Sugino BB Help
Sugino BB Help
I'm getting ready to go from a Sugino XD triple to a double. I'm just loosing the granny gear. What size would you use for that crank? It's going on a steel frame bike if that makes any difference.
Quoted: 2026 Post(s)
Liked 1,096 Times
Are you just unbolting the granny chainring and keeping the rest of the triple crank or switching to a purpose built double crank completely? Suguino should recommend a suitable length bottom bracket for either.
All I have now is the crankset. There isn't a BB. All my JIS taper BB spindles are for vintage bikes. So, they're all around 122mm which is way too long.
Should be a simple Math and measuring ..
your new chainline is between the 2 chainrings rather than the center of the middle of 3.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
For a double 107mm might work, depending on chainring size and dimple shape. 110mm will almost certainly work.
Jeff Wills
Jeff Wills
Liked 1,096 Times
Any way to take it to a co-op or bike shop and try-fit a couple of different bb's to see what works?
If I interpret you correctly, you currently have a Suguino triple crank and you are just going to unbolt the granny chainring. right? I wonder if the triple, even with the third ring removed, works with the same bb spindle as their purpose built double.
David Laird
Classic & Vintage
0
04-20-12 08:18 PM
SteelCan
Bicycle Mechanics
10
08-05-10 10:23 AM
