Does a Decent Ant+ HRM Strap Exist?
Quoted: 942 Post(s)
Liked 526 Times
That is interesting to know - I have never seen that in my data. But who knows what is going on and when it actually started.
However, I do somewhat regularly see the following. Note the sudden ups and downs in HR noted with the arrows. This was an August ride so by 15 minutes I was quite wet. Yellow is power and this is a constantly rolling terrain ride. I had not been seeing this on every ride, but certainly 10% of them or more.
dave
dave
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
dave
ps. Here is one from late June - 1+ hours into the ride here in Southcentral NC. If better electrical contact is the problem, then some kind of medical electrode gel is the right answer. And I have no idea if this relates at all to the problem being discussed. But they certainly could be related.
Quoted: 452 Post(s)
Liked 162 Times
And here is a classic. The time is misleading. This one was indoors and I first did 30 minutes at 95-100% of ftp, stopped very briefly and saved that ride, and did another 40 pretty steady at around 80% ftp. You are wet an hour+ into that kind of ride.
dave
dave
Quoted: 452 Post(s)
Liked 162 Times
I have noticed VERY rare tachycardia events (3 times in the last 2 to 3 years). My doctor has chosen no further action at this time. I usually notice these but those symptoms are so mild I can imagine missing that during exercise.
dave
dave
Look at the Polar H9 then, still ANT+ compatible just doesn't give you the Duel Bluetooth Smart, the accelerometer, and the ability to store workouts without using a device that the H10 does
Likes For Laseranimal:
Quoted: 452 Post(s)
Liked 162 Times
Here is a high level view of the differences between an H9 and H10... https://www.polar.com/blog/polar-oh1-vs-polar-h10/ Significant (from my perspective) is that they both use no threads of any kind. You use a screwdriver to pop up a plastic cover. Also note that they do NOT use CR2032's - they use CR 2025's which might be a factor to folks (like me) who just bought a bunch of CR2032's.
dave
dave
And wouldn't you know it, I tried to put my Tickr on just now and one of the snaps had broken. Back to my old Garmin I guess. As long as it registers it'll be OK but I replaced it the first time because it wouldn't register for about 15-20 minutes into the ride. Outside that was OK but inside a lot of my rides were short.
I'll check with Wahoo about a replacement strap.
Quoted: 942 Post(s)
Liked 526 Times
From sweat corrosion? You need to do a better job at rinsing that puppy! That happened to me before I started rinsing it. Wahoo replaced my strap and they should replace yours as well.
