If you had to choose...
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Whichever one listed the Lazer Z1 or new G1. I really have loved my Lazer helmet and really have no interest in changing to anything else at the moment.
Quoted: 2281 Post(s)
Liked 1,710 Times
I assume anything sold in the store or LBS would meet at least the minimum requirements, so I'd just go with whatever there fits my noggin.
Likes For Milton Keynes:
Quoted: 3241 Post(s)
Liked 2,512 Times
Quoted: 969 Post(s)
Liked 1,632 Times
No...
I gotta put my hands on it, wear it, strap it down, double check the padding, consider its longevity, and lastly make sure it fits my "les fringues".
My life was saved by a cheap Walmart Bell ChiCom helmet... Nuf Said...
Quoted: 6972 Post(s)
Liked 10,971 Times
Other things equal, I'd go with VA Tech.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I've never taken anyone's testing into consideration when choosing a helmet. I like Smith, so that's what I usually buy.
Quoted: 1944 Post(s)
Liked 2,164 Times
My only concern with Virginia Tech’s testing is whether any Delta fraternity was used in the testing process.
John
John
Likes For DonkeyShow:
I bought a helmet yesterday. I used the VPI site to narrow down my choices. Alas, many helmets of interest (current Smith models, for example, and Abus) haven't been tested. The real problem, though, is that I couldn't find many retailers with helmets of interest actually in stock. No Smith, no POC, no Abus (except their urban helmets), none of the Lazer MIPS versions in my size, no Giant, etc. Many of the the lower-priced (my limit was $160) helmets that tested well are simply not in stock at an LBS close to me. I took my list of helmets that tested well at VPI, and matched them to what was available.
I'm very glad I tried the helmets on. I found a couple that both tested well and fit as if they were made for my head. One of the ones I would have bought without the VPI list both tested relatively poorly and fit poorly - I just couldn't find an adjustment that was comfortable. That would have been a real PITA if I had bought online.
The VPI shortlist saved me a lot of time, since I found a helmet that fit. If none of the shortlist had fit as well as this one did, I'd have broadened my search beyond the shortlist. This is the best fitting helmet I'ver ever had, and I think I got my first helmet in 1979, maybe even earlier. (Alas, I don't know if that makes it safer.)
Likes For philbob57:
Likes For thehammerdog:
Quoted: 18424 Post(s)
Liked 15,581 Times
Likes For Camilo:
Quoted: 1069 Post(s)
Liked 788 Times
*If you had to choose...*
OOPS, I would have to delay purchase for a bit since I just bought a 2010 Miata.
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,444 Times
They are complementary tests, so if you find one that scores high on both, it is confidence-inspiring. I bought a bunch of Bontrager Wave-Cell helmets for the family after a local tragedy. (They scored high on both.)
Likes For Polaris OBark:
Quoted: 604 Post(s)
Liked 1,064 Times
Doesn’t matter to me if either did. I’d just buy one from my LBS that fits properly, and is at least somewhat comfortable, so that I actually wear it.
Tim
Tim
Quoted: 823 Post(s)
Liked 1,961 Times
The only problem I have with Virginia Tech is their mascot is a castrated turkey.
Liked 2,164 Times
Likes For 70sSanO:
Quoted: 2326 Post(s)
Liked 4,997 Times
Quoted: 5224 Post(s)
Liked 3,585 Times
I wouldn't read either. I just bought a name brand helmet & I'm moving on
Quoted: 4227 Post(s)
Liked 2,488 Times
There is no difference in protection between various bike helmets...All bike helmets have to meet certain standards even the cheap ones sold through wallmart and other big box stores.
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
I just bought one at Costco. fit and has a red flashing light built in. In the old days I had all the fancy top of the line ones and I doubt I will get any less protection than the costco special.
Clark W. Griswold
Liked 4,001 Times
Yes the Costco helmet is going to be better than no helmet at all but there are differences in this stuff, having tried a lot of different helmets over the years I can say my higher priced helmets are a lot more comfortable all around and I know a lot of these companies are doing testing to make the helmets safer.
