Crank Sechel
Bikes: 1982 Schwinn Super Sport S/P, 1984 Miyata 610, 1985 Panasonic LX 1000, Centurion Pro Tour 15 1983
Quoted: 5 Post(s)
Liked 5 Times
Crank Sechel
A recent thread about a failed left hand crank arm caused me to focus on my own crank problems. For several years, prompted by a post here, I've subscribed to the 'dry flats, greased thread' paradigm.
Fast forward. I've sourced a couple of replacement cranks. They have me very excited although it's something of a knuckle buster to swap out the rings. Before commencing today, I thought I'd see what sheldonbrown.com and Jobst Brandt might have to say on the subject.
It's sufficiently different from the above 'accepted wisdom', and important enough, that its pasted in below:
Installing Cranks by Jobst Brandt
" Subject: Installing Cranks
My cranks get loose, quite quickly too; over about 10 miles or so from being solid to flopping about in the breeze. Any suggestions?"
One or both of the cranks are ruined!* Once ridden in the "floppy" mode, the tapered square bore of the crank has been deformed and can no longer be secured on a spindle. Install and properly tighten new cranks on the spindle after greasing the tapered square ends of the spindle. Proper tightness should be achieved with a torque wrench or by a skilled hand.
The admonition not to grease the spindle finds life mainly in the bicycle trade. When I discussed the "dry assembly" rule with crank manufacturers, I discovered that they had warranty claims from customers who split cranks. However, cranks cannot be split by overtightening them. This can be proven by attemting to do so. An M8x1 bolt is not strong enough to split a major brand crank.
Failure from "over-tightening" is caused by repeated re-tightening of properly installed cranks. In use, an aluminum crank squirms on its taper and, because the retaining bolt prevents it from moving off the taper, it elbows itself away from the bolt and up the taper ever so slightly. The resulting loss of preload, after hard riding, can be detected by how easily the bolt can be turned.
Loss of crank bolt preload is greater on left than the right cranks, because left cranks transmit torque and bending simultaneously while right cranks transmit these forces separately. The left crank transmits driving torque through the spindle to the right crank and chainwheel while the right crank drives the chainwheel directly. Besides that, the right crank transmits torque to the spindle only when standing on both pedals. Doing this with the right foot forward (goofy footed) is the only time the spindle transmits reverse torque.
Mechanics, unaware of why crank bolts lose preload (and commensurate crank tightening), have re-tightened bolts until cranks split. No warnings against re-tightening properly installed cranks are evident although it is here where the warning should be directed rather than at lubrication.
Because friction plays no role in torque transmission, preload in the press fit must be great enough to prevent elastic separation between the crank and spindle under torque and bending. This means that no gap should open between crank and spindle facets under forceful pedaling. Crank bore failure occurs when the press fit is loose enough that a gap opens between spindle and crank. Torque is transmitted by both leading and trailing half of each facet, contact pressure increasing and decreasing respectively. In the event of lift-off, the entire force bears only on the leading edge of facets and causes plastic deformation, causing the bore takes on a "pin cushion" shape (loose crank syndrome). Subsequent tightening of the retaining screw cannot correct this because neither the retaining bolt nor crank are strong enough to re-establish the square bore.
The claim that a greased spindle will enlarge the bore of a crank and ultimately reduce chainwheel clearance is also specious, because the crank cannot operate in a plastic stress level that would soon split the crank in use. However, increased engagement depth (hole enlargement) may occur without lubricant, because installation friction could ream the hole.
With or without lubricant, in use, cranks will make metal-to-metal contact with the spindle, causing fretting erosion of the steel spindle for all but the lightest riders. Lubricating the spindle for assembly assures a predictable press fit for a given torque. Without lubrication the press is unknown and galling (aluminum transfer to the steel spindle) may occur during assembly. After substantial use, spindle facets may show rouge and erosion from aluminum oxide from the crank, showing that lubricant was displaced.
Crank "dust caps" have the additional duty to retain loose crank bolts. Because crank bolts lose preload in use, they can become loose enough to subsequently unscrew and fall out if there is no cap. If this occurs, loss of the screw will not be noticed until the crank comes off, after the screw is gone."
PS. 'Sechel'. "Common sense" (JPS), intelligence.
sechel - Jewish English Lexicon
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
FWIW, I usually use anti-seize, but have used grease as well; but always use something these days. I can't recall ever having a crank arm come loose using this method. I have had one come years ago loose mounted dry, but to be honest that may have been more of a "not enough torque at assembly" issue. YMMV.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
