Recommend a good tool for cleaning a cassette?
Quoted: 120 Post(s)
I finally started recreating my second rear wheel. The hub cracked on the 2016 one I built. I'm taking spokes off the broken hub and rim and adding them to a new hub and new rim (new rim that was going to be the second front wheel).
So I took the cassette off. I figured I'd clean it off with a brush and soap and water. Then I remember the cassette was actually silver. I thought cassettes came apart into each individual cog wheel but this one is just a cap cover on the end, smallest cog, and then the rest are one piece. That makes it more difficult to clean. I ended up using ear cleaners on it, including cracking them in half to use the stick to pull out muck from inside the cassette cogs.
Is there any kind of tool or special brush that can more easily clean a cassette? While I was cleaning it I was thinking it's not that big of a deal to pop the cassette off to clean it like that. It was black and had the black "road clay" that builds up on all that.
For cleaning, you're supposed to use mineral oil or some solvent to really clean parts like that good, right? That might be a future project. Soap and water and a lot of scrubbing got it 90% clean, with an hour spent on that.
Quoted: 3242 Post(s)
Liked 2,090 Times
I take the wheel off the bike, spray the cassette with a degreaser, let sit a bit, then use the edge of old tee shirts to get between the cogs. Rags work as well.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
mineral spirits get recommended around here for cleaning. nylon brushes are good to scrub with. and, it'd be swell if you had an air compressor. those make short work of blowing all the crud off at the start and the finish
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
I wax chains so I never have to do this, but the best way is probably to soak in mineral spirits, and clean it with a stiff toothbrush. The fast way is to use camp stove fuel, which is less ecologically sound, and it is probably best not to smoke too heavily while directly engaged in the process.
Likes For Polaris OBark:
Quoted: 136 Post(s)
Liked 57 Times
Fat yarn from a yardage or hobby store to floss it while on the bike. Hold some like when flossing teeth and rock it back and forth between the cogs. The ratcheting of the hub holds and turns the cassette to a new section to clean. You can even wet the floss with your favorite cleaner (I like full strength Simple Green) then follow up with a dry flossing.
Quoted: 969 Post(s)
Liked 1,632 Times
Here's an idea... Put the cassette into a plastic wide mouth jar. Fill the jar at least half way up with ATF used or old. Strap the jar to your left leg then go out for a ride. Ha!
OK... Not laughing? Well...
Likes For zandoval:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I've seen some folks use pieces of cardboard of the right thickness. Someone once gave me a narrow brush with a serrated end specifically made for the purpose, but I'd never buy one. I also sometimes use an Allen key of the right thickness for the cassette, if that's nearer at hand. Then brush, cleaner, and rag to finish.
I used to use a bowl of gasoline and a small paintbrush, and somehow I survived that along with many other things I used to do.
Likes For andrewclaus:
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
Quoted: 980 Post(s)
Liked 584 Times
There is a lesser-known but readily-available (and cheaper!) alternative: a Denture Brush. The bristles aren't as long as the ones on the dedicated cog brushes, but they are better than those on a toothbrush. I have found these useful for other de-gunking purposes as well.
Likes For sweeks:
Liked 3,445 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
Dollar store kitchen brush.
Likes For caloso:
Quoted: 1438 Post(s)
Liked 1,092 Times
Having said that, I use heavy knitting yarn dampened in a safe solvent, "shoeshine" style, to clean the crud from between cassette cogs.
Quoted: 2333 Post(s)
Liked 2,097 Times
I used to put the cassette into the ultrasonic for 30 minutes with water, simple green, and dawn dish detergent. It comes out clean as a whistle. Now, I very rarely have to clean the cassette because I wax my chain.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I used to do the toothbrush method, but it is too small. Now I take an old paintbrush, put degreaser on it, grab bristles with one hand an inch or so from the tips, and pedal bike backwards with brush on cassette gears. You can do 4-5 cogs at a time this way, much faster. Holding the bristles you can get them just right, more stiff so they will clean better than if you did not grip the bristles. If you bend the bristles before grabbing you can shape the ends to the cassette profile to get even better contact.
Quoted: 6973 Post(s)
Liked 10,975 Times
Yep, it’s kind of like flossing. I don’t even take the cassette off the wheel – – I just the wheel between my gut and the workbench and use the edge of an old t- shirt the way you described
Quoted: 569 Post(s)
Liked 589 Times
That's what I do once I found the right thickness and sturdiness to cover 8 to 11 speed. I table saw up dozens 3"x5" at a time. I ride mostly on well swept bike lanes, periodically toothbrush sandwich the chain, cardboard the cassette and chainrings and with my OMS/bar oil mix getting great chain life and a clean bike.
Quoted: 6199 Post(s)
Liked 4,816 Times
You don't really believe it's silver do you?
Liked 3,445 Times
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times
Here's what I use for all my cleaning needs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
In the past I've used rags, brushes, etc. to try and get between the gears but a few years ago I started using the thick cords or stings off of a floor mop head. They can be off a clean, used mop head or pick up a cheep one at your local hardware or cleaning supply store. They are thick enough that the clean well between most sizes of cassette. You use one at a time and discard when dirty. One mop head will last most of us a very long time. I am still on my first one and I clean upwards of 20 cassettes a year.
Of course you still need to soak or spray the dirty cassette with you choice of cleaner or solvent before cleaning them up with the mop cords.
Quoted: 143 Post(s)
Liked 90 Times
dsbrantjr ....see his comment above for some common sense, he nailed it !
Kitchen brush from dollar store ....might cost 1.25 now .... ( Biden-era price increase, thanks Joe ! )
Harbor freight parts cleaning brush / chip brush
Likes For TPL:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1950 Post(s)
Liked 1,475 Times
After soaking and agitating in degreaser (preferably organic mineral spirits), this brush has long and stiff bristles which work well:
Amazon.com: Amazon Basics Drain Cleaning Brush, Blue and White : Health & Household
Comes in a two pack so one for kitchen and one for bikes; do not mix them up.
Likes For SoSmellyAir:
