Non-Brompton front bags?
Liked 5 Times
I'm looking for a front bag for the front of my Brompton. I like the Brompton bags, but not the prices. I only plan to use the bag occasionally and spending $160+ on a bag doesn't work for me. I had the idea of getting the carrier block and one of the carry frames alone and using a handlebar bag. Has anybody else done this? Any bags work better then others?
Yup , First get the bag support frame, that fits over the frame block..
then you can get someone local to sew a bag to slide over it.
I had a messenger bag with a HD wide waist strap. i used a piece of coroplast in the bag ,
and found when I wrapped and clipped the buckle strap around the bag frame,
it was OK.
SJS cycles in UK has the bag frames.. separate,
web has pictures of people modifying the bag frames to clip on other pannier bags..
access to a metal fabrication shop? you can make
the bag side of the clip, others have.
FWIW Carradice has a Couple Brompton rack compatible bags , aiming at the commuter , in size..
it was OK.
Liked 5 Times
Nycewheels in NY where I bought the bike from actually sell both the regular and S frame. So, I got that part undercover. Just wanna see if anybody had ideas or would share their setups.
Some Examples From Left: Adidas Adapted Bag (purchased from my local Ross Dress For Less discount store for 10 dollars), I Luv UK Beaded Tote Bag, 2 photographs of the Lined Beaded Tote Bag Interiors
yahoo brompton group has a how to series of pix, on drilling out the poprivets. then narrowing the aluminum tubes , and clipping an Ortlieb pannier on..,
UK has some people, who modify brompons, make racks ..
Kinetics in Glasgow has a rack to fit a pannier pair.
Steve Parry, also in UK, made a clip that lets the HB bag
get screwed onto it.
he also made a tandem that you can store in a closet..
Starting with 2 Bromptons..
Quoted: 317 Post(s)
You need to search the forums and the net. Plenty stuff described out there, you`ll miss a lot of it if you just wait for the replies here.
Cheap Brompton bag is the Brompton basket. I added some material on top of it (made two) and turned it into a rolltop. This way nothing falls out of the basket and also the size can be extended quite a bit if needed.
If I did, I would not have the 2 dogs featured in my present Avatar or the nice kitty below in the signature-or the 3 bikes that are the best ones for me right now.
Liked 5 Times
I've searched a lot...just nothing solid popped up. I never ask questions on the forums without researching first. That's one thing I'm super anal about. I've only come across a few decent ideas from searches. This was my main reasoning for the thread. I have plenty of ideas which I said in my first post.
Cool Guy
Bikes: Jamis Sputnik, Leader 722 Heritage Edition, Brompton, Bianchi Via Nirone, Robinson SST, Diamondback Sorrento
folder fanatic, can you please show some pictures of how you custom made your bags? I'm planning to do one soon myself and would like to see other people's takes on it.
Private Mail me for more information if you wish.
Liked 5 Times
I bought the carrier block and s-frame today online. I've found a few bags that I'm interested in. I plan on drilling the rivets out on the side rails and cutting them shorter, so they will match the profile of the bags. I'm also thinking about just removing the side rails for small/slim bags and then install the side rails with screws if I use a bigger bag.
This is like my first idea...
I've often thought about a modified bag as well to adapt to the Brompton frame. To be truthful though, at the end of the day, I was just too lazy, and the Brompton bags - well - they do work pretty well, especially the C-bag.
Once I modified the Adidas bag for the Brompton's bare metal frame, I realize that I simply did not want to spend $150 US dollars for any bag that would work just as well at $10 dollars & a few hours (yes, hours-faster when you get used to the technique) of attaching straps to the bag at strategic points using a simple no frills home sewing machine.
to all,
This the exact thread I was looking for. I have an s-type. Just bought the frame and block. I am planning on getting a bag made up to fit this. I am lucky that my old man happens to have an industrial sewing machine from his days as a machinists. I am going to try it with an old cycle courier bag and the the bag below (hopefully the pic came through) for something a little more grown up!
His current project is to reinforce some denim jeans and add some reflective strips to the turn up. Very similar to the new levi commuter jeans.
Liked 5 Times
Here's my new bag...
I drilled out the rivets on the S-bag frame to remove the side tubing.
The hooks hang on the top of the brompton rack under the handle and the bungee holds it down. I used the loops below to allow me to use webbing if needed.
The bungee hooks to flush mount screws on each side where the rivets used to be.
The hooks are stainless steel and pivot from side to side. I slipped on some tubing for cushion.
Everything is screwed through a corrugated plastic for sale sign. It keeps the bolts from ripping through and keeps the bag ridged.
This bag has a rear compartment that has a zipper closure. It keeps the plastic panel and screws separate from the rest of the bag.
The hooks fold almost flat and are barely noticeable when wearing messenger style.
With the rack detached and flipped backwards and upside down inside...
...it acts as a kickstand for the bag
trrubicon,
That has almost single highhandedly increased my obsession about getting a bag made up. That looks awesome. At least I have a much better idea of what I can do with the front carrier rack.
I think my front carrier and block arrive this week some time.......its A-team time (albeit minus the blow torch and weapons).
k
k
Liked 5 Times
I forgot to add. The reason I made the bag attach with the hooks, is so I can use the bag on my dahons rear rack. So, its like a pannier bag.
I tied a loop of nylon cord thru the hole in the catch release lever, with a rubber button on it. ..
My steel Brompton bag support got a 9" bottom forward extension. 3 tubes and a cross piece in front , to haul Cartons ..
I have a Messenger bag , it has a waist belt too , the waist belt wraps around the side tubes and snaps together.
so when I have something else to carry , I put the Messenger Bag on .
Since this old thread was revived... last Xmas I bought myself a Ortlieb-Brompton O bag .. Always Its Dry inside.
went with the Bigger rear pockets , they snap on .. replacing the smaller ones Included.
Also optional.. A Bottle Cage, and a Mesh bag to put your helmet or similar sized thing In It. then it folds up small when empty.
Bikes: Brompton ML3
- Non-Brompton front bags?
I looks great and even matches the color of my cobalt frame. The bag will hold up to 14 liters. There is no interference with the brake levers and the bike folds perfectly with the bag attached.
In the future I may drill the rivets out on the side rails to remove or trim the size down a bit.
If combined with my Relevate Seat Bag (8-16 liters) it will provide a good bit of storage.
So far I'm very happy with the results.
Oh yeah, just tested, I can easily fit a 6 pack of beer in the front bag!
Quoted: 24 Post(s)
Jahwind, what kind of quick-release system do you have that grips on the handlebar like that? Where can I find one?
