New firmware (2.10) for Garmin Edge 800 released
Getting a clue
Bikes: 2010 Trek Madone 4.7, Diamondback Wildwood
Changes made from version 2.00 to 2.10:
* Improved Auto Pause behavior.
* Corrected issues that could cause incorrect speeds to be recorded.
* Improved auto wheel calibration especially for PowerTap power meters.
* Added a torque reading to the calibration page for Powertap power meters.
* Removed DeleteFiles folder.
* Allow the device to operate in normal mode with external power.
* Corrected issues that could corrupt activity files which would not allow them to be uploaded to Garmin Connect or Garmin Training Center.
* Improved keyboard layout, input, and design.
* Made improvements to the elevation profile.
* Added an activity reset reminder.
* Improved how the device responds when the screen has been locked.
* Added a factory default reset in MENU -> Settings -> System -> Initial Setup.
* Added the ability to view details for an activity that has not been reset.
* Data fields should now report correct time and distance while navigating.
* Corrected issues caused by removing an SD card while navigating.
* Corrected Auto Scroll issues.
* Corrected issues drawing the current activity on raster maps.
* Made improvements to the Virtual Partner.
* Added memory full warning message.
* Corrected issue that could prevent activities from being able to be deleted.
* Route recalculation can now be turned off in MENU -> Settings -> System -> Routing -> Recalculate.
* Added a day/night color mode setting in MENU -> Settings -> System -> Display -> Color Mode.
* Sensor settings will now be correctly maintained when merging FIT setting and sport files.
* Corrected issues with weight scale data recording and communication.
* Corrected issue that could cause lap calories to be reset after a power cycle.
* Corrected issue that could cause workouts, courses, and locations to not be displayed in their respective lists.
* Corrected issue that could cause data field changes on the map or elevation training pages to not be saved.
* Lap markers in a course will now be recorded correctly while following the course.
Quoted: 18883 Post(s)
Liked 10,646 Times
Thanks!
Bikes: something
I am hoping they send out a 705 update.
Its been long overdue from what ive heard after they recalled the latest firmware.
Quoted: 3376 Post(s)
Liked 5,522 Times
The updater tells me about it and asks if I want to update.
Then it goes out to lunch and never completes the download.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Note--it will reset your settings and your history. I'll wait another week or so to see if any more problems crop up. The last update, 3.2, was recalled and canceled.
Try downloading the update, and saving it as gupdate.gcd on the 705, and see if it'll update from that. From the garmin forum:
hello I'm martinus from belgium.
my problem: during update to 3.3 the 705 will stop at 50% and give a error message.
the only thing I can do is annulating the update.
can anyone help?
thnx,
martinus
23/12/10 : problem solved: reinstall (from this forum) a firmware vs 3.1 (download and rename to gupdate.gcd, than copy and paste into my 705) and after a new trial from the first time installation OK :-)
See this BF thread on manual updates.
can anyone help?
thnx,
martinus
Yep, just updated my 705 to 3.30 Released on Dec 10, 2010
Changes made from version 3.10 to 3.30:
*Improved calculation and reporting of total ascent, total descent, and grade.
*Correctly calibrate wheel size when using PowerTap hub.
*Backlight setting saved and set automatically on power-on.
*Improved 'Go Home' functionality to search for any user-created waypoints named 'home'.
*Added new timezone for Santiago, Chile.
*Allow house number 0 on find address page.
*Reduction in speed spikes from sensors.
*Added message indicating elevation calibration point (Save Location) has been found.
Improved robustness of internal filesystem.
*Changed XML settings file for use with Garmin Training Center.
*Improved autopause detection.
*Improved SD card reading.
*Improved reliability of barometer calibration.
*Improved reporting of elevation data.
*Translation updates.
Bikes: '09 Fuji Team Pro
B+ roadie I guess?
Bikes: 2013 BMC GranFondo GF01 Ui2
Well I updated without a hitch, it went pretty fast. I tried out the day/night views, and the night view pretty much just inverts the colors on the data fields (i.e., white text on black), and it also inverts the colors on the maps so the streets are white and the rest is black. I actually may try to keep it in night mode just to see if it is more visible during the day just to try it out.
I'll report back Thursday when I go on a ride if I notice anything different/broken/fixed.
B+ roadie I guess?
The DL/Changelog links for the 500/705/800s:
Edge 500 - https://www8.garmin.com/support/downl...ls.jsp?id=4715
Edge 705 - https://www8.garmin.com/support/downl...ls.jsp?id=3987
Edge 800 - https://www8.garmin.com/support/downl...ls.jsp?id=5237
Quoted: 14 Post(s)
Liked 13 Times
These Bike Forums are awesome, but for up to the minute info on Garmin devices, the Garmin users' forums are even awesomer.
https://forums.garmin.com/forumdisplay.php?f=20
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Thanks. I just updated.
ThePhoenix74
0
09-26-14 08:16 AM
Cyclelogikal
8
07-13-13 05:05 PM
