Best helicopter tape for frame protection
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
any recommendations for helicopter tape I see mentioned often to protect your frame? there seem to be a wide variety on amazon with a wide range in pricing.
This one seems okay and not too expensive.
https://www.amazon.com/VViViD-Clear-...3674958&sr=8-6
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
This is best:
https://www.skygeek.com/3m-8671-2-tape-clr-2-in.html
Helicopter tape is polyurethane, not vinyl.
Quoted: 805 Post(s)
Liked 2,990 Times
This is best:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
You'll never use it all! 2" x 36 YARDS. It's about a dime per square inch. Much less expensive than Lizard skins die-cut protectors.
Quoted: 841 Post(s)
Liked 1,064 Times
Yes, Polyurethane tape is what you want but should ad that you need to get the Outdoor/UV resistant type. It does come in less than 1/3 of a football field lengths too.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Before you spend money for paint film, go to a place that applies paint film to cars. They would probably give you some leftover material.
I got the leftovers from applying paint film to my Corvette, and I've put paint film on several bikes and there's enough for several more. it doesn't take much. The bottom of the downtube, the top of the DS chainstay, and the sides of the headtube are the areas I've applied film.
Dale, NL4T
Dale, NL4T
Quoted: 350 Post(s)
Liked 122 Times
I used Tesa 4289 strapping tape, which was for the rim tape, and wrapped it around the chainstay. It's an ugly yellow, but it's really cheap for $6 for 66 meters.
Quoted: 151 Post(s)
Liked 42 Times
This is best:
Quoted: 241 Post(s)
Liked 232 Times
Check places like Clear Mask or X-pel. Clear Mask sells bulk strips for various uses. 2" x 10' is $19.50, four 1/2" x 36" strips are $10. X-pel sell bulk 2" wide film for $1.83/ft
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
that is what has been on my mtn bike now since 2017 and seems to be working fine.
https://www.amazon.com/3M-Scotch-Sea...qid=1573710234
For the areas that take a heavy beating that is what I use though
Quoted: 604 Post(s)
Liked 1,064 Times
This, apply it using the wet method in their pdf instructions.
Tim
I use 3M and have no basis for a comparison with any other brand. I have found it useful for other things than my bike.
Quoted: 604 Post(s)
Liked 1,064 Times
Likes For tkamd73:
Likes For dsbrantjr:
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,110 Times
^^^yup, it is a brand that has not yet betrayed us... that said they have been pushing some stupid advertising where they drop some bowling balls on two plates of sheet metal joined by either a 1" strip of 3M glue or a couple of rivets. Which one do you think holds up?
You can often find frame protector that's pre-cut for your frame.
The real question is, what's the best bicycle tape for helicopters?
Genesis 49:16-17
Genesis 49:16-17
I remember my helicopter dets using "helicopter tape" and treating it as gold...couldn't tell you the brand or composition.
aged to perfection
Quoted: 840 Post(s)
Liked 1,271 Times
you'll never go wrong with the 3M stuff. I liked the suggestion about finding unused scraps at an auto detail shop. Be sure to use a windex or alcohol wipe before applying, and roll out or burnish any bubbles.
So-called helicopter tape (aircraft leading edge tape) is frequently used on the leading edge of main rotor blades to prevent erosion from sand and dust in harsh environments (like Iraq). The outer edges of main rotor blades approach a significant fraction of the speed of sound and blade damage is a constant concern in such conditions. Large helos have a blade monitoring system to detect cracks and damage and will turn a light on in the cockpit if activated. It is a lot like the tire pressure monitoring system in your Toyota Prius !
There used to be a tape available thru the NSN system called "ordinance tape", it was OD green and a lot like what's now available as "Gorilla tape". Great stuff. The joke was, it could hold a wing on at Mach 2. Never actually saw that tested.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Not sure you need real helicopter tape at $240 per roll. Sure, it would work, but a tape with a lesser spec (that is, cost) would probably work as well. A helicopter blade tip is going perhaps 850 fps (around 600mph) relative to the air on the advancing side of the aircraft. The duty level of tape protecting a bike finish is nowhere near that intense.
Quoted: 604 Post(s)
Liked 1,064 Times
Not sure you need real helicopter tape at $240 per roll. Sure, it would work, but a tape with a lesser spec (that is, cost) probably works as well. A helicopter blade tip is going perhaps 850 fps (around 600mph) relative to the air on the advancing side of the aircraft. The duty level of tape protecting a bike finish is nowhere near that intense.
Tim
Liked 341 Times
That makes more sense. There is the philosophy of getting somthing so way overspecced that you don't have to worry about it. I see on ebay you can buy a couple of feet of the stuff (but from China: pretty sure that its not 3M product).
aged to perfection
Quoted: 840 Post(s)
Liked 1,271 Times
As I said I liked the idea of finding scrap film at an auto detail shop.
I think the "real" tape is pretty thick for bike application. Agreed you don't need protection from 600 mph grit blast on a bike (altho I do get up to a significant fraction of that speed on my warm up rides) but you'll be glad you had it on the chain stay the first time the chain blows off !
Like chain lube, the fact that you have it on there is more important than what brand you chose.
Mark Petry
Mark Petry
Quoted: 1163 Post(s)
Liked 442 Times
I bought some “crankskins” which are not as popular as I would think. This is to protect my 6600 Ultegra and 7800 Dura Ace cranks, trying to both cover up existing scratches & prevent future scratches.
The “skin” material is a bit thinner than some chainstay protector helicopter tape I purchased. The crank skin is smoothed out with a blow dryer and a flexible plastic spatula. Heating it seems to improve adhesion. For some reason, the helicopter tape chainstay protector that I applied from a roll that I purchased years ago from Colorado Cyclist. The edges peel up a little, collect dirt & then you need to prematurely replace the helicopter tape due to this issue.
Quoted: 604 Post(s)
Liked 1,064 Times
[QUOTE=WizardOfBoz;21210112]That makes more sense. There is the philosophy of getting somthing so way overspecced that you don't have to worry about it. I see on ebay you can buy a couple of feet of the stuff (but from China: pretty sure that its not 3M product).[/QUOTE
Forget China, checkout Aircraftspruce.com, call them up way better deal, comes in a lot of different widths. There is even a UV protection version.
Tim
Tim
Quoted: 604 Post(s)
Liked 1,064 Times
Mark Petry
Mark Petry
Tim
Quoted: 1309 Post(s)
Liked 1,913 Times
Have you considered a coating of ceramic paint protection, it is going to be my next attempt at paint protection. I talked to a guy with a year old corvette that had the coating and it looked like it was just off the showroom floor, fresh from the detail shop. Smiles, MH
