Anyone try one of these 25/28 tires? Roubaix pro tires
Bikes: 16 Haibike Sdruo Cross SM
Quoted: 30 Post(s)
Seems interesting. Going to put a bigger tire on my Sirrus, bones are getting older and need more cushion than a 23mm will offer.
Specialized Bicycle Components
Bikes: Dream Ti bike to celebrate turning 70 - frame by Seven; Cannondale Synapse carbon Ultegra 3 (2015 model), Cannondale Quick SL-1 (2012 model- donated to a friend); Bianchi touring bike (1985 - Sold); Raleigh Super Course (1975 - donated to friend)
Quoted: 24 Post(s)
Liked 5 Times
I can certainly understand the appeal to move away from 23 - sounds uncomfortable to my old bones.
Even the ones you linked to have no interest to me while a 25/28 is the widest.
Hope you locate a tire you like - I find the 32mm Continental Sport Contact IIs which came with my bike as OE work absolutely wonderfully - and even then I inflate well below maximum pressures (I base on - but a little higher than - this document https://www.bikequarterly.com/images/TireDrop.pdf )
Quoted: 30 Post(s)
I went for it today. Went to Performance Bike and got a Conti Grand Prix 4000S II. Got it at 25mm, with a 330 TPI should be plenty comfortable. I asked the staff if I don't like it can I return it for something else? They said yes everything at PB has a return policy even used tires. Going to put it on tonight and try it out!
The shop that sells that Roubaix pro tire does not take returns on tires too risky for me to just try.
Quoted: 24 Post(s)
Liked 5 Times
Since you are looking for more comfort I am not sure you can go too far wrong putting on what should be a quality tire that is a little wider than you are currently using.
I obviously place a much higher emphasis than you on perceived 'comfort'. As a matter of interest - what characteristics would likely make you want to return either the Roubais or the Conti ?
aka Phil Jungels
Since you are looking for more comfort, why not try something in the 32 to 35 range? That's if your Sirrus will take that wide of a tire...
An added bonus would be better traction and flotation in all aspects of riding.
Quoted: 30 Post(s)
I'm not into tires 28mm and higher due to it losing some agility . 23 is too uncomfortable at times and 25mm and 28mm is the sweet spot. These high priced Conti are very very nice, the lower rolling resistance is very evident. I had never tried a tire over 330 TPI before.
As for the question of returning a tire, I like softness and a tire that conforms to the road and rolls easy and is durable. I think Gatorskins fits that bill but many would not agree with that so that's why I think its probably best to buy local from a shop that takes returns on expensive tires like Performance Bike.
My car tires are 65 dollars each while the Conti 4000 were 55 dollars. You bet I want a refund if they don't meet my expectations at those prices.
Quoted: 30 Post(s)
Its the high TPI that is a big difference and yes I can tell the difference in tire sizing. More volumne of air, better casing, material of tire. Its like a tennis racquet, you can buy one at Target for 30 bucks or one for 200 bucks at the fancy tennis shop. There is a difference.
Sumerian Street Rider
Bikes: Dahon Mu P8, Fuji Absolute 1.0
Quoted: 29 Post(s)
But I am a huge fan of fatter tires. If I owned one even my road bike would run 28s and my very road like hybrid is running 38s right now. I can't imagine anyone being disappointed in the Grand Prix 4000 tires so I am betting the OP won't be returning them. Personally I would go with the 32mm Grand Prix 4-Season and I may do that. I'm not sure my aging Vittoria Voyager Hypers are up to the gravel loop on RAGBRAI this year and while I could replace them with the same I would like to try an even higher thread count casing. My tentative plan was to consider the Vittoria 28 mm Open Pave but since the 4-Seasons are now available in 32mm that might be the weapon of choice for me.
Quoted: 30 Post(s)
I got them on today in the front. In 25/28 sizing. The Sirrus Expert in 23 or 25 front tire seems twitchy to me and there are times it feels too slim for cracked roads. The Roubaix Pro 25/28 is actually wider than 28 Gatorskins.
Handling is improved because its wider but, it rides just like a Gatorskin except for the lower price you might not notice the difference between these 2.
I rode around with a 23mm in the rear for a bit, it was very fun. The front 25/28 for handling, traction and the small rear tires helps a lot to make it feel agile. But it was too uncomfortable so back went a 25mm Rubino Pro Slick in the rear. Less fun but more stable overall.
I think I will stick with the bigger front smaller rear for a bit now. Its works for me.
aka Phil Jungels
Funny you should say that.... I mix tires, putting the wider one in the rear.
I find that the wider one improves comfort, while the narrow one on the front improves handling, meaning quicker and more precise. The narrow on the front does not impact comfort as much, and the wider on the rear does not affect handling as much.....
My Crosstrail came with 45s as OEM, and I ended up with a 40 on the back, and a 35 on the front. My Sirrus came with 28s, and I will probably end up with a 32 on the front, and a 35 on the back (about the widest that will fit on mine).
Of course, it would be much different in the mud...............
Food for thought.... MHO
Theflatbarguy!
Bikes: Custom Giant Anyroad Flatbar, Custom Raw Steel Raleigh XXIX SS
Quoted: 40 Post(s)
Any word on what the actual size is on these tires? Do they measure 28mm or??? If someone could post up a measurement (and on what size rim) that would be great as I'm considering a set of these.
Quoted: 30 Post(s)
Here is a 28mm shootout 28mm Tire Shootout - Slowtwitch.com
Here they measured it - Specialized Road Tires 2014 - Slowtwitch.com
I’m a fan of larger tires for training, and the Roubaix Pro did not disappoint. Specialized sent the 25mm version to Tom for roller testing, and the 28mm version to me for real-world pothole bashing. The retail price is $55 per tire, and the quoted weight is 260 grams (25mm) to 300 grams (28mm).
When installed on the 17mm (internal width) Roval CLX60 wheels, my tires measured a whopping 28.4mm at 90psi when brand new. My titanium frame has generous tire clearance and had no trouble fitting it, and Specialized says that it fits their endurance-minded Roubaix frame.
Theflatbarguy!
Quoted: 40 Post(s)
Thank you for the info 2702!
I considering the 25/28 Roubaix tire as well as the Conti 4000s II, and the Schwalbe Ultremo ZX in 28mm.
Bikes: Cannondale Quick 2
Quoted: 27 Post(s)
Liked 32 Times
I am very, very pleased with them. I run them at around 80 psi.
Best regards
Quoted: 1581 Post(s)
Liked 1,193 Times
Liked 1,193 Times
Quoted: 29 Post(s)
With a little bit of looking I found this which is the best tire efficiency data I know of although it is now 5 years out of date.
Bikes: Steel 1x's
Quoted: 632 Post(s)
Quoted: 30 Post(s)
I think that's right, the Roubaix tire is more of a flat profile. I think it works well with a more sporty " tippy" racing tire in the rear. I like that setup.
