Shimano GRX RD 810 on 11-46t cassette, is it possible?
Old 01-07-20, 06:59 PM
rivfranxco
Bikes: Surly Midnight Special, Surly Straggler, Marin Pinemountain
Planning to get the GRX STI 810 along with the RD and would pair it with my existing 11-46T cassette but Shimano stated that the GRX RD only can handle up to 42T cassette. Does anyone have tried this before?
rivfranxco is offline
Old 01-07-20, 11:26 PM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Liked 145 Times in 78 Posts
I can't say for sure, but it probably will be fine. If not, try a wolftooth roadlink. I run a similar one on my MTB with an XT derailleur. It says it fits all the current Shimano road derailleurs and the 810 looks to be the same design.
Wolftooth Roadlink DM.
Bryan C. is offline
Old 01-08-20, 11:20 PM
rivfranxco
[QUOTE=Bryan C.;21274987]I can't say for sure, but it probably will be fine. If not, try a wolftooth roadlink. I run a similar one on my MTB with an XT derailleur. It says it fits all the current Shimano road derailleurs and the 810 looks to be the same design.
That's what I'm also thinking. I have an extender like a roadlink. Well, I hope the RD alone is enough just to save weight. Lol. Thanks for the input!
Old 01-13-20, 01:08 PM
MAGAIVER
MAGAIVER's Avatar
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times in 25 Posts
That would be quite a lot for the RD-RX810 , the biggest cog it can handle in the back is a 34. The RD-RX812 will handle an 11-46.
MAGAIVER is offline
Old 01-14-20, 07:05 PM
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
If you don't care about weight you can get a SLX derailleur and a Wolftooth Tanpan since it fully supports an 11-46. I did this and it also saved me ~$15 but I haven't installed it yet. Once I do I can report back on how well it works.
DarKris is offline
Old 01-15-20, 12:38 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
has anyone confirmed the rd-rx812 works with a 2x11 system yet?
redlude97 is offline
Old 01-15-20, 04:30 AM
DavidfGR
DavidfGR's Avatar
Bikes: Santa Cruz - Stigmata
Quoted: 13 Post(s)
Liked 13 Times in 7 Posts
RD-RX810 will work with 11-40, but this would be max, i tried 11-42 and no go.
DavidfGR is offline
Likes For DavidfGR:
Old 01-15-20, 06:08 AM
MAGAIVER
MAGAIVER's Avatar
Quoted: 31 Post(s)
I also want to know that, I've seen the 810 used on a 2x setup with an 11-42 cassete but I'm not sure if it will work well.
MAGAIVER is offline
Old 01-15-20, 02:32 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
Interesting since I got an Ultegra RX800 GS to work with a 11-42T on a 2x11 setup.
katsup is offline
Old 01-16-20, 12:38 AM
rivfranxco
That was my previous setup for several months. I jüst want to have a "proper" Gravel bike groupset which doesn't mix/matching anymore.
Old 01-16-20, 12:45 AM
rivfranxco
I'm talking about the 1X specific RD which Shimano stated that it could handle up to 11-42T. The 2X system just offers up to 34T only.
Old 01-17-20, 02:32 AM
DavidfGR
DavidfGR's Avatar
Quoted: 13 Post(s)
I tried again, this time with my new 2020 Santa Cruz Stigmata, setup with 2x11 Grx Di2, and i can confirm that the rear mech works without problems with 11-42 cassette.
DavidfGR is offline
Likes For DavidfGR:
Old 01-20-20, 07:09 AM
MAGAIVER
MAGAIVER's Avatar
Quoted: 31 Post(s)
The 1x RD is the RD-RX812 the RD-RX810 is the 2x version.
MAGAIVER is offline
Old 01-29-20, 05:13 PM
redlude97
https://www.cxmagazine.com/shimano-g...10-rx812-rx570
Of course, there’s a difference between what’s recommended and what actually works. Due to a mix-up, our test bike arrived with a GRX 2x RX810 crankset, front derailleur and front and rear shifters, but with a 1x RX812 rear derailleur. It did the job without complaint or issue, and I likely wouldn’t have noticed until I asked Shimano’s Nick Legan why his bike had oversized pulleys while mine did not. Legan diligently followed up, and discovered by mistake I was supplied the wrong derailleur for the 48/31 and 11-34 drivetrain.
In a day I had the proper unit.
I swapped the RX812 derailleur out for the RX810, made a few adjustments and hit the dirt again. The shifting was crisper across the two chain rings as the upper pulley of the RX800 derailleur remained consistently closer to each cog across the cassette. However, I’m thankful for the mixup, as it revealed the effectiveness of the Shimano clutch, as the 1x derailleur handled shifting duties without a chain drop, even though the drivetrain was 9 teeth over the derailleur’s stated capacity.
Similarly, the 2x derailleur can handle duty with larger-than-stated rear cogs with some aggressive B-screw adjustment. We’ve done the same with the RX800 and RX805 derailleurs. Shifting may not be optimal, but it’s certainly possible.
Shimano GRX boasts gearing versatility, but it’s actually even more than the specs indicate.
Likes For redlude97:
Old 02-01-20, 07:00 PM
Lindarets
Lindarets's Avatar
Bikes: J.Guillem Atalaya Gravel, Orient All-Road, & Tomir mountain
Quoted: 7 Post(s)
Liked 14 Times in 7 Posts
We've tried them and the RoadLink/RoadLink DM/GoatLink/GoatLink11 don't significantly improve the GRX RD-RX812 performance on an 11-46. Would love to sell you one, but wouldn't feel great about being in the snake oil business.
The 11-46 exceeds Shimano's recommended 31t cage capacity, for what that's worth. But other derailleurs in their line with the same cage length are rated for much more
Lindarets is offline
Old 02-03-20, 08:21 AM
MAGAIVER
MAGAIVER's Avatar
Quoted: 31 Post(s)
The Evil Chamois Hagar seems to come with GRX 1x with and an 11-46 cassete, at least it has an 11-46 on this review.
https://bikerumor.com/2020/01/23/rev...road-or-trail/
I don't see why it would not work, the RD-RX812 looks a lot like the XT RD-M8000 GS rear derailleur, I would even argue that a Sunrace 11-50 may work. I run full XT8000 with a GS rear derailleur and Sunrace 11-50 on my 29er without any hanger extenders or anything extra and it works flawlessly, I'll try the 11-50 once my GRX 1x group arrives.
MAGAIVER is offline
Old 02-04-20, 06:46 PM
jwill911
Riding is my addiction
jwill911's Avatar
Bikes: 2017 Orbea Orca,'06 Orbea Opal, 2019 Trek Checkpoint SL6
Quoted: 12 Post(s)
Thanks for the link and quote. I just replaced the Ultegra 50-34 chainset and FD for a GRX 48-31 and FD, on my Checkpoint SL6. And was trying to determine the difference between and correct RD for my 2x setup, the RD-812 or RD-810. This article made it clear so now I'm planning to follow up with the GRX RD-RX810 RD with a 11-40 or 11-42 cassette..
Thanks,
John
jwill911 is offline
Old 02-12-20, 08:07 PM
jwill911
jwill911's Avatar
Quoted: 12 Post(s)
I want to chime in here and confirm the RD-RX810 works with a 11-40 in a 2x.
Just picked my bike up from my LBS, they were iffy about the 11-40, telling me the Shimano specs state 34 max, but they said it worked easier than they thought it would.
I bought my Trek Checkpoint SL6 with Ultegra group, swapped out the compact 50-34 for a GRX 48-31 (w/ GRX front derailleur). But wanted to go lower so bought the RD810 and 11-40. Now I'm going to need to put some knobbier tires on as traction will be the issue now on steep rocky climbs.
John
jwill911 is offline
Old 01-06-21, 02:36 PM
David Stew
John
Hi John,
I'm hoping to do the same thing on my diverge. Came with 48/31 GRX 810 chain rings, and 11/34 cassette, with RD810 long cage. As we know, Shimano says 34 is largest rear suggested, but I want an 11/40. Did you have to also use the Wolf tooth link to make yours work? Also, which cassette did you get? Assuming the Shimano XT CS-8000?
Thanks for any help you can provide.
David
David Stew is offline
Old 06-14-21, 02:23 AM
loggan26
Originally Posted by David Stew
Hi John,
David
Can confirm this works. Have diverge on praxis rings. 40 tooth shimano cassette and grx rd 810 no wolf tooth extender. Just adjust B screw all the way out. Works fine.
loggan26 is offline
Old 06-20-21, 08:26 PM
Chilepines
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times in 37 Posts
Excellent video showing that 11-42 works, but the position of the B-screw is iffy. Adding a GoatLink made it all work perfectly.
https://bikepacking.com/gear/wide-range-grx-2x11/
Chilepines is offline
Likes For Chilepines:
Old 06-21-21, 04:56 PM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Great video, thanks for sharing.
Bryan C. is offline
Old 06-24-21, 08:56 AM
shoota
shoota's Avatar
Quoted: 1873 Post(s)
Liked 692 Times in 468 Posts
[QUOTE=rivfranxco;21276456]
Ok wait. Two things:
1) You already own everything you need to try it out but you're asking us? Just go try it out and let us know.
2) You want an 11-46 cassette, the heaviest cassette known to mankind, and you're worried about the 5g a RoadLink weighs? Come on bro.
2019 Salsa Warbird
shoota is offline
Likes For shoota:
Old 04-05-22, 06:31 PM
bikeaddiction1
bikeaddiction1's Avatar
Bikes: Many
Quoted: 114 Post(s)
Liked 80 Times in 50 Posts
I have a 2 x 11 GRX 810 drivetrain with a 46/30 crank on my Salas Cutthroat. I have bought a GRX 812 rear derailleur and plan to do this:
As I already have an 11-42 cassette in the garage I don't plan to go to 11-46 unless I really feel I need the climbing gear when packs are loaded. If the XT SGS cages don't show up on time (I am told May or June) I may just pull the long cages off of the GRX 810 derailleur and put them on the 812, which I have read of others doing. Not only does the video show it working, but I have read accounts of others successfully doing this. I know there are cheaper solutions but IMHO making a derailleur that has the right climb angle for the 11-42 cassette and SGS cage for 2X crank should shift better than adding a Goat Link.
bikeaddiction1 is offline
Old 04-05-22, 08:07 PM
sdimattia
Bikes: Wabi Classic, Bombtrack Hook, Bombtrack Tension, Vitus Substance
Quoted: 156 Post(s)
Liked 86 Times in 56 Posts
https://www.youtube.com/watch?v=7kUxmkuJWNg
I run a GRX 600 2x crank in the front with a GRX-RD812 and an 11-42t in the rear. I swapped the stock cage for a mountain M8000 long cage. Can run big-big, small-small, and everything in between with no issues. Could probably put a 46t cassette for a 46-46 ratio but the 46-42 is already low. Works great, 1k+ miles later. Cage swap was $20. No reason it wouldn't work on a RD810 as well.
sdimattia is offline
Likes For sdimattia:
