Brompton porn. You are warned.
Awww man... that's brutal. If I only had $4000 lying around...
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Saw that the other day.
Pretty awesome, but a little too weenie for my comfort level.
Part-time epistemologist
Neat bike.
Who can add v-brake bosses to a finished titanium rear triangle/fork?
In reference to the description, can one spread titanium rear drop outs?
A narrative on bicycle driving.
RE: the description, can one spread titanium rear drop outs?
the bike in question uses Brompton's 2 external cog gear changer, so does not need that. ..
Brompton is working on their own front hub motor, to not make spreading required..
DancesWithSUVs
Quoted: 7 Post(s)
Hah,beat me to it.
Sweet ride,but I would have to do something about that front cable routing. Anyone know if that's some special zero compression housing,or did he make it himself?
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
There's no shifter or control cable for the "two speed hub".
2 speed kickback comes from a different source, and custom build up.
Front Ti forks spread (about 10mm) and dropouts opened up to 9mm to accommodate a small electric hub motor 1.4kg, 90mm diam and 83mm wide.
The other Brompton behind it is my first conversion of a steel Brompton using a slightly larger motor 2.0kg, 110mm diam, 83mm wide. The Ti fork work, took about three times as long to do mainly the part of opening out the dropouts with a dremel by about 2mm!
PS I have a SRAM A2 in the rear forks of the Black Brompton shown, though I had to remove one of the locking nuts and machine 1mm off the other one. I would not want to try and spread the rear forks.
Regards
Jerry
Regards
Jerry
"The bike is currently set as a single-speed, because I found it rather fitting for my relatively flat commute. I will, however, include everything needed to turn it back into a 2-speed bike."
When he says "currently set as a single-speed" it means the cable and shifter have been removed, but both sprockets are still installed. Strange choice.
Personally, I'd rather have the 2-speed capability than the weight savings. Then again, I haven't found carrying my M2L up the stairs a "daunting task", so I'm probably not the target market for this bike...
They are both Tongxin based. The smaller one on the white Brompton is a new lighter weight version known as a Goldant.
Available direct from here
Note though most things are shut down in China for the next week or so as its a national holiday.
Regards
Jerry
Regards
Jerry
Palmer
Liked 1,826 Times
Bicycle Repair Man !!!
Nokon housing... it's great for cables that have to withstand extreme bending and it is better, and even great for brakes but not as good for shifter cable.
