Ultegra 9 speed shifters junk?
Quoted: 360 Post(s)
Liked 328 Times
I have had three Ultegra 9 speed rear brifters crap out on me. Fortunately, I have not paid too much for any of them. The issue with all three has been something breaking. It is not just about them being gunked up and reluctant to move. Have I had an unusual run of bad luck or is this common with Ultegra 9 speed brifters? Do the 9 speed 105 or Dura Ace brifters have the same problem? Would I be better off with a new MicroShift lever? I am currently back to bar end shifters which I like, but I would prefer brifters.
Thanks,
Thanks,
Andy
Andy
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
I have used 7700 Dura Ace and 4400 Tiagra over the last 20 years on 3 different bicycles. I have not had a problem with any of them & I am horrible about keeping up with maintenance.
Actually the front DA shifter did crap out 15 years ago. Found another used one on eBay.
So not perfect luck.
When I hear of failures I always suspect the shifter to be abused in some way. Forced shifting without the chain moving and the a like.
I see many people new to cycling attempting to to do that type thing.
Another observation comparing DA to Tiagra is that DA is extremely crisp in shifting but that same crispness tends to go out of alignment much easier. Tiagra has more of a sloppy feel but it is not so finicky to falling out of adjustment.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Generic (Microshift, L-TWOO, Sensah) 9 speed brifters are pretty cheap (under $50) & easy to source these days, some even have hidden cable routing under the bar tape.
Quality may not be Shimano, but operation & durability likely better than 20+ y-o brifters.
I've used MicroShift on my spare road bikes for more than 12 years (replaced Ultegra ST-6500), crisp shifting, bulky looks, but never had a problem; I'd say they are better than 20+ y-o Ultegra for sure.
Likes For cat0020:
There have been some failures experienced with these shifters. The earlier versions (6500, 6501) were more prone to some issues. The later 6510 version did improve the design that reduces the issues. Still not fool-proof but improved.
The well-known issue of contaminated/hardened grease affecting pawls. Additionally, the early version had problems with the screw/nut in a couple of places loosening and allowing things to get out of alignment. As users continue to try to' force the shifts', excessive force is applied or applied in poor direction because of misalignment, and further damages parts.
Like all products, defects happen, I've seen a few 65xx shifters with parts that were defective, (broken B arm, bent or broken spring, cracked shift plate). Also, have seen a few that were not assembled well, (spring not properly seated, locknut/screw not torqued properly).
Have you tried investigating further? There are some guides on doing a partial disassembly that will allow you to get a better view of what is going on. If a part is not broken, it may be repairable.
Likes For KCT1986:
Quoted: 360 Post(s)
Liked 328 Times
Andy
Andy
Quoted: 360 Post(s)
Liked 328 Times
Andy
Andy
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Under $30 for right 9 spd brifter or $50 for the set is not bad: https://www.aliexpress.us/item/3256803138921526.html
or
Shimano brifters look-a-like under $50 a set: https://www.aliexpress.us/item/2255800913897161.html
or
I remember back in the day-they would double shift when you clicked the front derailleur. Probably related to what KCT1986 said.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
A new or used DA 9sp shifter can cost a mint!
I planned to list a very nice right 7700-C on eBay soon.
My research shows these going for $150 in this kind of condition.
I'm sitting on a gold mine!
With the millions of these made during the many years these series were put into service, some are still going about 20 years after production. Guess that there were some design weaknesses in these. These were still reasonably early in the brifter era.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 978 Times
Anything mint regarding dura ace 7700 or ultegra 6500 can be expensive but well maintained those will last decades. I have seen people still using DA 7700 and Ultegra 6500 on their race bikes
Quoted: 303 Post(s)
Liked 136 Times
20-26 yrs ago I had 3 successive sets of Shimano Ultegra or 105 8spd brifters fail in the range of 1500 to 4000 miles.
All failed in the ratchet, ie at some point you lose indexing from 5-6-7 or 6-7-8 smaller cogs. Elaborate clean outs
and lubes did not revive. On transition to 9 spd had one such failure over several generations of same and the
10 spds have been very reliable. DA 10 spd on the tandem is still going strong at 25k+ miles. My 11spd 105 and
Ultegra are holding up fine at 15k+ on each bike.
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
I have DA 7700 brifters on both of my "good" road bikes (89 Eddy Merckx, and 92 Paramount). Both bikes shift perfectly after 1000's of miles ridden. My wife's Cannondale R500 had 9-speed 6700 Ultegra brifters for many years without any issues before she sold it, and my son has had my old Cannondale R900 with 9-speed Ultegra 6700 brifters as his college bike since 2017 which has had thousands of brutal inner-city Baltimore miles over the past 6+ years. Before he used it as his college bike, I raced crits and did team training rides with this bike for 7 or 8 years before that. Never had any failures of any of these brifters over many thousands of miles, and nearly 20 years of regular use.
So not junk in my humble opinion.
I have a set of Shimano 9 speed R600 (Ultegra grade non-Groupo short reach) shifters now on their third touring bike, a Soma Saga, Up front they run a compact triple with IRD front derailleur and in back they still run a 32 ring w/XT derailleur perfectly. I bought them used back about 2007, I think,
10 speed Ultegra is another story. I’m on my third front shifter since 2012 for our tandem.
