XTR Rear Derailleur with STI Shifters?
Quoted: 427 Post(s)
Liked 339 Times
I am building a touring bike and hope to run a 9 speed 12-36 cassette on the rear with drop bars and STI shifters. Can I run an XTR rear derailleur with 9 speed STI shifters? (I know the XTR front derailleur is not compatible with STI shifters so I am planning to use an Ultegra front derailleur.)
Thanks for your help.
Don
Don
Liked 5 Times
Which XTR rear derailer? An older 9speed version would work nicely, but the 10speeds are s'posedly not compatible with 9 speed shifters/cassettes, due to slightly different pull ratios.
Quoted: 3376 Post(s)
Liked 5,522 Times
I had one here for experimental purposes.
Liked 5 Times
Touche. But,let's remember, 2cents is only slightly more than 1cent, even though it's twice as much. Some glasses are half-full; others are half-empty, etc.
It's a moot point; dyna-sys is the exact reason why i (finally) decided to boycott Shimano. I used to love 'em.
Quoted: 1529 Post(s)
Liked 718 Times
Don't imagine Dyna-Sys is merely planned obsolescence; Shimano should have changed their RD's actuation ratio when they came up with 8s.
It's long overdue - double the cable pull is a welcome improvement, and compatibility hassles are as nothing next to systems so finicky they only work properly when everything's in perfect condition.
Liked 5 Times
It may not be "merely" planned obsolescence, but there is certainly a planned obsolescence facet to the situation. And, let's face it, those new chains are just a rip-off designed to fleece the customer.
I'm done. I'll keep my indexed stuff working as long as I can, then i'll move to friction forever.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Don
Don
Stuart Black
Stuart Black
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
It's not double. I tried to hang a dynasys RD on a road bike a while back, it was travelling 7 or 8 rings (out of 10) over the range of the shifters.
It is a completely pointless change whose only purpose that I can see is to make things incompatible with each other.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
As already pointed out, DynaSys has a different pull ratio and will not work, but any earlier 9S or 8S Shimano mountain rear derailleur will work just fine with road STI levers.
Quoted: 427 Post(s)
Liked 339 Times
Thanks,
Don
Quoted: 389 Post(s)
Liked 270 Times
The one in the picture ^^^ looks exactly the same as the one I tried to put on mine, which was dyna-sys. If it is the correct picture, I have no idea why it's working for you.
Bikes: Bridgestone RB-1, 600, T700, MB-6 w/ Dirt Drops, MB-Zip, Bianchi Limited, Nashbar Hounder
Nashbar seems to have a big sale/closeout on first gen XTR dyna-sys RD. Was tempted to buy one but looking for compatibility and so I stopped myself even though the price was good. I found buying a long arm Microshift version was indeed more compatible and cheaper. That might be an option, unless having the "all Shimano" gruppo label on the bike is important.
Quoted: 427 Post(s)
Liked 339 Times
I think that is the RD-M772 SGS. I guess I'll have to just plug it all together and wire it up then and see how it goes. Fingers crossed.
Thanks everyone! You guys rock as always!
Keep the rubber side down...
specialmonkey
Bicycle Mechanics
8
05-08-18 08:43 PM
paranoidroadie
Bicycle Mechanics
5
04-12-12 06:53 PM
Virginian
Bicycle Mechanics
3
08-14-10 01:18 PM
