How do I remove the BB cup?
Bikes: 2016 Fuji SL
Quoted: 69 Post(s)
I'm replacing the cottered BB in an old, low-end Bridgestone frame from the 70's with a square taper BB. Not sure how to get out the DS BB cup. I'm a bit confused with all the different terminology and standards, so it's been difficult searching and figuring out which method to use, or if I need special tools. Thanks in advance for your help!
Quoted: 86 Post(s)
if that one is threaded and has left handed threads, then...
i made and used Sheldon's DIY tool to good effect. Tool Tips--Bottom Bracket Cups
Those 2 holes are for a pin wrench. to use the holes you may have to make that tool yourself.
the truck wheel bolt sized Tool may be made up of parts found in an Auto parts store . get the bolt long enough to be wider than the BB shell .
Then it can be flipped either way ..
Quoted: 2338 Post(s)
Liked 2,827 Times
there is always the Sheldon Brown bolt tool method it works well (oops just noted this was already posted.....it is that good )
Bikes: 2015 All-City Spacehorse, 2014 Specialized Allez Race, Mid 80s Takara Acknowledge Fixed Gear
Park SPA-2 Red Freewheel Ring Spanner - Modern Bike
Spanner Wrench Pins | MSCDirect.com
Try either of those.
