How to Adjust Spring Tension - MAFAC Cantilevers
Bikes: '72 Paramount 15-9, '74 Schwinn Paramount P10-9, '73 Schwinn Super Sport, 1983 Schwinn Voyageur SP,17 Motobecane Cafe Noir, 1970 Raleigh Competition Tourist, 1999 Rans V-Rex
Quoted: 220 Post(s)
Liked 83 Times
Trying to install a set of MAFAC cantilevers on my '75 Paramount.
Spring tension pushes the pad arm directly on the side of the rim. Obviously, with the pad, pressure on the rim is even tighter. Can't see any way to get pad clearance.
Is there any way to decrease the spring tension in order to get some rim clearance? I don't really want to start bending the spring out of shape however.
If it helps, I'll post a pic but I'm sure everything's installed correctly on the cantilever braze-ons. I saw where some thought there's different front and rear springs. Not the case here.
Thanks
Thanks
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
First, disconnect the springs on both sides and make sure that one side isn't binding. While you're there, check to make sure both springs are "sprung" away from the brakes at the same angle. They should engage with the brake arms at about the same distance fromt the rim. If they don't, you'll have to bend them a bit to make them equal.
Quoted: 220 Post(s)
Liked 83 Times
The pad arm is tight against the rim without the pad on. With the pad arm on, its really tight. I'm afraid if I press hard on the arms while they are mounted to get some space between the pad and the rim, I'm going to torque the hell out of the spring and perhaps not have the same tension on both sides.
Liked 5,790 Times
Youn can bend the spring and debend it several times, won’t hurt anything. They’re made of steel, you’re not going to break them.
Randomhead
Liked 3,687 Times
I had to bend one of the springs on my Mafac racers to get it to sit at a distance from the rim. Same problem, only upside-down
Quoted: 964 Post(s)
Liked 1,451 Times
While there is no difference between springs front to rear, there is a difference side to side. It's worth double-checking to make sure you have the right side's spring in the right spot. Both springs should have the long part coming off the bottom of the coil, then entering into the hole in the brake arm, like so:
Have you got them set up like that?
Quoted: 1136 Post(s)
Liked 650 Times
It's very easy to mistakenly install the springs on the wrong side such that they are pushing the arms inward instead of outward. Uninstall and switch the springs and you'll find they work just fine.
Edit: @scarlson beat me to it
Quoted: 220 Post(s)
Liked 83 Times
But why is the spring pushing the brake arm toward the rim? That doesn't make much sense. It is meant to push the brake arm away from the rim, and then your cable pulls the arm toward the rim. It seems it would have to be pretty badly bent to be pushing the brake arm toward the rim as hard as you are describing.
Quoted: 220 Post(s)
Liked 83 Times
Thanks for the assist
