Ultegra 6700 rear derailleur w/ 6600 shifters?
Old 02-21-10, 12:52 PM
Queequeg
I'm building a commuter bike and have Ultegra 6600 shifters, front derailleur and crank. If I use a 6700 rear derailleur, is it going to reduce the drive train performance in any way compared to finding the matching 6600 rear derailleur?
Shimano puts a scary-sounding disclaimer on the 6700 spec that suggests you need to use other 6700 shifters and parts. Is that just marketing hype to get you to buy everything again, or is there anything to that?
Queequeg is offline
Old 02-21-10, 01:55 PM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
AFAIK, there is no change to the RD's actuation ratio, so it should work.
DaveSSS is offline
Old 02-22-10, 01:53 PM
cpb406
Charles
cpb406's Avatar
No problem. See this link https://cycle.shimano-eu.com/publish/...harts_2009.pdf
cpb406 is offline
Old 02-22-10, 01:57 PM
jccaclimber
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times in 108 Posts
Agreed, you can swap those around and it should make no difference.
jccaclimber is offline
Old 02-22-10, 07:50 PM
xander k
...if you say so...
xander k's Avatar
Bikes: Litespeed Firenze (2004) , Kona Honky 2009 (lovely rain bike), Soma DC for the commute, ancient but intact Cannondale Criterium (1987), Bianchi Grizly Mtn
This will NOT be an issue in ANY respect. Multiple (DA 78xx,Ultegra,105) shifters have worked perfectly properly with the Ultegra 6700 in my personal experience. I am not a fan of 6700 aesthetics, but I swear the R Der is quieter than the 7800/6600... maybe my imagination, maybe a pulley design change, maybe just a byproduct of clean new builds with new chains. Both front and rear 6700 derailers are fine with all historical Shimano 10sp brifters, regardless of any lingering older "spend-more-please" Shimano incompatibility claims you may find. Mix as you like.
xander k is offline
Old 02-22-10, 07:59 PM
Panthers007
Great State of Varmint
Panthers007's Avatar
Liked 15 Times in 15 Posts
Shimano *LOVES* to scare it's customers into thinking that if a bolt falls off - you need to buy a new gruppo from them. You're gold.
Don't believe the hype.
Panthers007 is offline
Old 02-22-10, 09:49 PM
Queequeg
Super, guys---thanks a lot for the clarification. And Panthers007, great photo!
Queequeg is offline
Old 02-23-10, 01:51 PM
DArthurBrown
Chasing the horizon.
DArthurBrown's Avatar
Bikes: 2016 Felt F75, 2008 Mercier Corvus Steel, 2006 Trek 4300, 1985 Trek 620 (modernized)
Just to add to the good advice above. You could safely use any 10 speed Shimano derailleur without any real difference in performance. In fact, all but the very old rear derailleurs are compatible. My wife's bike is running a 10 speed chain on a 6 speed triple crank, with a double front derailleur, an 8 speed rear derailleur and a 9 speed cassette--no problems whatsoever. Bike companies want you to buy more stuff, but the only real compatibility issues are between the pull of the shifters and the swing (indexing) of the derailleurs. All modern Shimano derailleurs are compatible with all Shimano shifters.
If you're building a commuter, a Shimano Deore XT or Shimano 105 rear derailleur would be an excellent choice.
DArthurBrown is offline
Old 02-23-10, 01:55 PM
DArthurBrown
Spoke too fast. The front derailleurs are better off being kept with the same speed as the chain, since they are optimized for the external width of the chain for the smoothest shifting. But you could still probably get away with mixing it up--certainly if you use friction shifting on the front.
Old 05-23-10, 07:35 PM
nwengerd
Bikes: Cannondale CAAD9 6, Scattante R-330
So just to clarify here, I could get away with using my 9s Tiagra front derailleur with 6700 shifters/rear derailleur and a 10s chain and cassette?
nwengerd is offline
Old 05-24-10, 07:54 AM
jccaclimber
Quoted: 127 Post(s)
I've been using a 7sp DA braze on derailer with a 9sp Sram chain, 9sp Shimano cassette, and 10sp ultegra rings up front with 9sp Ultegra sti shifters for 5 years with no problems. I did pinch the center of the cage in just a bit though.
Old 05-24-10, 03:27 PM
Gonzo Bob
cycles per second
Gonzo Bob's Avatar
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times in 48 Posts
I thought there was a change made in the latest Dura-Ace and Ultegra groups that does require using the same model number front brifter and front derailer. But it does not apply to the rear.
Gonzo Bob is offline
Pax_Eco
Bicycle Mechanics
5
01-03-19 05:04 PM
dansknewb
Bicycle Mechanics
3
11-10-14 08:12 PM
paranoidroadie
Bicycle Mechanics
5
04-12-12 06:53 PM
bowman57
Road Cycling
2
03-15-10 01:49 PM
y8kmoal
Road Cycling
4
01-26-10 02:23 PM
