Alternative for Wrench Force Syn Grease
Bikes: mid 80s Ross Centaur converted to Alfine 11 09 motobecane imortal force, 83 Ross Paragon,81 Schwinn LeTour Tourist, 91 Paramount, 93 GT converted to city bike
Just emptied the last tube of this great lube and discovered..it apparently is no longer available.
(spent 40 minutes on line comming up with 'product is no longer available)
I use it mainly for the bearings.
Wondered what's a good alternative/what others are using.
Thanks
Thanks
Just keep pedalling!
Bikes: 1987 Schwinn Circuit, 1987 Panasonic DX-4000, 1984 Peugeot PSV10, 1989 Centurion Prestige, 1973 Raleigh Sprite, 1987 Peugeot Canyon Express, ~1986 Raleigh Capri, 1994 Trek 850, 1984 Centurion Pro Tour 15, 2012 Gravity Zilla
I use this stuff for all of my bearings, seatposts, and stems:
https://www.alexgs.com/product/mystik-665056002080.html
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
Park grease and Phil's have both worked great for me
Quoted: 443 Post(s)
Liked 27 Times
Is Wrench Force grease from Trek dealers like the tools? I have one of their cable cutters. They were supposedly made by Snap-On, but I'm not impressed with the quality.
I use Park grease. The tubes are convenient.
Boat trailer wheel bearing grease, It's extra water-resistant,
+ cheap, a tub has lasted me for decades.
Kitten Legion Master
Bikes: Fuji silhouette, Dawes SST-aL
I've switched all my greases and currently switching my oils to Super Lube.
https://www.amazon.com/Loctite-82325-.../dp/B000XBH9HI
Quoted: 114 Post(s)
Liked 119 Times
For bicycle application, seems like automotive grease is more than fine. I've used Phils, Park Polylube, Nashbar white lithium, and automotive wheel bearing grease. Except for the color and feel, one really can't tell the difference. Bicycle specific grease is more costly per ounce, but is often packaged in an easy to use squeeze tube. A tube (4oz) of Park Polylube lasts me many years. On modern bikes, there isn't much to grease, since the bottom bracket and hubs tend to be sealed cartridge bearings. For the price of a tube of bicycle specific grease, I could get a pound tub for the same price - and that would last probably 10+ years assuming I don't contaminate it over the years. Since I don't use much and the cost for a 4 oz tube may be ~$5, I don't mind buying a bicycle specific grease, if just for the convenience.
Bikes: CAAD9-6, 13' Dawes Haymaker 1500
Liked 6 Times
I got a tub of the Park Polylube, has worked great for me, but the tub is wayyy too much, unless you work in a bike shop or have like 30 bikes(like some people on here...), get the tube.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
1lb tub of Valvoline + mini grease gun = set for life.
Quoted: 2026 Post(s)
Liked 1,096 Times
22 oz tub of Phil grease plus a Dualco refillable grease gun = set for decades + won't contaminate the tub with dirty fingers.
Experienced
Quoted: 16 Post(s)
Don't overthink it; pretty much anything anybody has already posted is fine. I use this. https://www.amazon.com/SILGLYDE-LUBE-.../dp/B000KXLR5E
Advisor
To replace my Pedro's/Wrench Force synthetic grease, I just ordered a small tub of Finish Line's Ceramic Grease, $20-$25. Finish Line's most advanced bearing lubrication technology. Formulated with sub-micron ceramic particles, TeflonŽ fluoropolymer and premium non-toxic synthetic oils.
Bicycle Repair Man !!!
Advisor
Originally Posted by Lawrence08648 To replace my Pedro's/Wrench Force synthetic grease, I just ordered a small tub of Finish Line's Ceramic Grease, $20-$25. Finish Line's most advanced bearing lubrication technology. Formulated with sub-micron ceramic particles, TeflonŽ fluoropolymer and premium non-toxic synthetic oils.
I did order Finish Line's Ceramic Grease this past week. I haven't received it yet to look at it. The rest I copied off their website that's why it appears to be an ad.
Cottered Crank
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 13 Times
I use both the cheaper ordinary green waterproof trailer grease (for most applications) and the nicer Castrol lithium grease rated for bearings on disc caliper brakes for IGH's that need grease.
The mini grease guns are very cheap and work extremely well. Harbor Freight sells the same thing too for a buck or so less -even cheaper when it goes on sale.
Fred-ish
