Carbon v Alloy
Carbon v Alloy
I know this thread has been posted hundreds of times, but in this instance the situation is reversed. The carbon bike I am looking at is cheaper, but weights more (maybe a pound or so). Is the carbon a better material even if the weight is not in its favor? I ask because it seems carbon can be quite fragile in crashes, humidity, and so on. If you had the option of carbon or alloy and the were pretty much the same cost, but the carbon weighed a little more which would you prefer and why?
Quoted: 20810 Post(s)
Liked 9,456 Times
Personally, I wouldn't base my decision solely upon weight or upon material.
Quoted: 2952 Post(s)
Liked 3,106 Times
Bikes: 2010 Giant TCR Advance SL
Why do alot of people think that carbon is fragile? I had a 2003 Giant TCR and I was still riding it up til a couple of years ago when I sold it to buy a newer one. In that time I had raced it and got hit buy an SUV that had taco-ed my Mavic wheels, but the frame is still good.
Liked 9,456 Times
Boom.
Quoted: 16 Post(s)
Quoted: 1851 Post(s)
Liked 679 Times
Airplanes also are made of Carbon Fiber, as are Formula 1 race cars, and even some super-high end sports cars, like Ferraris.
That said, most modern new carbon fiber frames are probably more durable than any high end, lightweight aluminum frames currently on the market. That's right, the average new carbon frame is probably more durable than a Caad 10.
To make aluminum lightweight, the tube walls are made very thin, and it is quite easy to dent the aluminum. Now, a dent will not immediately render an aluminum frame unsafe - it will not fail catastrophically, as carbon can - but the aluminum will eventually crack at the dent.
Now, you may be asking, why does everyone suggest racing a Caad 10 over a carbon frame - the answer is cost. Replacing a trashed Caad 10 is generally cheaper than a carbon frame, though unbranded Chinese frames are cutting that cost advantage.
downhill quickly
Bikes: SWorks Roubaix
OP; your assumptions of carbon are steering you well off the road. Take time and search here and elsewhere “actual” advantages/disadvantages of popular frame materials in line with your style and needs in cycling. After which come back and use this forum to discern those coin flip questions you have whereupon you’ll better separate fact from fiction. IMO: /burn this thread and rejoin with a more informed thread start...I'll watch for that one but won't waste time here spelling out a frame material 101 class for you. Good luck
Live to ride ride to live
Bikes: Calfee Tetra Pro
Carbon is not more fragile. The problem is that when carbon fails, it fails spectacularly and catastrophically, compared to metal frames.
But regardless, you'd generally have to have quite an accident to be a candidate for https://www.bustedcarbon.com/.
Knows the weight of my bike to the nearest 10 pounds.
Bikes: Colnago C59 Italia Di2
Actually carbon can be damaged by water, it will soak it up if water is in contact with the end grain of the fibre which can indeed damage it. Scratches should be sealed to prevent this but in reality a scratch usually does not expose the ends of the fibres, it exposes the sides so water is not such an issue
Liked 9,456 Times
Liked 9,456 Times
^ Smooths without dampening road feel - I use it myself.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Actualy I agree but you over-simplify the issue
