Di2 Bluetooth question
I've got a basic Di2 Ultegra set up that's working quite nicely, but I'd like to add BT connectivity so it can be paired with my phone and Edge 1030. I've got the required EW-WU111 module, but I'm not sure about where it can be placed in the wiring. Would it work properly connected to the wire that goes from my "B" junction box to the to the battery mounted in my seat mast? Thanks.
Quoted: 6190 Post(s)
Liked 4,806 Times
Quoted: 3230 Post(s)
Liked 2,079 Times
Yes and that's a good spot for it, keeps it out of the way. You'll need a short 15mm E-Tube cable, break the connection to the battery, put that wire into the WU111, then the short wire from the BT unit to the battery. Maybe wrap a bit of foam around the BT unit to keep it from rattling.
Liked 2,079 Times
Thanks! I've got the WU111 in hand and the 150mm cable is due to show up today. If I understand the manual correctly, when the mobile E-Tube app first connects to the system, it'll try to update the firmware before doing anything else. I've also heard reports of the update breaking the system. So I'm a bit worried about adding this piece of functionality.
EDIT: My notes from last April installing an XT Di2 system was that the BT unit on that system, which is the h-bar mounted gear indicator/charging port/BT connection/A Junction, is that the BT would not update via a PC connection, it would only update via the app on my tablet. I expected a bricked system, but it worked.
It will only update from a mobile or PC connection to E-Tube software. It might work out of the box, so I’d try to pair it with the Garmin first. There had been issues with the mobile E-Tube app updating the WU111 unit, which then and in the process of being updated, would subsequently dump the BT connection to the app, and brick the system. I think Shimano fixed this as they’ve been pushing the use of the mobile app. There are as well reports of issues using the latest E-Tube version 4.0.2 with a USB connection to a PC. I think I’d trust the mobile app currently.
Likes For August West:
I finally received the short Di2 cable I needed to install the WU111 yesterday afternoon, and the installation itself was a piece of cake. Put it inline between the B junction and the battery. Loaded the E-Tube mobile app on my phone and went thru the initial registration. It connected to my Di2 system without issue. It reported that all firmware was up to date. All the configuration screens worked as advertised, but I chose to leave well enough alone for now. My Garmin Edge 1030 recognized the Di2 system immediately so I added it to my sensors and set up the screens to display drive train data.
Long story short, everything worked without issue and the whole process was straight forward and easier than anticipated.
Quoted: 6956 Post(s)
Liked 10,959 Times
Now that I have it all together, I'd have to say I like the Di2 set up just a bit better than EPS. Clearly that's a subjective judgement, but it is based on first hand experience with both systems side by side. As always YMMV.
Liked 10,959 Times
I agree but since I have a Campy EPS system (V3) on my other road bike, I can't help but make some comparisons. The first difference I noted was the Di2 hardware shifts faster and quieter than it's EPS equivalent. The tactile feedback from the EPS shifers feels better to me, but it's not all that noticeable. The Ultegra gear seems also to run quieter too, but that atributed to it's realtively low mileage. I was somewhat dissappointed that the Di2 stuff needed extra hardware and a "fiddley" software set up to allow BT connectivity. The EPS V3 has that capability straight out of the box, and it's pretty tranparent to the user.
Well, it is just an opinion, after all. An informed one, I think, but without empiric data. The main reason I jumped ship was to take advantage of Shimano's lower gearing possibilities. There's no path to anything lower than a 34-29 in the Campy Record line, and my knees aren't getting any younger, and the stock 34-32 combo available in the Ultegra line is much more appropriate for geriatric knees in the narrow end of the Rogue River valley where going in almost any direction means some significant climbing. The electronics are really just the frosting on the cake.
