The perfect bike for these times
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Since the lifting of the lockdown, even the drivers here in rural Yucatan have forgotten how to be courteous. That fact caused my routes to migrate off of the secondary roads and onto tertiary and quaternary (unpaved). I have become quite fond of off road riding. While researching whether the tube set was suitable, I found that not only is it suitable, but also the particular frame will take 42mm tires!
A 1980 Trek 414, made of Ishiwata 022. It is currently shod with a 27mm Open Pavè on the rear and a 32mm Kenda ?? cross tire on the front. So far that combination works well for a mix of pavement and non-pavement.
And I thought I always have been and always would be a pure roadie. Ha!
Likes For seedsbelize:
Quoted: 5888 Post(s)
Liked 3,471 Times
Traffic is not as bad here in Iowa as in Mexico but I've been moving more and more to gravel and rougher stuff to ride. I'm fixing up a 1979 Trek 510 with 700 x 35c tires for that kind of riding. I'm impressed that your 1980 Trek 414 can take a 42c tire.
So you know what they say, pics or it didn't happen. Besides who wouldn't like seeing a bit of bike porn from the Yucatan? Andale.
Likes For bikemig:
Quoted: 2364 Post(s)
Liked 1,751 Times
Sounds like an excellent adaptation, but +1 above, pics are hereby requested and required.
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Hmmm, I sense a shift to gravel bike... before you know it you’re going to be looking for “gravel specific” bikes and then carbon starts to look interesting and before you know it you’re thinking about 12 speeds and you don’t have a Suntour Perfect FW on or a front derailleur, you have a frame bag, your saddle looks like it has a *****, and there are these shiny discs attached to your hubs!
Just be careful... it’s a slippery slope. Just do a 650b conversion on your Trek and you’ll be fine... trust me.
I'm feeling the call to go off road more and more. One of my roadbike riding routes ends at a dirt trail leading into a big wooded area. Drives me nuts. I need an fat tired bike.
Quoted: 1873 Post(s)
Liked 692 Times
[QUOTE=seedsbelize;21615488the particular frame will take 42mm tires[/QUOTE]
You sure about that? Color me highly skeptical. Nevertheless, you should maximize what ever you can fit in there, it sure makes a big difference on rougher roads.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 821 Post(s)
Liked 255 Times
I sold most of my "c&v" bikes and ended up with a Yeti SB5 and a Santa Cruz Stigmata.
Between the two of them, I could survive rather nicely as far as bikes go.
While I still have some interesting steel bikes, they tend to just sit there.
Likes For gomango:
smelling the roses
Liked 901 Times
smelling the roses
Liked 901 Times
I personally haven't tried it, but I'm told it can be done. It looks doable.
smelling the roses
Liked 901 Times
Nope. The problem is twofold. The phone will not let me select from a specific album, and it will.also not let me download and go that route. There appears to be no option for uploading directly from the gallery. Perhaps things will be clearer in the morning.
smelling the roses
Liked 901 Times
Here is an old one, from last Spring (2019) which, somehow, was allowed to be downloaded. And is tiny. Is Mercury in retrograde by chance?
Liked 3,471 Times
https://johns-recycled-bicycle.blogs...ation.html?m=1
https://www.bikeforums.net/classic-v...tage-bike.html
The bikes that popped up on that thread are the Raleigh super course, Nishiki semi pro, Fuji special road racer and Motobecane grand record. All four are 1970s models. I suspect they were all originally spec'd for 27 inch wheels and they had lots of clearance even with 27 x 1 and a 1/4 tires.
smelling the roses
Liked 901 Times
I was wondering about that. I started a thread a while back as to which vintage bikes could take a 700 x 38c tire. There are not a lot of vintage bikes that can handle that:
Liked 3,471 Times
I've rebuilt a lot of old Treks from the late 70s and 80s. They tend not to have as much clearance as the early to mid 70s era bikes that were designed around 27 inch wheels. At least based on the feedback on that thread, vintage bikes that can take a 38c tire are not that common. Hopefully yours can.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
You can add an ‘84 Miyata 610 to that list.
Liked 3,471 Times
Quoted: 685 Post(s)
Liked 370 Times
tantum vehi
Liked 992 Times
Once in the 80’s, it gets hard to fit 38mm tires on Treks. I just barely got 35’s with fenders on my ‘81 412.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
smelling the roses
Liked 901 Times
I went back and read that article, and see it doesn't mention 42mm tires. I read that somewhere, I thought. Anyway, I'm gonna stick with the 35mm Kenda Small Block Eights that are on it now. Until they wear out. Our terrain is flat flat. But now I'm curious to see just how wide it will go.
Liked 692 Times
Add the '86 Schwinn Voyageur to the list. 42mm front, 38mm rear.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 2338 Post(s)
Liked 2,827 Times
I put 30mm corsa control tubular on the 85 team miyata......while it is not a gravel bike by any means....is sure handles the little forays onto the gravel on the side of one trail i use...... so suggest something like this 30mm on the 84 team miyata might be the ticket for next years heroica
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
If 'perfect' is attainable, it will have at least 42 on the front. It's easy to wash out on unknown surfaces. I'm running 47- 38 on a Triplecross and have had some anxious moments on steep downhill paths.
