Shimano 9-speed triple crank and BB
Looking to buy a used 9-speed Shimano triple crank, 105-series or higher, and preferably 170mm or shorter arm length. If you just have the spider, that's okay because I have an extra set of chain rings. Also need a compatible BB as well for generic 68mm threaded shell, if you have one that's in reasonable running order. As I recall, the spindle length is longer for an octalink triple, so make sure to check that. Should be 118.5mm I believe.
Okay, so I got the BB. Now I just need a 55 or 65-series triple crank. As I said before, no chain rings required since I have a set. It would be nice if you had the chain ring fasteners, however!
Bikes: You mean this week?
Quoted: 29 Post(s)
Liked 29 Times
If you're still looking, I have a nice Shimano 105 Triple Octalink 175mm. It came off my wife's recumbent, which is to say, barely used. :-)
