Trying to build a period specific bike, need info.
highflange.com
This is my bike, it is a Vitus Carbone 3:
I got this bike off of the Austin Craigslist in a big box of parts for about $100. Built it up as a fixed gear and to be honest it worked great as my going to the bar or running random errands bike for the last year and half. I recently had one of the crankarms fail and decided it was time to re-gear this bike and restore it to its former glory. Since I got it as frame/fork only I have no idea what originally came on it.
Does anyone have information on the release year of this frame or the original equipment that would have come on the bike? I imagine this frame was fairly high end for its time but I have no idea. Google has been less than helpful in locating any information on this bike other than it likes to fall apart. I realize I could build it up with just about anything but I feel it would be much more fun to have a full on classic bike.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Those down tube shifters are the key to your question. What model are they? Ditto the headset. Chances are (if they are original), they matched the other components. Bike likely came with either Shimano 105 or more likely Shimano 600 components. There are many competitor versions of this bike: Giant, Centurion, Trek, Specialized and many others made carbon frames with aluminum lugs.
Look for date codes on any parts you think were original (from the box of parts you had).
I have a 1992 Giant Cadex which came with 600 components.
Myself, I would probably look for some Shimano 600 components. I would not worry about what exactly came on the bike originally. Frames are meant to be built, with the components of your choosing.
What is your budget?
Quoted: 1372 Post(s)
Liked 1,752 Times
Not sure if this is any help but my Vitus was complete Mavic SSC "as found" You can learn more about it here, if you wish.
https://www.mytenspeeds.com/My_TenSpe...troduction.htm
I should add that the Vitus was a wonderful bike that had great ride quality. Sadly, at 230 lb, the frame set was flexing way too much and I feared damaging the bicycle. You might see it cruising around Texas one day.
Bikes: 2007 Nagasawa with C-Record, 1992 Duell with Croce D'aune/Chorus, three Gazelles, M5 recumbent
Quoted: 47 Post(s)
Liked 25 Times
The Vitus Carbone frames were very high end when they were build. The price in 1986 was 3000 Dutch guilders, which is about 1500 euro.
I still have a leaflet of the Dutch importer (Jan Janssen) in 1986, the frame was sold loose but could be build up with Shimano 600 or Campagnolo Record.
For $100 you got a really good deal.
highflange.com
@wrk101 Its got a campagnolo headset + cinelli handlebars/stem. The rest of the parts were from other bikes. I don't really have a budget, though it would be nice to stay under $500-600. I would like nicer stuff though. I've bought a dura ace 7402 front and rear derailleurs and these wheels:
https://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
@randyjawa Your site is great. I really enjoyed reading that.
@paulkal If you do not mind do you think you could scan that flyer? I'd be really interested to see it.
Quoted: 28 Post(s)
Liked 60 Times
The carbon-3 frame was a less expensive version of the carbon-7 which also used a carbon rear triangle.
It would have come as a bare frame from Vitus. Regional distributer or a LBS may have offered them as pre-built bikes, but most probably were sold as bare frames for the purchaser to build-up however they wanted. If you want a represenative period example to pattern your re-build, look back through old winning magazines for the time and set it up to match a pro-team build. Anyone buying a frame this expensive would have used components more attractive than lowly shimano 105. In the later 1980's era of snobby high-end bikes, 105 was really looked down on even if it worked OK.
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Quoted: 28 Post(s)
Liked 60 Times
woohoo! That era didn't end, or start, in the '80s. Just follow a few threads on the Road Forum, and you'll see that it is alive and well today. I would probably try to build it back using '80s vintage Mavic parts; they are unusual and make for a more interesting (and challenging, seein's how they are French) build. You have some expensive Campy parts, though, so maybe a full campy NR bike would be a little cheaper, and fully appropriate for this frame.
Bikes: 2020 Fuji Transonic; Zunow Z-1; All-City Macho King ACE; De Bernardi Track
Liked 10 Times
That's quite a nice bike and I'm glad your deciding to bring it back to its original state.
There was just a thread about Chombi's same exact bike that he recently built up: https://www.bikeforums.net/showthread...ighlight=vitus
He did a pretty good job, I'd say the closer you can get to him the better.
Quoted: 47 Post(s)
Liked 25 Times
Like RoboIsGod, I´m glad that you will bring it back to its original state, but I would not put 105 on this frame, it deserves better.
Here are the scans of the catalogues, they are in Dutch:
1986, with first generation C-Record
1987, frame only
And 1988 with Shimano Sante
I guess that in Holland french parts were not popular.
1987, frame only
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Welcome to the Vitus carbone resto club!
I think your bike is an 85 like mine but the "3" version instead of the "7".
Here's the recipe of my recent restoration/re-build of my Carbone 7:
Frame: 1985 Vitus Carbone 7, 7 tubes carbon with 979 aluminum fork.
Shifters: Mavic/Simplex/Spidel Retrofriction shift levers.
Seatpost: 23mm Rubis/vitus aluminunm, two bolt clamp microadjust.
Bar: Mavic Model 350 "criterium" bend bars.
Bottom bracket: Stronglight JP1000 sealed bearing cartridge BB English thread, 118 spindle legnth.
Crankset: Mavic Model 630/SSC 53/41(by TA Specialites).
Pedals: Look Keo Classic.
Rear Derailleur: Mavic 851 SSC.
Front Derailleur Mavic 860 SSC.
Freewheel/cogset: Malliard 700 Super Compact, 7 speed, 13/19T: British Threading.
Hubs: Mavic 32H 500/550, 100/126mm spacing.
Spokes: DT stainless 14/15/14ga. Double butted, with brass nipples.
Rims:Mavic 32H GEL280 tubular rims.
Brakes: Spidel/Mafac LS sidepulls.
Headset: Stronglight A9 with new style sealed cartridge bearings.
Chain: Sedis SL Pro Narrow chain
Everything French so far except these:
Stem: "Vitus" engraved ITM, 100mm.
Saddle: White, perforated leather covered Selle Italia "turbo"
Bar tape: Cinelli Cork in white.
Tires: 700C x 22 Schwalbe "Milano" tubulars.
Water bottlecage: Blackburn Road/competition
Bottle: "Vitus" bottle by Specialized.
Almost all of the compnenets are French and period correct (Bar tape and pedals and tires are the only items not period correct, but I consider these as wear items/incidentals).
Took about 6 months to gather all the compnents together and restore the bike. to what you see in the pic.
See other detail pics of the bike in my "Recipe for "Tout French" Build-up???" thread I recently posted.
Our bikes are pretty much identical except for the rear triangle. If you have any technical questions on it, feel free to ask. I hope I can contribute to the forum's answers!
BTW, thank you for not cutting off the rear derailleur hanger and permanently "neutering" the Vitus frame. Glad you decided to try and bring her back to what she could have been in the past.
Chombi
84 Peugeot PSV
highflange.com
@paulkal Thanks for posting those. It really gave me an idea of how these were originally sold.
@roboisgod That build is beautiful. I think I'm going to give the bike a full Dura Ace 7401 7 speed buildup as that seems to be the most common.
New question: Does anyone still produce clincher 700x23c or x25c gumwall tires? I found some second hand ones on ebay but I was more curious if they were still made.
highflange.com
@Chombi Your bike is amazing. Could you provide some more details on the bottom bracket? When I first got the bike the mechanic at the bikeshop mentioned the bike had an unusual cone style bottom bracket and told me to keep it in the event I restore the bike. It's got a generic shimano BB in there now; do you think it would be worth it to go back to original or a higher end BB?
Side note: It's quite amusing to find out this bike is an 85. It's older than me.
Quoted: 150 Post(s)
Liked 34 Times
Chombi
Quoted: 150 Post(s)
Liked 34 Times
I'll post pics of the bike with the PP76s soon just to have a more complete period picture on record.
Thanks for the tips! I suspect as bike build=up projects go they are never really done till you give away or sell the bike.....which I suspect i will never do with this Carbone 7.
Chombi
Quoted: 150 Post(s)
Liked 34 Times
1987, frame only
1987, frame only
Most of the time the top models were built up with DA 7400 groups as my Vitus Carbone was and I think even the later issue of the Peugeot PY10FC was. It was pretty mich the twighlight of the full French compnent group, the mid 80's was.
Spidel and mavic were the last ones to try, but the competition from the Japanese companies was just too strong, specially with their newer indexed shifting technology starting to be accepted as the new standard. Add to that the very high quality of the Japanese components, it was not surprising that mavic and Spidel put up the white flag by the end of the 80s'
Never really liked the idea of a Vitus with a Shimano group on it, being so used to all French Peugeots in the 80's...thus my French build-up/resto project.
Chombi
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Many of those Vitus frames were sold bare, so feel free to build it up any way that suits you.
highflange.com
If anyone cares I finished my rebuild with all the information in this thread. I appreciate everyones help and I did a full writeup of the rebuild on my blog:
https://highflange.com/2010/03/23/fro...-french-glory/
wrk101
6
02-06-12 09:05 PM
