I gather that you ride a road bike, and you stated that you only ride when it's dry out. In those circumstances, I agree that rim brakes are all that's necessary. It's why my two road bikes have rim brakes, and I have no immediate plans to replace them with anything different.
Liked 11,913 Times
Or, you know, just make sure the wheel is properly aligned before closing the QR.
#149
Liked 2,927 Times
#150
Quoted: 1109 Post(s)
Liked 1,200 Times
I have found an error in Dave's logic. AMEX platinum cards are made of stainless steel instead of plastic, making them incredibly heavy by comparison. No self respecting cyclist would ever dare carry such an boat anchor on rides. You'd lose several seconds on even short climbs and you'd be left to watch as your powerful, dedicated, handsome riding buddies disappear over the next crest never to be seen again.
