Saddle adjust question?
Quoted: 1858 Post(s)
Liked 664 Times
what is the more important when changing saddles of different lengths the position of the back of the saddle or the nose of the saddle ie if you are replacing a saddle that seems to be close to the correct set back with one that is longer by 8mm should the new saddle's nose or back of the saddle be used for positioning it? I am using the stem bolt (quill stem) as a measuring point. seems like it would be the back of the saddle but not sure. thanks
The big variation among saddles, aside from width and the height of the seating surface, is the position of the front of the rail relative to the widest point. This position limits the setback you can achieve with a given seat post.
Liked 664 Times
If you need more setback or need to get your saddle rail away from the edge of the seat rail clamp (it’s stronger that way), you might want to look for a Nitto S84 seatpost, which has another 15 mm or so of setback. It’s useful for putting a B17 or Professional on a BB modern road frame with a 74 degree seat tube angle, rather than the more traditional 71 to 73 degree seatpost angles.
Quoted: 514 Post(s)
Liked 451 Times
Saddle position looks good to me. Try straightening your upper back
Liked 664 Times
@jadmt, My guess is that you are not in any trouble with riding position, with three possible exceptions, strictly from my personal point of view.
1. I'm impressed by the rear view, where I see you are a much better roller rider than I am. Also notable and impressive is that you have very little hip rock. I tend to edge my saddles up until hip rock becomes uncomfortable (let me count the ways ... !). Then I back it down a little, fine-tuning as the season goes on.
2. I wonder if your center of gravity is a little too far forward. If you are fully acclimated to that position with respect to hand pressure while indoors, great. But I find I move around on the bike a lot more outdoors than on the trainer. I lift my hands up off the bars for bumps, as well my butt off the saddle. That's a lot easier when my center of gravity is over the BB axis. But your saddle cannot be setback farther, without a deeper setback seat post. The post you have looks like a good quality piece. For more setback I would suggest a Nitto S-84, but its only available in 27.2 mm, and it's pricy. I don't think it's the only high-setback post, but it has two bolts to enable fine adjustment.
3. I agree with the comments about the Brooks rails. Yes, they are quite tough, and yes, they have been known to break. It's not necessarily due to sheer weight, but due to localized overstress over a long time, metal fatigue. I haven't broken one, nor an Ideale, Selle AnAtomica, or a Specialized, but I am only 5'6" and I'm likely to weigh less than you. Selle AnAtomica at some time changed its steel rail material to CrMo from, well, whatever it was.
With all these, YMMV, but if it was me, I would try increasing the setback, especially since it reduces localized stress in the Brooksie's rails.
Likes For Road Fan:
just another gosling
Quoted: 3894 Post(s)
Liked 1,943 Times
Every saddle has a slightly different sweet spot for my butt, meaning how far back on that particular saddle do I find myself sitting? I get my fore-and-aft position by the balance method: can I lift my hands off the bars briefly without sliding forward on the saddle? I.e., I don't measure unless I'm using the same saddle on more than one bike.
I find I am more comfortable on long rides if I'm more stretched out than you are. When riding with horizontal forearms, I like my elbows to be just ahead of my knees. For my body geometry, that happens to be when my upper arms make a right angle with my torso, so quite a bit more reach than you have. You might experiment with considerably longer stems than you have now, see how that works for you. I feel most comfortable with a 30mm setback post (Velo Orange) and my Selle Italia saddle almost all the way back on the rails. I use a road bike bar with drops and brifters, which might make a difference. I like the varied hand positions which it provides. I spend a lot of time with the load on the side of my hands rather than my grip. Geezers tend to do relatively better on long rides.
https://velo-orange.com/collections/seatposts
My bike fit primer is here: https://www.bikeforums.net/21296948-post3.html
Results matter
Results matter
Likes For Carbonfiberboy:
Liked 664 Times
Actually, Carb, I tend to carry hand pressure mainly on the sides as well! I guess it's because it helps me keep finger contact with the brake lever.
Likes For Road Fan:
