Would the Handlebars Work?
I'm getting tired of my hands getting numb and wrists uncomfortable with the flat bar on my trek fx 7.3. I've tried adjusting the existing bars to no avail. Would these work with the shifters and brake levers I have?
SUNLITE Northroad Touring Handlebar https://a.co/d/a0wNHTg
Or.maybe these??
Or.maybe these??
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
The bar shown will work with your brake and shift levers. However, you need to be aware of at least two things:
- It looks like that bar uses a 25.4mm stem clamp diameter, and your FX likely has a 31.8mm stem clamp diameter. You can get shims to fit a smaller diameter bar into a larger stem, or you can also buy a stem with a 25.4mm clamp diameter. Either way would work, but it's something you'll need to check on. You can also get swept-back handlebars with 31.8mm stem clamp diameters, but they are less common.
- You'll very likely need to re-route or even lengthen your brake and shift cables, since the back-sweep on that and similar bars will move the levers rearward. Depending on the configuration of your cables, this may require longer cables and housings. This is most likely to be an issue for the front brake, which generally has the most direct routing and, thus, the least amount of slack of free play.
Thanks so much! Maybe I'll just give bar ends a try.
I Saw there are $20 ones and these ergons for $55 that people on here seem to like. I wonder if they are worth the 150% markup
Quoted: 1083 Post(s)
Liked 687 Times
Quoted: 581 Post(s)
Liked 921 Times
IT shouldn't be too hard to mount those bars, as mentioned above, but this won't necessarily fix the problem. Excess pressure on the hands leading to discomfort and numbness is often caused by other details of bike fit, especially saddle adjustment.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
I like my Ergon GP5's, three hand positions, and very supportive. You just need to make sure they are adjusted properly so when on the bar portion of the grips, your hand and arm align so your not bending your wrists. Otherwise you will still have wrist pain. Following is copied by Ergon's site:
Likes For travbikeman:
Food points, all. I've fiddled with the seat and rotated the bar every which way to try to keep my wrists straight but no matter what I do, I still have issues. Fortunately Amazon has a pretty liberal return policy (for now) so I guess the Ergons on worth a shot
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 438 Times
Another Ergon user here. One of my favorite additions for sure and greatly improved my comfort. You probably found my Quick 1 thread with pics.
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,310 Times
I've always wondered, how does one brake if your hands are on the bar ends? Seems dangerous. On the MUP I ride I have at least one panic stop per week to avoid rabbits. So I've been reluctant to move my hands so far from the brakes. I often ride with my fingers on the brake levers themselves.
Mark
Mark
Liked 762 Times
Another solution is "hooked" brake levers, similar to these: https://www.amazon.com/22-24mm-Brake.../dp/B08NPGN52K
You can configure those so that you can pull the main part of the lever from the main grips, or the hook or curved part of the lever from bar ends.
Likes For hokiefyd:
