Seat post tube of frame is out of round
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Duplicate threads merged.
Quoted: 18378 Post(s)
Liked 4,512 Times
Also, what size of seatpost?
i'm seeing a bunch of 1 1/8" muffler tubing expanders that likely would work for OS tubing, but not for 27.2.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...it's remarkable how difficult it is to successfully expand steel bicycle tubing to perfectly round once it's been ovalized.
Mostly the problem is getting it to go out past the point of elsasticity in the direction you want it to go, and if you don't do that, it snaps back to where it was or close to it. If you're just talking about the top, where the post insertion happens, you can sometimes just brute force a seat post to where you need it in terms of height, clamp it down, and use the bike.
In general, the cheaper the bike (lesser steel alloys are easier to manipulate), the more likely you'll have some success with this.
If it's just a cosmetic thing, and the post still works (like maybe it was still in the tube when it got squashed), the bike will probably still ride fine for a good long while.
Quoted: 4409 Post(s)
Liked 1,566 Times
If it was the top of the tube, I'd be inclined to try an undersized hardwood dowel that is split, then drive a wood wedge into the split. If (when) it gets stuck you just bore out the wedge.
But I have never heard of a tool for this.
