Bike Shifters Labeling
Quoted: 18 Post(s)
I was given a bike and I needed to change the right gripshifter because it wasn't compatible to the shimano derailleur I bought..
The stock shifters were GRIPSHIFT 3.0 by Sram I believe
3 1
2 2
1 3
. 4
. 5
. 6
. 7
But I needed a new grip shifter so then I bought Sram MRX Comp for the 7 speed
But now the numbers are not i guess...properly...labeled or something.. I'm not too sure what happeend This is the labeling now
3 7
2 6
1 5
. 4
. 3
. 2
. 1
How do I fix this. Matter fact, why is it changed now, why is 7 on top.. and not at the bottom like many other bikes
3 1
2 2
1 3
. 4
. 5
. 6
. 7
3 7
2 6
1 5
. 4
. 3
. 2
. 1
Quoted: 18 Post(s)
This is what was there before https://www.chainreactioncycles.com/M...?ModelID=39484
Formerly Known as Newbie
If it works, does the order of the numbers matter? It might take a bit getting used to, as you now have to twist in opposite direction compared to your old shifter, but still?
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Bikes: surly cross check
grip shifters are available in either configuration. If you don't like the setup you purchased, you may be able to exchange it for the shifter you want.
or as a previous poster stated, try using it for a while and see if you can get used to it.
cw1
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
4
02-07-16 03:36 PM
