Replacing bearings on WI hub
Old 12-01-11, 10:32 PM
jnbrown
jnbrown's Avatar
Quoted: 133 Post(s)
Liked 95 Times in 52 Posts
My rear tandem hub needs new bearings.
White Industries lists the bearings as 6902-2RS.
Would these work?
https://www.jensonusa.com/store/produ...e+Bearing.aspx
Is there any preferred brand? I hear Enduro a lot.
The instructions also call for a bearing puller. I found this one:
https://www.jensonusa.com/store/produ...ng+Puller.aspx
I assume to press the bearings in you could use a large bolt and washers?
jnbrown is offline
Old 12-02-11, 02:31 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
6902 refers to the size, inner diameter, outer diameter and width. Any bearing with that designation would fit. The 2RS part refers to the type of seals, which is a less critical feature.
For my inline skates, nothing has ever come close to the original SKF bearings. But for bikes I can't really say that I've noticed any other difference apart from "worn", "run in" and "new".
A puller can be handy, but I've usually simply tapped out the bearing from the other side.
Bolt and washer is a so-so technique. Bolt-and-washer will have you pressing sideways on the inner race (to some degree), and these bearings don't really like that kind of load.
Ideally, when installing a bearing (w/o the axle being present), you should seat a bearing by pushing on the outer race only.
Now, a bearing can take a bit of sideways load, so unless it's a really tight fit in the hub, bolt-and-washer may still work out OK.
My favourite improvised bearing press tools are the sockets out of a socket wrench set. There's just about always one in there that'll mate up nicely with the outer race.
dabac is offline
Old 12-02-11, 09:40 AM
jnbrown
jnbrown's Avatar
Quoted: 133 Post(s)
Thanks for tip on using a socket. I can probably pick one up cheap at Harbor Freight.
jnbrown is offline
Old 12-02-11, 11:00 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
If you are planning to buy a socket for this specific use, be sure to take the bearing with you. Get a socket that has almost exactly the same OD as the bearing's outer race OD but not so large it won't fit into the hubshell recess.
I expect what dbac was talking about is that he already has a fairly complete set of sockets and just picks an appropriate one from the existing choices.
HillRider is offline
Old 12-02-11, 11:31 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Enduro is a 90% fill, all ball type bearing cartridge.
an angular contact bearing in a Hub
may be better than a radial contact type, if there is an adjustment, mechanism.
as they function like a cup and cone, the orientation is a factor when installed..
fietsbob is offline
Old 12-02-11, 06:28 PM
Soil_Sampler
A little North of Hell
Quoted: 71 Post(s)
Liked 4 Times in 4 Posts
White Ind. bearings
White OEM bearings are Enduro.
https://enduroforkseals.com/
Soil_Sampler is offline
patricio.montes
Bicycle Mechanics
25
02-08-19 09:38 AM
joedab
Bicycle Mechanics
16
12-17-18 05:11 PM
HerrKaLeun
Bicycle Mechanics
20
12-21-17 12:26 PM
jambon
Bicycle Mechanics
7
11-24-17 08:14 AM
clones2
Bicycle Mechanics
9
12-14-13 11:57 PM
