International Redux
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
International Redux
Two guys work at the same bikeshop in NorCal, but not exactly at the same time-missed each other by maybe 6 months. Life goes by, one moves back east, the other to the PNW. The bike bug reignites in one, stays strong in the other.
There's a shared affinity for vintage Raleigh's, the bikes of their childhood (isn't that the way it goes with us types). The PNW guy starts modifying them, feeling the rando bug (he is close to the BQ gang after all). The easterly guy collects a slew of them, fixes them up, they morph from fixie to IGH to modern derailleur, as they turn out to be extremely versatile frames. 27", 700c, 650b, lots of options with and without fenders.
The east coast guy comes across one that is pretty raggedy. a bit dented up, and won't be missed if the west coast guy screws the pooch. So he ships it to the left coast, and it sits a bit, queued up, ready for the torch.
It's time to start work on @nlerner's 1971 Raleigh International.
First, the dent.
You dent a tube, somewhere else it pops out-a zero sum game. Normally I'd just get a set of aluminum frame tubes, lube 'em up, clamp,, and roll it until most of the dent is worked out. In this case, however, a brake cable guide is in the way. It's gotta go. Some flux to keep the charring down, and lots of heat right on the boss until it glows, but before the tube overheats, then yank it of with some pliers
Note that there's a hole where the cable guide was. Raleigh pinned these in place back in the day.
Clean everything up before the next step:
A set of 1" aluminum frame blocks comes in handy for the next step. Lube 'em up first:
I can't emphasize enough how a good, strong vice gets used over and over again when working with frames:
Clamp tight and wiggle back and forth, working the frame back to round.
Sand it, clean it up, flux and filler:
Some hot water dissolves the flux, light filing and the shoe shine method with some 80 grit utility cloth, after paint you'll never know it was dented.
First, the dent.
Quoted: 1627 Post(s)
Liked 630 Times
Very cool, Gugie. I've always wondered how that sort of thing was done. Thx for the concise tutorial!
One spelling correction though: A good strong "vise" is what you use to pinch alloy blocks around a dented tube; a good strong "vice" is my penchant for booze.
Quoted: 3804 Post(s)
Liked 6,643 Times
I've been staring at that dent for years now, so I'm very glad to see it go away! Thanks, @gugie.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Gugie, you have a gift for explaining your work, much like a good teacher will have. Thanks for sharing the International Redux with us here.
Bill
Bill
Semper Fi, USMC, 1975-1977
Quoted: 472 Post(s)
Liked 1,028 Times
Thank you. Great post with excellent photos. I've got a small TT dent too but, alas, no block set. And I agree about having a real good vise, well mounted to a solid stand. I see in your last photo that you have the requisite jaw covers. I have made hard wood replacement jaws, a set of copper covers, a set of aluminum covers and a set of stainless steel covers (from a stainless drinking cup dispenser pulled out of the bin at our transfer station). I use them often for both bike work and general machinery repair. Well done.
Quoted: 3464 Post(s)
Liked 2,827 Times
Very interesting the locator holes for the cable stops.
Raleigh did have good production engineers.
Also note how little was submersed in the plating tank.
Don't waste that good Rhodesian chrome. (Former British colony)
If mine was not such a time capsule, I would consider modifying it.
I agree on a big sturdy vise. I got mine from National Lumber when they were closing down, weighs near 100lbs, $15. Need a solid bench below too. I really like gugie's back bench with the drawers, very cool.
Nice!
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Liked 5,790 Times
Fixed, thanks.
Liked 5,790 Times
Thanks! I like to use lots of pictures. It's hard to mis-spell those...
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 344 Post(s)
Liked 266 Times
gugie -
As a retired teacher, I am assigning you an A+ on your tutorial. Very interesting and clear. Thanks for the effort on the presentation.
Liked 5,790 Times
For a bit more detail on the process, here's a
You can make frame blocks out of hardwood with 1, 1-1/8, and 1-1/4" forstner bits on a drill press for accuracy. A hole saw would work as well, but the runout is much higher, typically, so the hole will be on the big side, and the amount of dent left over will be a bit bigger, no biggie. After you bore out the hole, just cut them in half with the grain (so they won't split in use). Since the forces on the block are in compression, with a vise backing them, should mostly do the job.
As noted in the video, and in my notes, it won't get rid of the dent completely, just makes the tube very close to perfectly round. Fill the small dent with JB Weld, let it cure, carefully file, and once you start nicking the steel, switch to 80 grith utility cloth. JB Weld can take powder coat temperatures.
I use brass and/or silver filler rod because I have it around.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
You've completely changed my ideas of what frames can be made to look nice again! Have I talked to you about the Schwinn Voyager in my garage?
My Bikes
My Bikes
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 163 Post(s)
Liked 101 Times
I tried making some frame blocks from hardwood (oak) but they cracked in the vise, so I bought a set of aluminum blocks. Only about $20 and much less screwing around.
Liked 5,790 Times
Paragon has them for under $20, a set of 3 for the main tubing sizes would run you around $50 shipped. Not a bad thing to have in your kit.
Liked 5,790 Times
Quoted: 7346 Post(s)
Liked 2,452 Times
Why is it better to roll out the dent before filling it?
Yeah, spelling is a funny thing. I had a google alert to show me vises for sale on craigslist, but I wasn't getting hits. Then I learned that most people spell it "vice." Adjusted the filters, and I got some hits, and I eventually got a good vise very cheap.
Heck on Wheels
Bikes: In Signature
Quoted: 206 Post(s)
"I had a great ride this morning, except for that part about winding up at work."
Bikes so far: 2011 Felt Z85, 80's Raleigh Sovereign (USA), 91 Bianchi Peregrine, 91 Austro-Daimler Pathfinder, 90's Trek 730 Multitrack, STOLEN: 80 Schwinn Voyageur (Japan)
Liked 5,790 Times
Try it with an aluminum can. Push a small dent in it, you'll find that somewhere else it pushed out. With small dents, even the one on nlerner's frame, it's pretty much just aesthetics. Since there's a whole bunch more torchin' coming up, the frame will get repainted. Nothing worse than having a fresh coat of paint and seeing a dent that didn't get filled.
But I should say that it may not be all aesthetics, after all. I apply a liberal amount of placebium on all of these remakes. It seems to have the same effect as a related element on the veliodic chart, drillium, although unobtanium is what you really want, if you can find it. All of these seem to make the bike go faster. Newpartium is a most effective element, but the half-life is rather short, sometimes decaying into Boxocrappium far too soon.
Liked 5,790 Times
I posted to the RBW group a few times, and made the mistake of spelling it Rivendale. Everytime I searched with that spelling google corrected me, so it reinforced my keystroke memory. Man, did I catch some gruff for that! Now I just call them Riv and Dale. They have a commune in Walnut Creek, hidden in plain site amongst capitalist squalor.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Liked 2,827 Times
This.
No one asked me, but I vote multicam.
Bikes on Flickr
Bikes on Flickr
