Is this normal wear on derailleur pulleys?
Is this normal wear on rear derailleur pulley wheels? This from a Deore M590 RD used for 20-30 thousand miles.
I believe the left pulley is the lower one.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Sure, if you don't take care of your stuff that's what happens.
Quoted: 1088 Post(s)
Liked 1,028 Times
Seen it plenty of times, you're running metal over plastic, eventually they can't help to look like that. Just pick up a nice new pair and be amazed at how the new bearings or bushings make it seem easier to pedal and how noise went down. Not a big deal.
Likes For Russ Roth:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Yes, I've worn a few sets to where the teeth are pointy. Replace them.
Jeff Wills
Jeff Wills
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
Frankly I would have replace those 10,000 miles ago
Likes For Bob the Mech:
Quoted: 6199 Post(s)
Liked 4,816 Times
Were you looking for manufacture defect and wanting a free replacement?
Just replace them. Its what you do when things get worn. Surprisingly though, I think I've seen some that looked almost like that new back in the vintage days when all sorts of DR tech was going in every direction and experimenting on us.
Likes For Iride01:
Liked 4,816 Times
All cogs wear.... and pulley wheels are cogs technically, but they are special, so they get a more special name. At your mileage you should have some other things needing changing if you haven't already.
I have changed the cassette a few times and the crankset has maybe 7-10 thousand miles on it. A road biker fell on me and destroyed my original crank.
Quoted: 283 Post(s)
Liked 262 Times
They are worn out. Maybe the local bike coop has a RD or the pulleys you could swap in. Congrats on riding your bike enough to wear parts out. Awesome.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
I'd suggest you clean & lubricate your pulleys more frequently. Typical non-DuraAce/XTR Shimano pulleys are simple bushings. They run fine when clean and lubricated. They have no real pulling load on them, as they simply act as tensioners. But they quickly get dirty, dry out and get stuff wound around them, fouling them and causing a lot of drag. I've been amazed to see how much friction dry pulley wheels can add to the drivetrain. This wear indicates they had developed a fair amount of friction and that's why they wore so much. I have yet to wear out a set of pulleys to that extreme.
And yes, the left pulley is the lower. The lower one always gets more wear because it takes the chain at an angle unless you always ride in a gear combination that involves a perfectly straight chainline.
The replacement pulleys appear to use cartridge bearings.
After 20 or 30 thousand miles that's totally normal, even if you were using aluminium jockey wheels it would be normal. I would have replaced them several times in that mileage.
Keep in mind that they're plastic and as I've side before, the lower pulley takes the chain at whatever angle the gear combination you're using causes, and also the chain sometimes comes in weird angles due to bumps and irregularities, especially on MTBs. This means that the harder side plates from the chain rub against the teeth of the wheel constantly which causes the wear. Even if you use aluminium sprockets,aluminium is quite soft compared to the chain and doesn't make that much difference.
What can make a difference is keeping them clean, as dust, sand and any type of contamination gets trapped between the pulley and the chain plates and works as an abrasive.
Try to keep them clean and running freely, but I don't lose your mind over it. They're relatively cheap, usually last a long time, and after all, like all parts of the drivetrain, they're a consumable.
Whatever you do, in 20 or 30k miles they will be destroyed anyway. I'd just check that they're clean and spin freely. If they don't i'd try to free the bearings with a bit of oil. If they're just a bushing you can probably disassemble it and clean it. I've mostly had problems with them seizing on MTBs, as they tend to get wet when crossing streams or puddles and water doesn't play nice with the bearings.
Thank you for the guidance.
Quoted: 283 Post(s)
Liked 262 Times
If it's a sealed bearing pulley just clean it up, then put everything back together. I wouldn't try and take any of the bearing apart.
Removable bushing pulley-
Remove the round metal covers on either side. Q-tips and solvent, push out the bushing and clean whole pulley, teeth, grooves, and bore. Clean inside and out of the bushing. Find some grease, shouldn't feel too thick or crusty. Grease the inside bore of the pulley, outside of the bushing. Put the metal covers back, bolt the pulley assemble back into the derailer. When installed, pulley should spin freely.
Quoted: 279 Post(s)
Liked 207 Times
Found all but one! Probably 99% of pulleys have no actual ball (or cartrigde) bearings in them. These are really nice pulleys and deserving of an overhaul. Cleaned with fresh grease? Like buttah! And will roll better than bushing pulleys for a long time.
A 3mm allen wrench removes the pulley bolts so you can fully open them up and clean them. Again, they're basic bushings. But as I said, when they get dry, they can create a lot of friction. Clean off the old gunk, apply light lube like TriFlo and reassemble. LocTite on the bolt threads isn't a bad idea. Pulley bolts tend to fall out at the least opportune times!
In the future, just drip a little oil between the plastic and medal washer on the pulleys and wipe off all the excess. The oil will work its way in and will keep them happy. Overhaul 'em only as frequently as you see fit. 6 months or a year? Watch the football game and clean your pulleys!
If you have actual cartridge bearing pulleys, they can be flushed with solvent and relubricated without too much trouble. At least there are no individual ball bearings to fall out!
mechanically sound
By the time my pulleys look like that, the joints on the parallelogram are usually worn out too. I’d just get a new derailer personally.
mechanically sound
To me, it looks like abnormal wear. After 26000 km on the road, mine (sram force 22) are still very similar with the new ones, just the edges are a little bit less firm. And I use to heavily shift, to keep a constant cadence.
I had to change the whole derailleur for a new "middle cage" to accommodate bigger cogs (11-32), otherwise I think the old pulleys would last well above 100.000 km
It is on my all weather commute bike and I also ride it on dirt roads and dirt paths after work and sometimes on weekend.
